8.0 Release
sources/libs/nvds_rest_server/nvds_rest_server.h File Reference
Data Structures
struct  NvDsServerErrorInfo
struct  NvDsServerDecInfo
struct  NvDsServerEncInfo
struct  NvDsServerConvInfo
struct  NvDsServerMuxInfo
struct  NvDsServerRoiInfo
struct  NvDsServerStreamInfo
struct  NvDsGetRequestInfo
struct  NvDsServerInferInfo
struct  NvDsServerOsdInfo
struct  NvDsServerAnalyticsInfo
struct  NvDsServerTextEmbeddingInfo
struct  NvDsServerAppInstanceInfo
struct  NvDsServerInferServerInfo
struct  NvDsServerNvTrackerInfo
struct  NvDsServerResponseInfo
struct  NvDsServerConfig
struct  NvDsServerCallbacks
Macros
#define UNKNOWN_STRING   "unknown"
#define EMPTY_STRING   ""
Typedefs
typedef struct NvDsServerErrorInfo NvDsServerErrorInfo
typedef struct NvDsServerDecInfo NvDsServerDecInfo
typedef struct NvDsServerEncInfo NvDsServerEncInfo
typedef struct NvDsServerConvInfo NvDsServerConvInfo
typedef struct NvDsServerMuxInfo NvDsServerMuxInfo
typedef struct NvDsServerRoiInfo NvDsServerRoiInfo
typedef struct NvDsServerStreamInfo NvDsServerStreamInfo
typedef struct NvDsGetRequestInfo NvDsServerGetRequestInfo
typedef struct NvDsServerInferInfo NvDsServerInferInfo
typedef struct NvDsServerOsdInfo NvDsServerOsdInfo
typedef struct NvDsServerAnalyticsInfo NvDsServerAnalyticsInfo
typedef struct NvDsServerTextEmbeddingInfo NvDsServerTextEmbeddingInfo
typedef struct NvDsServerAppInstanceInfo NvDsServerAppInstanceInfo
typedef struct NvDsServerInferServerInfo NvDsServerInferServerInfo
typedef struct NvDsServerNvTrackerInfo NvDsServerNvTrackerInfo
typedef struct NvDsServerResponseInfo NvDsServerResponseInfo
typedef struct NvDsServerConfig NvDsServerConfig
using cb_func = std::function< NvDsServerStatusCode(const Json::Value &req_info, const Json::Value &in, Json::Value &out, struct mg_connection *conn, void *ctx)>
typedef struct NvDsServerCallbacks NvDsServerCallbacks
Enumerations
enum  NvDsServerDecPropFlag {
  DROP_FRAME_INTERVAL = 1 << 0,
  SKIP_FRAMES = 1 << 1,
  LOW_LATENCY_MODE = 1 << 2,
enum  NvDsServerEncPropFlag {
  BITRATE = 1 << 0,
  FORCE_IDR = 1 << 1,
  FORCE_INTRA = 1 << 2,
  IFRAME_INTERVAL = 1 << 3,
  BITRATE = 1 << 0,
  FORCE_IDR = 1 << 1,
  BITRATE = 1 << 0,
  FORCE_IDR = 1 << 1,
  BITRATE = 1 << 0,
  FORCE_IDR = 1 << 1,
enum  NvDsServerConvPropFlag {
  SRC_CROP = 1 << 0,
  DEST_CROP = 1 << 1,
  FLIP_METHOD = 1 << 2,
  INTERPOLATION_METHOD = 1 << 3,
  SRC_CROP = 1 << 0,
  DEST_CROP = 1 << 1,
  SRC_CROP = 1 << 0,
  DEST_CROP = 1 << 1,
  SRC_CROP = 1 << 0,
  DEST_CROP = 1 << 1,
enum  NvDsServerMuxPropFlag {
  BATCHED_PUSH_TIMEOUT = 1 << 0,
  MAX_LATENCY = 1 << 1,
enum  NvDsServerInferPropFlag {
  INFER_INTERVAL = 1 << 0,
enum  NvDsServerInferServerPropFlag {
  INFERSERVER_INTERVAL = 1 << 0,
enum  NvDsServerNvTrackerPropFlag {
  NVTRACKER_CONFIG = 1 << 0,
enum  NvDsServerGetRequestPropFlag {
  GET_LIVE_STREAM_INFO = 1 << 0,
  GET_READY_INFO = 1 << 1,
  GET_LIVE_INFO = 1 << 2,
  GET_STARTUP_INFO = 1 << 3,
  GET_METRICS_INFO = 1 << 4,
  GET_METADATA_INFO = 1 << 5,
 Flags for GET request types supported by the REST server. More...
