sources/gst-plugins/gst-nvmultistream2/gstnvtimesynch.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2021-2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
13 #ifndef __GST_NVTIMESYNC_H__
14 #define __GST_NVTIMESYNC_H__
15
16 #include <gst/gst.h>
17 #include "nvstreammux.h"
18 #include "nvstreammux_batch.h"
19 #include "nvstreammux_pads.h"
20 #include <unordered_map>
21 #include <mutex>
22
24 {
25
26  public:
27  NvTimeSync(GstElement* el)
28  : plugin(el), pipelineLatency(0), upstreamLatency(0),
29  minFpsDuration(0),
30  segments(), mutex()
31  {}
32
33
35  void removing_old_buffer(BufferWrapper* buffer);
36
49  void SetPipelineLatency(GstClockTime latency);
50
55  void SetUpstreamLatency(GstClockTime latency);
56
57  GstClockTime GetUpstreamLatency();
58
59  GstClockTime GetCurrentRunningTime();
60
61  void SetSegment(unsigned int stream_id, const GstSegment* segment);
62
64
66
67
68  uint64_t GetBufferRunningTime(uint64_t pts, unsigned int stream_id);
69
70  private:
71  GstElement* plugin;
72  GstClockTime pipelineLatency;
73  GstClockTime upstreamLatency;
74  GstClockTime minFpsDuration;
75  GstClockTime bufferWasEarlyByTime;
76  std::unordered_map<unsigned int, GstSegment*> segments;
77  std::mutex mutex;
78 };
79
80
81 #endif
NvTimeSync::GetCurrentRunningTime
NvTimeSync::get_buffer_earlyby_time
NanoSecondsType get_buffer_earlyby_time()
NvTimeSync::NvTimeSync
NvTimeSync(GstElement *el)
Definition: sources/gst-plugins/gst-nvmultistream2/gstnvtimesynch.h:27
BufferWrapper
Definition: sources/libs/nvstreammux/include/nvstreammux_pads.h:92
BUFFER_TS_STATUS
BUFFER_TS_STATUS
Definition: sources/libs/nvstreammux/include/nvstreammux_pads.h:66
NvTimeSync::GetUpstreamLatency
NvTimeSync::removing_old_buffer
void removing_old_buffer(BufferWrapper *buffer)
NvTimeSync::get_synch_info
BUFFER_TS_STATUS get_synch_info(BufferWrapper *buffer)
NvTimeSync::SetOperatingMinFpsDuration
void SetOperatingMinFpsDuration(NanoSecondsType min_fps_dur)
NanoSecondsType
std::chrono::duration< double, std::nano > NanoSecondsType
Definition: sources/libs/nvstreammux/include/nvstreammux_pads.h:22
NvTimeSync::SetSegment
void SetSegment(unsigned int stream_id, const GstSegment *segment)
NvTimeSync::GetBufferRunningTime
NvTimeSync::SetPipelineLatency
Set the downstream latency Note: Currently the whole pipelineLatency value is used in timesynch logic...
NvTimeSync::SetUpstreamLatency
Set the upstream latency.
ISynchronizeBuffer
Definition: sources/libs/nvstreammux/include/nvstreammux_pads.h:342
NvTimeSync
Definition: sources/gst-plugins/gst-nvmultistream2/gstnvtimesynch.h:23
