| gboolean | create_pipeline (AppCtx *appCtx, bbox_generated_callback bbox_generated_post_analytics_cb, bbox_generated_callback all_bbox_generated_cb, perf_callback perf_cb, overlay_graphics_callback overlay_graphics_cb) |
| | Create DS Anyalytics Pipeline per the appCtx configurations. More...
| gboolean | pause_pipeline (AppCtx *appCtx) |
| gboolean | resume_pipeline (AppCtx *appCtx) |
| gboolean | seek_pipeline (AppCtx *appCtx, glong milliseconds, gboolean seek_is_relative) |
| void | toggle_show_bbox_text (AppCtx *appCtx) |
| void | destroy_pipeline (AppCtx *appCtx) |
| void | restart_pipeline (AppCtx *appCtx) |
| gboolean | parse_config_file (NvDsConfig *config, gchar *cfg_file_path) |
| | Function to read properties from configuration file. More...
| gboolean | parse_config_file_yaml (NvDsConfig *config, gchar *cfg_file_path) |
| | Function to read properties from YML configuration file. More...
| gboolean | msgapi_init_early (AppCtx *appCtx, const gchar *cfg_file_path) |
| | Generic msgapi helper functions for error propagation These work with ANY DeepStream app (test1-5, custom apps, etc.) More...
| void | msgapi_report_error_and_cleanup (AppCtx *appCtx, const gchar *error_message) |
| | msgapi_report_error_and_cleanup: Generic error reporting function called before application exit. More...
| NvDsSensorInfo * | get_sensor_info (AppCtx *appCtx, guint source_id) |
| | Function to procure the NvDsSensorInfo for the source_id that was added using the nvmultiurisrcbin REST API. More...
◆ AppCtx
◆ bbox_generated_callback
◆ overlay_graphics_callback
◆ create_pipeline()
- Parameters
| appCtx | [IN/OUT] The application context providing the config info and where the pipeline resources are maintained |
| bbox_generated_post_analytics_cb | [IN] This callback shall be triggered after analytics (PGIE, Tracker or the last SGIE appearing in the pipeline) More info: create_common_elements() |
| all_bbox_generated_cb | [IN] |
| perf_cb | [IN] |
| overlay_graphics_cb | [IN] |
◆ destroy_pipeline()
| void destroy_pipeline |
AppCtx * |
appCtx | ) |
◆ get_sensor_info()
- Parameters
| [in] | appCtx | [IN/OUT] The application context providing the config info and where the pipeline resources are maintained |
| [in] | source_id | [IN] The unique source_id found in NvDsFrameMeta |
- Returns
- [transfer-floating] The NvDsSensorInfo for the source_id that was added using the nvmultiurisrcbin REST API. Please note that the returned pointer will be valid only until the stream is removed.
◆ msgapi_init_early()
| gboolean msgapi_init_early |
AppCtx * |
appCtx, |
const gchar * |
cfg_file_path |
msgapi_init_early: Pre-parse msgapi settings and initialize msgapi BEFORE full config parsing. This enables error reporting even if config parsing fails.
- Parameters
| [in] | appCtx | Application context |
| [in] | cfg_file_path | Configuration file path |
- Returns
- TRUE if msgapi initialized successfully, FALSE otherwise
◆ msgapi_report_error_and_cleanup()
| void msgapi_report_error_and_cleanup |
AppCtx * |
appCtx, |
const gchar * |
error_message |
Sends error to message broker (if initialized) and cleans up resources. Call this from the done: label when return_value == -1
- Parameters
| [in] | error_message | Error description (or NULL for generic message) |
◆ parse_config_file()
| gboolean parse_config_file |
NvDsConfig * |
config, |
gchar * |
cfg_file_path |
- Parameters
| [in] | config | pointer to NvDsConfig |
| [in] | cfg_file_path | path of configuration file. |
- Returns
- true if parsed successfully.
◆ parse_config_file_yaml()
| gboolean parse_config_file_yaml |
NvDsConfig * |
config, |
gchar * |
cfg_file_path |
- Parameters
- Returns
◆ pause_pipeline()
| gboolean pause_pipeline |
AppCtx * |
appCtx | ) |
◆ restart_pipeline()
| void restart_pipeline |
AppCtx * |
appCtx | ) |
◆ resume_pipeline()
| gboolean resume_pipeline |
AppCtx * |
appCtx | ) |
◆ seek_pipeline()
| gboolean seek_pipeline |
AppCtx * |
appCtx, |
glong |
milliseconds, |
gboolean |
seek_is_relative |
◆ toggle_show_bbox_text()
| void toggle_show_bbox_text |
AppCtx * |
appCtx | ) |
