7.1 Release
infer_preprocess_kernel.h File Reference
Data Structures
struct  BatchSurfaceInfo
Macros
#define NVDSINFER_MAX_PREPROC_CHANNELS   4
 Header file for pre-processing CUDA kernels with normalization and mean subtraction required by nvdsinferserver. More...
#define NVDSINFER_INVALID_CONVERSION_KEY   UINT32_MAX
Typedefs
typedef void(* NvDsInferConvertFcn) (void *outBuffer, int outDataType, BatchSurfaceInfo outBufferInfo, void *inBuffer, int inDatatype, BatchSurfaceInfo inBufferInfo, int validN, int cropC, int cropH, int cropW, float scaleFactor, float *meanDataBuffer, int fromChannelIndices[NVDSINFER_MAX_PREPROC_CHANNELS], int toNCHW, cudaStream_t stream)
 Function pointer type to which any of the NvDsInferConvert functions can be assigned. More...
Functions
bool NvDsInferConvert_CxToPx (void *outBuffer, int outDataType, BatchSurfaceInfo outBufferInfo, void *inBuffer, int inDatatype, BatchSurfaceInfo inBufferInfo, int validN, int cropC, int cropH, int cropW, float scaleFactor, float meanOffsets[NVDSINFER_MAX_PREPROC_CHANNELS], int fromChannelIndices[NVDSINFER_MAX_PREPROC_CHANNELS], int toNCHW, cudaStream_t stream)
bool NvDsInferConvert_CxToPxWithMeanBuffer (void *outBuffer, int outDataType, BatchSurfaceInfo outBufferInfo, void *inBuffer, int inDatatype, BatchSurfaceInfo inBufferInfo, int validN, int cropC, int cropH, int cropW, float scaleFactor, float *meanDataBuffer, int fromChannelIndices[NVDSINFER_MAX_PREPROC_CHANNELS], int toNCHW, cudaStream_t stream)
◆ NVDSINFER_INVALID_CONVERSION_KEY
Definition at line 25 of file infer_preprocess_kernel.h.
◆ NVDSINFER_MAX_PREPROC_CHANNELS
Definition at line 24 of file infer_preprocess_kernel.h.
Typedef Documentation
◆ NvDsInferConvertFcn
Definition at line 57 of file infer_preprocess_kernel.h.
Function Documentation
◆ NvDsInferConvert_CxToPx()
bool NvDsInferConvert_CxToPx ( void *  outBuffer,
int  outDataType,
void *  inBuffer,
int  inDatatype,
int  validN,
int  cropC,
int  cropH,
int  cropW,
float  scaleFactor,
int  toNCHW,
cudaStream_t  stream
◆ NvDsInferConvert_CxToPxWithMeanBuffer()
bool NvDsInferConvert_CxToPxWithMeanBuffer ( void *  outBuffer,
int  outDataType,
void *  inBuffer,
int  inDatatype,
int  validN,
int  cropC,
int  cropH,
int  cropW,
float  scaleFactor,
float *  meanDataBuffer,
int  toNCHW,
cudaStream_t  stream
