NVIDIA DeepStream mask utils API
Description: This file specifies the APIs used to transform mask buffers
Definition in file nvds_mask_utils.h.
Functions | |
| bool | nvds_mask_utils_resize_to_binary_argb32 (float *src, uint32_t *dst, uint32_t src_width, uint32_t src_height, uint32_t dst_width, uint32_t dst_height, uint32_t channel, float threshold, uint32_t argb32_px, uint32_t interpolation, cudaStream_t stream) |
| resize FP32 Tensor and apply threshold to create INT32 binary tensor Output INT32 tensor pixels are assumed ARGB32 For resized pixels > threshold, transparency is set to 50% and other pixels are set to 100% transparent; RGB = 0 for all pixels More... | |
| bool nvds_mask_utils_resize_to_binary_argb32 | ( | float * | src, |
| uint32_t * | dst, | ||
| uint32_t | src_width, | ||
| uint32_t | src_height, | ||
| uint32_t | dst_width, | ||
| uint32_t | dst_height, | ||
| uint32_t | channel, | ||
| float | threshold, | ||
| uint32_t | argb32_px, | ||
| uint32_t | interpolation, | ||
| cudaStream_t | stream | ||
| src | [IN/OUT] source FP32 tensor |
| dst | [IN/OUT] dst INT32 (ARGB32) tensor |
| src_width | [IN] source FP32 tensor width |
| src_height | [IN] source FP32 tensor height |
| dst_width | [IN] dst INT32 (ARGB32) tensor width |
| dst_height | [IN] dst INT32 (ARGB32) tensor height |
| channel | [IN] |
| threshold | [IN] |
| argb_32 | [IN] The pixel value in dst when src pixel > threshold |
| interpolation | [IN] The NPP interpolation method to use Enumeration copied below: NPPI_INTER_NN =1, Nearest neighbor filtering. NPPI_INTER_LINEAR Linear interpolation. NPPI_INTER_CUBIC Cubic interpolation. NPPI_INTER_CUBIC2P_BSPLINE Two-parameter cubic filter (B=1, C=0) NPPI_INTER_CUBIC2P_CATMULLROM Two-parameter cubic filter (B=0, C=1/2) NPPI_INTER_CUBIC2P_B05C03 Two-parameter cubic filter (B=1/2, C=3/10) NPPI_INTER_SUPER Super sampling. NPPI_INTER_LANCZOS Lanczos filtering. NPPI_INTER_LANCZOS3_ADVANCED Generic Lanczos filtering with order 3. NPPI_SMOOTH_EDGE Smooth edge filtering. |
| stream | [IN] The cuda-stream to use for scaling operation on GPU |
