7.1 Release
GstBufferWrapper Class Reference
Definition at line 45 of file gstnvstreammux_impl.h.
Inheritance diagram for GstBufferWrapper:
Collaboration diagram for GstBufferWrapper:
Public Member Functions
 GstBufferWrapper (void *buffer, ENTRY_TYPE et, BATCH_SEQUENCE_TYPE bt, GstClockTime a_ntp_ts, GstClockTime a_buf_pts, GstClockTime a_duration, unsigned int id=0)
 ~GstBufferWrapper ()
void * unwrap ()
void free ()
void SetAudioParams (NvBufAudioParams aAudioParams)
void SetMemTypeNVMM (bool isNVMM)
bool IsMemTypeNVMM ()
Data Fields
NvBufAudioParams audioParams
GstClockTime ntp_ts
GstClockTime buf_pts
GstClockTime duration
unsigned int stream_id
gdouble buffer_wrapper_creation_time
bool is_nvmm
void * raw
uint32_t rawSize
uint64_t timestamp
void * wrapped
BATCH_SEQUENCE_TYPE batch_type
ENTRY_TYPE type
◆ GstBufferWrapper()
GstBufferWrapper::GstBufferWrapper ( void *  buffer,
ENTRY_TYPE  et,
unsigned int  id = 0
inline
TODO: Raise an exception if raw is nullptr; no_throw shall work whoever creates an object of GstBufferWrapper
Definition at line 49 of file gstnvstreammux_impl.h.
References buf_pts, buffer_wrapper_creation_time, duration, is_nvmm, LOGD, ntp_ts, nvds_enable_latency_measurement, nvds_get_current_system_timestamp(), stream_id, unwrap(), and QueueEntry::wrapped.
◆ ~GstBufferWrapper()
GstBufferWrapper::~GstBufferWrapper ( )
inline
Definition at line 67 of file gstnvstreammux_impl.h.
References free().
Member Function Documentation
◆ free()
void GstBufferWrapper::free ( )
inlinevirtual
Implements BufferWrapper.
Definition at line 88 of file gstnvstreammux_impl.h.
References LOGD, BufferWrapper::raw, and QueueEntry::wrapped.
Referenced by ~GstBufferWrapper().
◆ IsMemTypeNVMM()
bool GstBufferWrapper::IsMemTypeNVMM ( )
inline
Definition at line 104 of file gstnvstreammux_impl.h.
References is_nvmm.
◆ SetAudioParams()
void GstBufferWrapper::SetAudioParams ( NvBufAudioParams  aAudioParams)
inline
Definition at line 94 of file gstnvstreammux_impl.h.
References audioParams.
◆ SetMemTypeNVMM()
void GstBufferWrapper::SetMemTypeNVMM ( bool  isNVMM)
inline
Definition at line 99 of file gstnvstreammux_impl.h.
References is_nvmm.
◆ unwrap()
void* GstBufferWrapper::unwrap ( )
inline
Definition at line 72 of file gstnvstreammux_impl.h.
References BufferWrapper::raw, BufferWrapper::rawSize, and QueueEntry::wrapped.
Referenced by GstBufferWrapper().
Field Documentation
◆ audioParams
NvBufAudioParams GstBufferWrapper::audioParams
Definition at line 109 of file gstnvstreammux_impl.h.
Referenced by SetAudioParams().
◆ batch_type
BATCH_SEQUENCE_TYPE QueueEntry::batch_type
inherited
Definition at line 85 of file nvstreammux_pads.h.
◆ buf_pts
GstClockTime GstBufferWrapper::buf_pts
Definition at line 112 of file gstnvstreammux_impl.h.
◆ buffer_wrapper_creation_time
gdouble GstBufferWrapper::buffer_wrapper_creation_time
Definition at line 115 of file gstnvstreammux_impl.h.
◆ duration
GstClockTime GstBufferWrapper::duration
Definition at line 113 of file gstnvstreammux_impl.h.
◆ is_nvmm
bool GstBufferWrapper::is_nvmm
Definition at line 116 of file gstnvstreammux_impl.h.
Referenced by GstBufferWrapper(), IsMemTypeNVMM(), and SetMemTypeNVMM().
◆ ntp_ts
GstClockTime GstBufferWrapper::ntp_ts
Definition at line 111 of file gstnvstreammux_impl.h.
◆ raw
void* BufferWrapper::raw
inherited
Definition at line 103 of file nvstreammux_pads.h.
Referenced by BufferWrapper::BufferWrapper(), free(), and unwrap().
◆ rawSize
uint32_t BufferWrapper::rawSize
inherited
Definition at line 104 of file nvstreammux_pads.h.
Referenced by unwrap().
◆ stream_id
unsigned int GstBufferWrapper::stream_id
Definition at line 114 of file gstnvstreammux_impl.h.
◆ timestamp
uint64_t BufferWrapper::timestamp
inherited
Definition at line 109 of file nvstreammux_pads.h.
Referenced by BufferWrapper::BufferWrapper().
◆ type
ENTRY_TYPE QueueEntry::type
inherited
◆ wrapped
void* QueueEntry::wrapped
inherited
Definition at line 84 of file nvstreammux_pads.h.
Referenced by free(), GstBufferWrapper(), and unwrap().
