8.0 Release
sources/libs/nvds_rest_server/nvds_rest_server.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2022-2026 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
13 #ifndef _NVDS_SERVER_H_
14 #define _NVDS_SERVER_H_
15
16 #include <string>
17 #include <unordered_map>
18 #include <vector>
19 #include <functional>
20 #include "gst-nvdscustomevent.h"
21 #include "gst-nvdscommonconfig.h"
22 #include <json/json.h>
23 #define UNKNOWN_STRING "unknown"
24 #define EMPTY_STRING ""
25
26 typedef enum
27 {
29  SKIP_FRAMES = 1 << 1,
30  LOW_LATENCY_MODE = 1 << 2,
32
33 typedef enum
34 {
35  BITRATE = 1 << 0,
36  FORCE_IDR = 1 << 1,
37  FORCE_INTRA = 1 << 2,
38  IFRAME_INTERVAL = 1 << 3,
40
41 typedef enum
42 {
43  SRC_CROP = 1 << 0,
44  DEST_CROP = 1 << 1,
45  FLIP_METHOD = 1 << 2,
48
49 typedef enum
50 {
52  MAX_LATENCY = 1 << 1,
54
55 typedef enum
56 {
57  INFER_INTERVAL = 1 << 0,
59
60 typedef enum
61 {
64
65 typedef enum
66 {
67  NVTRACKER_CONFIG = 1 << 0,
69
80 typedef enum
81 {
83  GET_READY_INFO = 1 << 1,
84  GET_LIVE_INFO = 1 << 2,
85  GET_STARTUP_INFO = 1 << 3,
86  GET_METRICS_INFO = 1 << 4,
89
90 typedef enum
91 {
92  PROCESS_MODE = 1 << 0,
94
95 typedef enum
96 {
97  RELOAD_CONFIG = 1 << 0,
99
100 typedef enum
101 {
104
105 typedef enum
106 {
107  ROI_UPDATE = 1 << 0,
109
110 typedef enum
111 {
112  QUIT_APP = 1 << 0,
114
115 typedef enum
116 {
120
121 typedef enum
122 {
128
129 typedef enum
130 {
144
145 typedef enum
146 {
150
151 typedef enum
152 {
160
161 typedef enum
162 {
172
173 typedef enum
174 {
184
185 typedef enum
186 {
192
193 typedef enum
194 {
198
199 typedef enum
200 {
204
205 typedef enum
206 {
210
211 typedef enum
212 {
216
217 typedef enum
218 {
222
223 typedef enum
224 {
228
229 typedef enum
230 {
231  StatusOk = 0, // HTTP error code : 200
232  StatusAccepted, // HTTP error code : 202
233  StatusBadRequest, // HTTP error code : 400
234  StatusUnauthorized, // HTTP error code : 401
235  StatusForbidden, // HTTP error code : 403
236  StatusMethodNotAllowed, // HTTP error code : 405
237  StatusNotAcceptable, // HTTP error code : 406
238  StatusProxyAuthenticationRequired, // HTTP error code : 407
239  StatusRequestTimeout, // HTTP error code : 408
240  StatusPreconditionFailed, // HTTP error code : 412
241  StatusPayloadTooLarge, // HTTP error code : 413
242  StatusUriTooLong, // HTTP error code : 414
243  StatusUnsupportedMediaType, // HTTP error code : 415
244  StatusInternalServerError, // HTTP error code : 500
245  StatusNotImplemented // HTTP error code : 501
247
248 typedef struct NvDsServerErrorInfo
249 {
250  std::pair < int, std::string > err_log;
253
254 typedef struct NvDsServerDecInfo
255 {
256  std::string root_key;
257  std::string stream_id;
258  guint drop_frame_interval;
259  guint skip_frames;
260  gboolean low_latency_mode;
263  std::string dec_log;
264  std::string uri;
267
268 typedef struct NvDsServerEncInfo
269 {
270  std::string root_key;
271  std::string stream_id;
272  guint bitrate;
273  gboolean force_idr;
274  gboolean force_intra;
275  guint iframeinterval;
278  std::string enc_log;
279  std::string uri;
282
283 typedef struct NvDsServerConvInfo
284 {
285  std::string root_key;
286  std::string stream_id;
287  std::string src_crop;
288  std::string dest_crop;
289  guint flip_method;
