sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess_allocator.h File Reference
Data Structures
struct  GstNvDsPreProcessMemory
 This file describes the custom memory allocator for the Gstreamer TensorRT plugin. More...
struct  GstNvDsPreProcessVideoBufferAllocatorInfo
 structure containing video buffer allocator info More...
Functions
GstNvDsPreProcessMemorygst_nvdspreprocess_buffer_get_memory (GstBuffer *buffer)
 Get GstNvDsPreProcessMemory structure associated with buffer allocated using GstNvDsPreProcessAllocator. More...
GstAllocator * gst_nvdspreprocess_allocator_new (GstNvDsPreProcessVideoBufferAllocatorInfo *info, size_t raw_buf_size, guint gpu_id, gboolean debug_tensor)
 Create a new GstNvDsPreProcessAllocator with the given parameters. More...
Function Documentation
◆ gst_nvdspreprocess_allocator_new()
GstAllocator* gst_nvdspreprocess_allocator_new ( GstNvDsPreProcessVideoBufferAllocatorInfo info,
guint  gpu_id,
Parameters
infovideo buffer allocator info.
raw_buf_sizesize of raw buffer to allocate.
gpu_idID of the gpu where the batch memory will be allocated.
debug_tensorboolean to denote if DEBUG_TENSOR flag is enabled.
Returns
Pointer to the GstNvDsPreProcessAllocator structure cast as GstAllocator
◆ gst_nvdspreprocess_buffer_get_memory()
GstNvDsPreProcessMemory* gst_nvdspreprocess_buffer_get_memory ( GstBuffer buffer)
Parameters
bufferGstBuffer allocated by this allocator.
Returns
Pointer to the associated GstNvDsPreProcessMemory structure