enum  NvDsServerOsdPropFlag {
  PROCESS_MODE = 1 << 0,
enum  NvDsServerAnalyticsPropFlag {
  RELOAD_CONFIG = 1 << 0,
enum  NvDsServerTextEmbeddingPropFlag {
  TEXT_EMBEDDING_GENERATE = 1 << 0,
enum  NvDsServerRoiPropFlag {
  ROI_UPDATE = 1 << 0,
  ROI_UPDATE = 1 << 0
enum  NvDsServerAppInstanceFlag {
  QUIT_APP = 1 << 0,
  QUIT_APP = 1 << 0,
  QUIT_APP = 1 << 0,
  QUIT_APP = 1 << 0
enum  NvDsServerAppInstanceStatus {
  QUIT_SUCCESS = 0,
  QUIT_FAIL,
  QUIT_SUCCESS = 0,
  QUIT_FAIL,
  QUIT_SUCCESS = 0,
  QUIT_FAIL,
  QUIT_SUCCESS = 0,
  QUIT_FAIL
enum  NvDsServerStreamStatus {
  STREAM_ADD_SUCCESS = 0,
  STREAM_ADD_FAIL,
  STREAM_REMOVE_SUCCESS,
  STREAM_REMOVE_FAIL,
  STREAM_ADD_FAIL,
  STREAM_REMOVE_FAIL,
  STREAM_ADD_FAIL,
  STREAM_REMOVE_FAIL,
  STREAM_ADD_FAIL,
  STREAM_REMOVE_FAIL
enum  NvDsServerGetRequestStatus {
  GET_LIVE_STREAM_INFO_SUCCESS = 0,
  GET_LIVE_STREAM_INFO_FAIL,
  GET_READY_INFO_SUCCESS,
  GET_READY_INFO_FAIL,
  GET_LIVE_INFO_SUCCESS,
  GET_LIVE_INFO_FAIL,
  GET_STARTUP_INFO_SUCCESS,
  GET_STARTUP_INFO_FAIL,
  GET_METRICS_INFO_SUCCESS,
  GET_METRICS_INFO_FAIL,
  GET_METADATA_INFO_SUCCESS,
  GET_METADATA_INFO_FAIL,
  GET_LIVE_INFO_FAIL,
  GET_LIVE_INFO_FAIL,
  GET_LIVE_INFO_FAIL,
enum  NvDsServerRoiStatus {
  ROI_UPDATE_SUCCESS = 0,
  ROI_UPDATE_FAIL,
  ROI_UPDATE_FAIL,
  ROI_UPDATE_FAIL,
  ROI_UPDATE_FAIL
enum  NvDsServerDecStatus {
  DROP_FRAME_INTERVAL_UPDATE_SUCCESS = 0,
  DROP_FRAME_INTERVAL_UPDATE_FAIL,
  SKIP_FRAMES_UPDATE_SUCCESS,
  SKIP_FRAMES_UPDATE_FAIL,
  LOW_LATENCY_MODE_UPDATE_SUCCESS,
  LOW_LATENCY_MODE_UPDATE_FAIL,
enum  NvDsServerEncStatus {
  BITRATE_UPDATE_SUCCESS = 0,
  BITRATE_UPDATE_FAIL,
  FORCE_IDR_UPDATE_SUCCESS,
  FORCE_IDR_UPDATE_FAIL,
  FORCE_INTRA_UPDATE_SUCCESS,
  FORCE_INTRA_UPDATE_FAIL,
  IFRAME_INTERVAL_UPDATE_SUCCESS,
  IFRAME_INTERVAL_UPDATE_FAIL,
enum  NvDsServerConvStatus {
  DEST_CROP_UPDATE_SUCCESS = 0,
  DEST_CROP_UPDATE_FAIL,
  SRC_CROP_UPDATE_SUCCESS,
  SRC_CROP_UPDATE_FAIL,
  INTERPOLATION_METHOD_UPDATE_SUCCESS,
  INTERPOLATION_METHOD_UPDATE_FAIL,
  FLIP_METHOD_UPDATE_SUCCESS,
  FLIP_METHOD_UPDATE_FAIL,
enum  NvDsServerMuxStatus {
  BATCHED_PUSH_TIMEOUT_UPDATE_SUCCESS = 0,
  BATCHED_PUSH_TIMEOUT_UPDATE_FAIL,
  MAX_LATENCY_UPDATE_SUCCESS,
  MAX_LATENCY_UPDATE_FAIL,
enum  NvDsServerInferStatus {
  INFER_INTERVAL_UPDATE_SUCCESS = 0,
  INFER_INTERVAL_UPDATE_FAIL,
enum  NvDsServerInferServerStatus {
  INFERSERVER_INTERVAL_UPDATE_SUCCESS = 0,
  INFERSERVER_INTERVAL_UPDATE_FAIL,
enum  NvDsServerNvTrackerStatus {
  NVTRACKER_CONFIG_UPDATE_SUCCESS = 0,
  NVTRACKER_CONFIG_UPDATE_FAIL,
enum  NvDsServerOsdStatus {
