8.0 Release
28 #ifndef _NVGSTDS_YAML_PARSER_H_
29 #define _NVGSTDS_YAML_PARSER_H_
NvDsYamlParserStatus nvds_parse_nvv4l2h265enc(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvv4l2h265enc element from values specified in a YAML configuration file.
struct NvDsYamlCodecStatus NvDsYamlCodecStatus
Enum for codec type for the API call on a encoder.
NvDsYamlParserStatus nvds_parse_rtsp_source(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a rtspsrc element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_egl_sink(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nveglglessink element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_tracker(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvtracker element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_tiler(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvtiler element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_nvxfer_position(gchar *cfg_file_path, const char *group, guint *position)
Parses nvdsxfer plugin position values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_alsasrc(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a alsasrc element from values specified in a YAML configuration file.
gboolean enable
Enable status.
@ NVDS_GIE_PLUGIN_INFER_SERVER
Inference using nvinferserver GIE.
NvDsYamlParserStatus nvds_parse_codec_status(gchar *cfg_file_path, const char *group, NvDsYamlCodecStatus *codec_status)
Parses codec type and enable status values specified in a YAML configuration file.
gboolean check_enable_status(gchar *cfg_file_path, const char *group)
Function definition to check if the rest server is enabled in the YAML config file.
NvDsYamlParserStatus nvds_parse_nvv4l2h264enc(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvv4l2h264enc element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_osd(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvdsosd element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_msgconv(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvmsgconv element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_fake_sink(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a fakesink element from values specified in a YAML configuration file.
@ NVDS_YAML_PARSER_SUCCESS
Properties were set correctly.
NvDsYamlParserStatus nvds_parse_msgbroker(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvmsgbroker element from values specified in a YAML configuration file.
NvDsGieType
Enum for specifying the inference plugin type.
NvDsYamlParserStatus nvds_parse_gie(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvinfer element from values specified in a YAML configuration file.
Enum for Yaml parsing status for the API call on a GstElement.
NvDsYamlParserStatus nvds_parse_uridecodebin(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a uridecodebin element from values specified in a YAML configuration file.
@ NVDS_YAML_PARSER_DISABLED
Property group was disabled, properties were not set.
NvDsYamlParserStatus nvds_parse_nvdsanalytics(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvdsanalytics element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_file_sink(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a filesink element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_multiurisrcbin(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvmultiurisrcbin element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_nvarguscamerasrc(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvarguscamerasrc element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_gie_type(NvDsGieType *gie_type, gchar *cfg_file_path, const char *group)
Get the GIE type, nvinfer or invinferserver, from the YAML configuration file.
NvDsYamlParserStatus nvds_parse_file_source(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a filesrc element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_nvxfer(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvdsxfer element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_source_list(GList **src_list, gchar *cfg_file_path, const char *group)
Parse semicolon separated uri(s) in the source-list group and store it in a GList.
NvDsYamlParserStatus nvds_parse_streammux(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nvstreammux element from values specified in a YAML configuration file.
@ NVDS_YAML_PARSER_ERROR
Encountered an error while setting properties.
NvDsYamlParserStatus nvds_parse_v4l2src(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a v4l2src element from values specified in a YAML configuration file.
NvDsYamlParserStatus nvds_parse_multifilesrc(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a multifilesrc element from values specified in a YAML configuration file.
guint codec_type
Type codec=1 h264, codec=2 h265.
NvDsYamlParserStatus nvds_parse_3d_sink(GstElement *element, gchar *cfg_file_path, const char *group)
Set properties of a nv3dsink element from values specified in a YAML configuration file.
Inference using nvinfer GIE.
