7.1 Release
sequence_preprocess_kernel.h File Reference
Data Structures
struct  Float4Vec
Macros
#define VEC4_SIZE   4
Functions
cudaError_t preprocessNCDHW (void *outPtr, unsigned int outC, unsigned int H, unsigned int W, unsigned int S, const void *inPtr, unsigned int inC, unsigned int inRowPitch, Float4Vec scales, Float4Vec means, bool swapRB, cudaStream_t stream)
 NCDHW preprocess per ROI image. More...
◆ VEC4_SIZE
#define VEC4_SIZE   4
Definition at line 19 of file sequence_preprocess_kernel.h.
Function Documentation
◆ preprocessNCDHW()
cudaError_t preprocessNCDHW ( void *  outPtr,
unsigned int  outC,
unsigned int  H,
unsigned int  W,
unsigned int  S,
const void *  inPtr,
unsigned int  inC,
Float4Vec  scales,
Float4Vec  means,
bool  swapRB,
cudaStream_t  stream
Parameters
outPtroutput data pointer offset to current image position
inPtrinput data pointer