  PROCESS_MODE_UPDATE_SUCCESS = 0,
  PROCESS_MODE_UPDATE_FAIL,
enum  NvDsServerAnalyticsStatus {
  RELOAD_CONFIG_UPDATE_SUCCESS = 0,
  RELOAD_CONFIG_UPDATE_FAIL,
enum  NvDsServerTextEmbeddingStatus {
  TEXT_EMBEDDING_GENERATE_SUCCESS = 0,
  TEXT_EMBEDDING_GENERATE_FAIL,
enum  NvDsServerStatusCode {
  StatusOk = 0,
  StatusAccepted,
  StatusBadRequest,
  StatusUnauthorized,
  StatusForbidden,
  StatusMethodNotAllowed,
  StatusNotAcceptable,
  StatusProxyAuthenticationRequired,
  StatusRequestTimeout,
  StatusPreconditionFailed,
  StatusPayloadTooLarge,
  StatusUriTooLong,
  StatusUnsupportedMediaType,
  StatusInternalServerError,
  StatusNotImplemented,
  StatusOk = 0,
  StatusAccepted,
  StatusBadRequest,
  StatusUnauthorized,
  StatusForbidden,
  StatusUriTooLong,
  StatusOk = 0,
  StatusAccepted,
  StatusBadRequest,
  StatusUnauthorized,
  StatusForbidden,
  StatusUriTooLong,
  StatusOk = 0,
  StatusAccepted,
  StatusBadRequest,
  StatusUnauthorized,
  StatusForbidden,
  StatusUriTooLong,
Functions
NvDsRestServer * nvds_rest_server_start (NvDsServerConfig *server_config, NvDsServerCallbacks *server_cb, void *custom_ctx)
void nvds_rest_server_stop (NvDsRestServer *ctx)
bool iequals (const std::string &a, const std::string &b)
◆ EMPTY_STRING
◆ UNKNOWN_STRING
Typedef Documentation
◆ cb_func
using cb_func = std::function < NvDsServerStatusCode (const Json::Value & req_info, const Json::Value & in, Json::Value & out, struct mg_connection * conn, void *ctx)>
◆ NvDsServerAnalyticsInfo
◆ NvDsServerAppInstanceInfo
◆ NvDsServerCallbacks
◆ NvDsServerConfig
◆ NvDsServerConvInfo
◆ NvDsServerDecInfo
◆ NvDsServerEncInfo
◆ NvDsServerErrorInfo
◆ NvDsServerGetRequestInfo
◆ NvDsServerInferInfo
◆ NvDsServerInferServerInfo
◆ NvDsServerMuxInfo
◆ NvDsServerNvTrackerInfo
◆ NvDsServerOsdInfo
◆ NvDsServerResponseInfo
◆ NvDsServerRoiInfo
◆ NvDsServerStreamInfo
◆ NvDsServerTextEmbeddingInfo
◆ NvDsServerAnalyticsPropFlag
Enumerator
RELOAD_CONFIG
RELOAD_CONFIG
RELOAD_CONFIG
RELOAD_CONFIG
Definition at line 95 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerAnalyticsStatus
Enumerator
Definition at line 217 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerAppInstanceFlag
Enumerator
QUIT_APP
QUIT_APP
QUIT_APP
QUIT_APP
Definition at line 110 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerAppInstanceStatus
Enumerator
QUIT_SUCCESS
QUIT_FAIL
QUIT_SUCCESS
QUIT_FAIL
QUIT_SUCCESS
QUIT_FAIL
QUIT_SUCCESS
QUIT_FAIL
Definition at line 115 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerConvPropFlag
Enumerator
SRC_CROP
DEST_CROP
FLIP_METHOD
SRC_CROP
DEST_CROP
FLIP_METHOD
SRC_CROP
DEST_CROP
