sources/gst-plugins/gst-nvmultistream2/gstnvstreammux.h File Reference
Data Structures
struct  _GstNvStreamMux
struct  _GstNvStreamMuxClass
Macros
#define GST_TYPE_NVSTREAMMUX   (gst_nvstreammux_2_get_type ())
#define GST_NVSTREAMMUX(obj)   (G_TYPE_CHECK_INSTANCE_CAST((obj),GST_TYPE_NVSTREAMMUX,GstNvStreamMux))
#define GST_NVSTREAMMUX_CLASS(klass)   (G_TYPE_CHECK_CLASS_CAST((klass),GST_TYPE_NVSTREAMMUX,GstNvStreamMuxClass))
#define GST_IS_NVSTREAMMUX(obj)   (G_TYPE_CHECK_INSTANCE_TYPE((obj),GST_TYPE_NVSTREAMMUX))
#define GST_IS_NVSTREAMMUX_CLASS(klass)   (G_TYPE_CHECK_CLASS_TYPE((klass),GST_TYPE_NVSTREAMMUX))
#define NEW_METADATA   1
Typedefs
typedef struct _GstNvStreamMux GstNvStreamMux
typedef struct _GstNvStreamMuxClass GstNvStreamMuxClass
Functions
G_GNUC_INTERNAL GType gst_nvstreammux_2_get_type (void)
◆ GST_IS_NVSTREAMMUX
#define GST_IS_NVSTREAMMUX (   obj)    (G_TYPE_CHECK_INSTANCE_TYPE((obj),GST_TYPE_NVSTREAMMUX))
◆ GST_IS_NVSTREAMMUX_CLASS
#define GST_IS_NVSTREAMMUX_CLASS (   klass)    (G_TYPE_CHECK_CLASS_TYPE((klass),GST_TYPE_NVSTREAMMUX))
◆ GST_NVSTREAMMUX
#define GST_NVSTREAMMUX (   obj)    (G_TYPE_CHECK_INSTANCE_CAST((obj),GST_TYPE_NVSTREAMMUX,GstNvStreamMux))
◆ GST_NVSTREAMMUX_CLASS
#define GST_NVSTREAMMUX_CLASS (   klass)    (G_TYPE_CHECK_CLASS_CAST((klass),GST_TYPE_NVSTREAMMUX,GstNvStreamMuxClass))
◆ GST_TYPE_NVSTREAMMUX
◆ NEW_METADATA
Typedef Documentation
◆ GstNvStreamMux
◆ GstNvStreamMuxClass
Function Documentation
◆ gst_nvstreammux_2_get_type()
G_GNUC_INTERNAL GType gst_nvstreammux_2_get_type ( void  )
