Data Structures | |
| struct | NvDsInstanceBin |
| struct | NvDsPipeline |
| struct | NvDsConfig |
| struct | _AppCtx |
| struct | StreamSourceInfo |
| struct | TestAppCtx |
Typedefs | |
| typedef struct _AppCtx | AppCtx |
| typedef void(* | bbox_generated_callback) (AppCtx *appCtx, GstBuffer *buf, NvDsBatchMeta *batch_meta, guint index) |
Functions | |
| gboolean | create_pipeline (AppCtx *appCtx, perf_callback perf_cb, bbox_generated_callback bgpa_cb) |
| Create DS Anyalytics Pipeline per the appCtx configurations. More... | |
| gboolean | pause_pipeline (AppCtx *appCtx) |
| gboolean | resume_pipeline (AppCtx *appCtx) |
| gboolean | seek_pipeline (AppCtx *appCtx, glong milliseconds, gboolean seek_is_relative) |
| void | destroy_pipeline (AppCtx *appCtx) |
| void | restart_pipeline (AppCtx *appCtx) |
| gboolean | parse_config_file (NvDsConfig *config, gchar *cfg_file_path) |
| Function to read properties from configuration file. More... | |
Definition at line 34 of file sources/apps/sample_apps/deepstream-audio/deepstream_audio.h.
| typedef void(* bbox_generated_callback) (AppCtx *appCtx, GstBuffer *buf, NvDsBatchMeta *batch_meta, guint index) |
Definition at line 36 of file sources/apps/sample_apps/deepstream-audio/deepstream_audio.h.
| gboolean create_pipeline | ( | AppCtx * | appCtx, |
| perf_callback | perf_cb, | ||
| bbox_generated_callback | bgpa_cb | ||
| appCtx | [IN/OUT] The application context providing the config info and where the pipeline resources are maintained |
| perf_cb | [IN] |
| void destroy_pipeline | ( | AppCtx * | appCtx | ) |
| gboolean parse_config_file | ( | NvDsConfig * | config, |
| gchar * | cfg_file_path | ||
| [in] | config | pointer to NvDsConfig |
| [in] | cfg_file_path | path of configuration file. |
| gboolean pause_pipeline | ( | AppCtx * | appCtx | ) |
| void restart_pipeline | ( | AppCtx * | appCtx | ) |
| gboolean resume_pipeline | ( | AppCtx * | appCtx | ) |
| gboolean seek_pipeline | ( | AppCtx * | appCtx, |
| glong | milliseconds, | ||
| gboolean | seek_is_relative | ||
