7.1 Release
infer_ioptions.h File Reference
Data Structures
class  nvdsinferserver::IOptions
struct  nvdsinferserver::IOptions::OTypeV< V >
struct  nvdsinferserver::IOptions::oType< Value >
struct  nvdsinferserver::IOptions::oType< Value * >
struct  nvdsinferserver::IOptions::oType< bool >
struct  nvdsinferserver::IOptions::oType< double >
struct  nvdsinferserver::IOptions::oType< int64_t >
struct  nvdsinferserver::IOptions::oType< uint64_t >
struct  nvdsinferserver::IOptions::oType< std::string >
Namespaces
 nvdsinferserver
Macros
#define OPTION_SEQUENCE_ID   "sequence_id"
#define OPTION_SEQUENCE_START   "sequence_start"
#define OPTION_SEQUENCE_END   "sequence_end"
#define OPTION_PRIORITY   "priority"
#define OPTION_TIMEOUT   "timeout_ms"
#define OPTION_NVDS_UNIQUE_ID   "nvds_unique_id"
#define OPTION_NVDS_SREAM_IDS   "nvds_stream_ids"
#define OPTION_NVDS_FRAME_META_LIST   "nvds_frame_meta_list"
#define OPTION_NVDS_OBJ_META_LIST   "nvds_obj_meta_list"
#define OPTION_NVDS_BATCH_META   "nvds_batch_meta"
#define OPTION_NVDS_GST_BUFFER   "nvds_gst_buffer"
#define OPTION_NVDS_BUF_SURFACE   "nvds_buf_surface"
#define OPTION_NVDS_BUF_SURFACE_PARAMS_LIST   "nvds_buf_surface_params_list"
#define OPTION_TIMESTAMP   "timestamp"
Enumerations
enum  nvdsinferserver::OptionType : int {
  nvdsinferserver::OptionType::oBool = 0,
  nvdsinferserver::OptionType::oDouble,
  nvdsinferserver::OptionType::oInt,
  nvdsinferserver::OptionType::oUint,
  nvdsinferserver::OptionType::oString,
  nvdsinferserver::OptionType::oObject,
  nvdsinferserver::OptionType::oArray,
  nvdsinferserver::OptionType::oNone = -1
◆ OPTION_NVDS_BATCH_META
Definition at line 48 of file infer_ioptions.h.
◆ OPTION_NVDS_BUF_SURFACE
Definition at line 50 of file infer_ioptions.h.
◆ OPTION_NVDS_BUF_SURFACE_PARAMS_LIST
Definition at line 51 of file infer_ioptions.h.
◆ OPTION_NVDS_FRAME_META_LIST
Definition at line 46 of file infer_ioptions.h.
◆ OPTION_NVDS_GST_BUFFER
Definition at line 49 of file infer_ioptions.h.
◆ OPTION_NVDS_OBJ_META_LIST
Definition at line 47 of file infer_ioptions.h.
◆ OPTION_NVDS_SREAM_IDS
Definition at line 45 of file infer_ioptions.h.
◆ OPTION_NVDS_UNIQUE_ID
Definition at line 44 of file infer_ioptions.h.
◆ OPTION_PRIORITY
Definition at line 42 of file infer_ioptions.h.
◆ OPTION_SEQUENCE_END
Definition at line 41 of file infer_ioptions.h.
◆ OPTION_SEQUENCE_ID
Definition at line 39 of file infer_ioptions.h.
◆ OPTION_SEQUENCE_START
Definition at line 40 of file infer_ioptions.h.
◆ OPTION_TIMEOUT
Definition at line 43 of file infer_ioptions.h.
◆ OPTION_TIMESTAMP
Definition at line 52 of file infer_ioptions.h.
