sources/apps/apps-common/includes/deepstream_secondary_preprocess.h File Reference
Data Structures
struct  NvDsSecondaryPreProcessBinSubBin
Functions
gboolean create_secondary_preprocess_bin (guint num_secondary_preprocess, guint primary_gie_unique_id, NvDsPreProcessConfig *config_array, NvDsSecondaryPreProcessBin *bin)
 Initialize NvDsSecondaryPreProcessBin. More...
void destroy_secondary_preprocess_bin (NvDsSecondaryPreProcessBin *bin)
 Release the resources. More...
Function Documentation
◆ create_secondary_preprocess_bin()
gboolean create_secondary_preprocess_bin ( guint  num_secondary_preprocess,
NvDsPreProcessConfig config_array,
NvDsSecondaryPreProcessBin bin
It creates and adds secondary preprocess and other elements needed for processing to the bin. It also sets properties mentioned in the configuration file under group CONFIG_GROUP_SECONDARY_PREPROCESS
Parameters
[in]num_secondary_gienumber of secondary preprocess.
[in]config_arrayarray of pointers of type NvDsPreProcessConfig parsed from configuration file.
[in]binpointer to NvDsSecondaryPreProcessBin to be filled.
Returns
true if bin created successfully.
◆ destroy_secondary_preprocess_bin()
void destroy_secondary_preprocess_bin ( NvDsSecondaryPreProcessBin bin)
