7.1 Release
nvds_latency_meta_internal.h File Reference
Macros
#define nvds_enable_component_latency_measurement   (nvds_get_enable_per_component_latency_measurement())
Functions
void * nvds_set_latency_metadata_ptr (void)
gpointer nvds_copy_latency_meta (gpointer data, gpointer user_data)
void nvds_release_latency_meta (gpointer data, gpointer user_data)
gdouble nvds_get_current_system_timestamp (void)
gboolean nvds_get_enable_per_component_latency_measurement (void)
◆ nvds_enable_component_latency_measurement
Definition at line 32 of file nvds_latency_meta_internal.h.
Function Documentation
◆ nvds_copy_latency_meta()
gpointer nvds_copy_latency_meta ( gpointer  data,
gpointer  user_data
◆ nvds_get_current_system_timestamp()
gdouble nvds_get_current_system_timestamp ( void  )
◆ nvds_get_enable_per_component_latency_measurement()
gboolean nvds_get_enable_per_component_latency_measurement ( void  )
◆ nvds_release_latency_meta()
void nvds_release_latency_meta ( gpointer  data,
gpointer  user_data
◆ nvds_set_latency_metadata_ptr()
void* nvds_set_latency_metadata_ptr ( void  )