FLIP_METHOD
SRC_CROP
DEST_CROP
FLIP_METHOD
Definition at line 41 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerConvStatus
Enumerator
Definition at line 173 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerDecPropFlag
Enumerator
DROP_FRAME_INTERVAL
SKIP_FRAMES
LOW_LATENCY_MODE
DROP_FRAME_INTERVAL
SKIP_FRAMES
LOW_LATENCY_MODE
DROP_FRAME_INTERVAL
SKIP_FRAMES
LOW_LATENCY_MODE
DROP_FRAME_INTERVAL
SKIP_FRAMES
LOW_LATENCY_MODE
Definition at line 26 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerDecStatus
Enumerator
Definition at line 151 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerEncPropFlag
Enumerator
BITRATE
FORCE_IDR
FORCE_INTRA
IFRAME_INTERVAL
BITRATE
FORCE_IDR
FORCE_INTRA
IFRAME_INTERVAL
BITRATE
FORCE_IDR
FORCE_INTRA
IFRAME_INTERVAL
BITRATE
FORCE_IDR
FORCE_INTRA
IFRAME_INTERVAL
Definition at line 33 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerEncStatus
Enumerator
BITRATE_UPDATE_FAIL
BITRATE_UPDATE_FAIL
BITRATE_UPDATE_FAIL
BITRATE_UPDATE_FAIL
Definition at line 161 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerGetRequestPropFlag
GET_LIVE_STREAM_INFO - Query stream information via /api/v1/stream/get-stream-info GET_READY_INFO - Application readiness health check via /ready GET_LIVE_INFO - Application liveness health check via /live GET_STARTUP_INFO - Application startup state via /startup GET_METRICS_INFO - Query application metrics via /api/v1/metrics GET_METADATA_INFO - Query application metadata via /api/v1/metadata
Enumerator
GET_READY_INFO
GET_LIVE_INFO
GET_STARTUP_INFO
GET_METRICS_INFO
GET_METADATA_INFO
GET_READY_INFO
GET_LIVE_INFO
GET_STARTUP_INFO
GET_METRICS_INFO
GET_METADATA_INFO
GET_READY_INFO
GET_LIVE_INFO
GET_STARTUP_INFO
GET_METRICS_INFO
GET_METADATA_INFO
GET_READY_INFO
GET_LIVE_INFO
GET_STARTUP_INFO
GET_METRICS_INFO
GET_METADATA_INFO
Definition at line 80 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerGetRequestStatus
Enumerator
GET_READY_INFO_FAIL
GET_LIVE_INFO_FAIL
GET_READY_INFO_FAIL
GET_LIVE_INFO_FAIL
GET_READY_INFO_FAIL
GET_LIVE_INFO_FAIL
GET_READY_INFO_FAIL
GET_LIVE_INFO_FAIL
Definition at line 129 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerInferPropFlag
Enumerator
INFER_INTERVAL
INFER_INTERVAL
INFER_INTERVAL
INFER_INTERVAL
Definition at line 55 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerInferServerPropFlag
Enumerator
Definition at line 60 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerInferServerStatus
Enumerator
Definition at line 199 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerInferStatus
Enumerator
