7.1 Release
libs/gstnvdscustomhelper/gst-nvdscustomevent.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2022-2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
33 #ifndef __GST_NVDSCUSTOMEVENT_H__
34 #define __GST_NVDSCUSTOMEVENT_H__
35
36 #include <gst/gst.h>
37
38 #ifdef __cplusplus
39 extern "C"
40 {
41 #endif
42
43
45  typedef struct RoiDimension
46  {
47  gchar roi_id[128];
48  guint left;
49  guint top;
50  guint width;
51  guint height;
52  } RoiDimension;
53
54 #define FLAG(name) GST_EVENT_TYPE_##name
55
57  typedef enum
58  {
62  = GST_EVENT_MAKE_TYPE (406, FLAG (DOWNSTREAM) | FLAG (SERIALIZED)),
66  = GST_EVENT_MAKE_TYPE (407, FLAG (DOWNSTREAM) | FLAG (SERIALIZED)),
70  = GST_EVENT_MAKE_TYPE (408, FLAG (DOWNSTREAM) | FLAG (SERIALIZED))
72 #undef FLAG
73
81  GstEvent *gst_nvevent_new_roi_update (gchar * stream_id, guint roi_count,
82  RoiDimension * roi_dim);
83
96  void gst_nvevent_parse_roi_update (GstEvent * event, gchar ** stream_id,
97  guint * roi_count, RoiDimension ** roi_dim);
98
105  GstEvent *gst_nvevent_infer_interval_update (gchar * stream_id,
106  guint interval);
107
118  void gst_nvevent_parse_infer_interval_update (GstEvent * event,
119  gchar ** stream_id, guint * interval);
120
121
128  GstEvent *gst_nvevent_osd_process_mode_update (gchar * stream_id,
129  guint process_mode);
130
141  void gst_nvevent_parse_osd_process_mode_update (GstEvent * event,
142  gchar ** stream_id, guint * process_mode);
143
144 #ifdef __cplusplus
145 }
146 #endif
147
148 #endif
149
RoiDimension::roi_id
gchar roi_id[128]
Definition: libs/gstnvdscustomhelper/gst-nvdscustomevent.h:47
RoiDimension
Defines Roi structure for GST_NVCUSTOMEVENT_ROI_UPDATE custom event.
Definition: libs/gstnvdscustomhelper/gst-nvdscustomevent.h:45
void gst_nvevent_parse_infer_interval_update(GstEvent *event, gchar **stream_id, guint *interval)
Parses a "nv-infer-interval-update" event received on the sinkpad.
RoiDimension::height
guint height
Definition: libs/gstnvdscustomhelper/gst-nvdscustomevent.h:51
GstEvent * gst_nvevent_new_roi_update(gchar *stream_id, guint roi_count, RoiDimension *roi_dim)
Creates a new "roi-update" event.
RoiDimension::left
guint left
Definition: libs/gstnvdscustomhelper/gst-nvdscustomevent.h:48
void gst_nvevent_parse_osd_process_mode_update(GstEvent *event, gchar **stream_id, guint *process_mode)
Parses a "nv-osd-process-mode-update" event received on the sinkpad.
RoiDimension::width
guint width
Definition: libs/gstnvdscustomhelper/gst-nvdscustomevent.h:50
GST_NVEVENT_OSD_PROCESS_MODE_UPDATE
@ GST_NVEVENT_OSD_PROCESS_MODE_UPDATE
Specifies a custom event to indicate osd process mode update of a particular stream in a batch.
Definition: libs/gstnvdscustomhelper/gst-nvdscustomevent.h:69
GST_NVEVENT_ROI_UPDATE
@ GST_NVEVENT_ROI_UPDATE
Specifies a custom event to indicate ROI update for preprocess of a particular stream in a batch.
Definition: libs/gstnvdscustomhelper/gst-nvdscustomevent.h:61
GstNvDsCustomEventType
Defines supported types of custom events.
Definition: libs/gstnvdscustomhelper/gst-nvdscustomevent.h:57
RoiDimension::top
guint top
Definition: libs/gstnvdscustomhelper/gst-nvdscustomevent.h:49
FLAG
#define FLAG(name)
Definition: libs/gstnvdscustomhelper/gst-nvdscustomevent.h:54
GstEvent * gst_nvevent_osd_process_mode_update(gchar *stream_id, guint process_mode)
Creates a new "nv-osd-process-mode-update" event.
GstEvent * gst_nvevent_infer_interval_update(gchar *stream_id, guint interval)
Creates a new "nv-infer-interval-update" event.
RoiDimension
struct RoiDimension RoiDimension
void gst_nvevent_parse_roi_update(GstEvent *event, gchar **stream_id, guint *roi_count, RoiDimension **roi_dim)
Parses a "roi-update" event received on the sinkpad.
GST_NVEVENT_INFER_INTERVAL_UPDATE
@ GST_NVEVENT_INFER_INTERVAL_UPDATE
Specifies a custom event to indicate infer interval update of a particular stream in a batch.
Definition: libs/gstnvdscustomhelper/gst-nvdscustomevent.h:65