Definition at line 193 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerMuxPropFlag
Enumerator
MAX_LATENCY
MAX_LATENCY
MAX_LATENCY
MAX_LATENCY
Definition at line 49 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerMuxStatus
Enumerator
Definition at line 185 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerNvTrackerPropFlag
Enumerator
NVTRACKER_CONFIG
NVTRACKER_CONFIG
NVTRACKER_CONFIG
NVTRACKER_CONFIG
Definition at line 65 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerNvTrackerStatus
Enumerator
Definition at line 205 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerOsdPropFlag
Enumerator
PROCESS_MODE
PROCESS_MODE
PROCESS_MODE
PROCESS_MODE
Definition at line 90 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerOsdStatus
Enumerator
Definition at line 211 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerRoiPropFlag
Enumerator
ROI_UPDATE
ROI_UPDATE
ROI_UPDATE
ROI_UPDATE
Definition at line 105 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerRoiStatus
Enumerator
ROI_UPDATE_SUCCESS
ROI_UPDATE_FAIL
ROI_UPDATE_SUCCESS
ROI_UPDATE_FAIL
ROI_UPDATE_SUCCESS
ROI_UPDATE_FAIL
ROI_UPDATE_SUCCESS
ROI_UPDATE_FAIL
Definition at line 145 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerStatusCode
Enumerator
StatusOk
StatusAccepted
StatusBadRequest
StatusUnauthorized
StatusForbidden
StatusNotAcceptable
StatusUriTooLong
StatusOk
StatusAccepted
StatusBadRequest
StatusUnauthorized
StatusForbidden
StatusNotAcceptable
StatusUriTooLong
StatusOk
StatusAccepted
StatusBadRequest
StatusUnauthorized
StatusForbidden
StatusNotAcceptable
StatusUriTooLong
StatusOk
StatusAccepted
StatusBadRequest
StatusUnauthorized
StatusForbidden
StatusNotAcceptable
StatusUriTooLong
Definition at line 229 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerStreamStatus
Enumerator
STREAM_ADD_SUCCESS
STREAM_ADD_FAIL
STREAM_REMOVE_FAIL
STREAM_ADD_SUCCESS
STREAM_ADD_FAIL
STREAM_REMOVE_FAIL
STREAM_ADD_SUCCESS
STREAM_ADD_FAIL
STREAM_REMOVE_FAIL
STREAM_ADD_SUCCESS
STREAM_ADD_FAIL
STREAM_REMOVE_FAIL
Definition at line 121 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerTextEmbeddingPropFlag
Enumerator
Definition at line 100 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerTextEmbeddingStatus
Enumerator
Definition at line 223 of file sources/libs/nvds_rest_server/nvds_rest_server.h.
Function Documentation
◆ iequals()
bool iequals ( const std::string &  a,
const std::string &  b
◆ nvds_rest_server_start()
NvDsRestServer* nvds_rest_server_start ( NvDsServerConfig server_config,
NvDsServerCallbacks server_cb,
void *  custom_ctx
◆ nvds_rest_server_stop()
void nvds_rest_server_stop ( NvDsRestServer *  ctx)