290  guint interpolation_method;
293  std::string conv_log;
294  std::string uri;
297
298 typedef struct NvDsServerMuxInfo
299 {
300  std::string root_key;
302  guint max_latency;
305  std::string mux_log;
306  std::string uri;
309
310 typedef struct NvDsServerRoiInfo
311 {
312  std::string root_key;
313  std::string stream_id;
314  guint roi_count;
315  std::vector < RoiDimension > vect;
318  std::string roi_log;
319  std::string uri;
322
323 typedef struct NvDsServerStreamInfo
324 {
325  std::string key;
326  std::string value_camera_id;
327  std::string value_camera_name;
328  std::string value_camera_url;
329  std::string value_change;
330  std::string value_creation_time;
331
332  std::string metadata_resolution;
333  std::string metadata_codec;
334  std::string metadata_framerate;
335
336  std::string headers_source;
337  std::string headers_created_at;
339  std::string stream_log;
340  std::string uri;
343
344 typedef struct NvDsGetRequestInfo
345 {
346  std::string root_key;
347  std::string stream_id;
348  gboolean is_text;
351  std::string get_request_log;
352  std::string uri;
353  Json::Value stream_info;
354  std::vector<NvDsSensorInfo*> sensorInfo_vec;
357
358 typedef struct NvDsServerInferInfo
359 {
360  std::string root_key;
361  std::string stream_id;
362  guint interval;
365  std::string infer_log;
366  std::string uri;
369 typedef struct NvDsServerOsdInfo
370 {
371  std::string root_key;
372  std::string stream_id;
373  guint process_mode;
376  std::string osd_log;
377  std::string uri;
380
381 typedef struct NvDsServerAnalyticsInfo
382 {
383  std::string root_key;
384  std::string stream_id;
385  std::string config_file_path;
388  std::string analytics_log;
389  std::string uri;
392
393 typedef struct NvDsServerTextEmbeddingInfo
394 {
395  std::string text_input;
396  std::string model;
397  std::string id;
398  long created;
399  Json::Value data;
402  std::string text_embedding_log;
403  std::string uri;
406
407 typedef struct NvDsServerAppInstanceInfo
408 {
409  std::string root_key;
410  gboolean app_quit;
413  std::string app_log;
414  std::string uri;
417
418 typedef struct NvDsServerInferServerInfo
419 {
420  std::string root_key;
421  std::string stream_id;
422  guint interval;
425  std::string inferserver_log;
426  std::string uri;
429
430 typedef struct NvDsServerNvTrackerInfo
431 {
432  std::string root_key;
433  std::string stream_id;
434  std::string config_path;
437  std::string nvTracker_log;
438  std::string uri;
441 typedef struct NvDsServerResponseInfo
442 {
443  std::string status;
444  std::string reason;
445  Json::Value stream_info;
447
448 typedef struct NvDsServerConfig
449 {
450  std::string ip;
451  std::string port;
453
454 using cb_func = std::function < NvDsServerStatusCode (const Json::Value & req_info,
455  const Json::Value & in,
456  Json::Value & out, struct mg_connection * conn, void *ctx)>;
457
458 typedef struct NvDsServerCallbacks
459 {
460  std::function < void (NvDsServerRoiInfo * roi_info, void *ctx) > roi_cb;
461  std::function < void (NvDsServerDecInfo * dec_info, void *ctx) > dec_cb;
462  std::function < void (NvDsServerEncInfo * enc_info, void *ctx) > enc_cb;
463  std::function < void (NvDsServerStreamInfo * stream_info,
464  void *ctx) > stream_cb;
465  std::function < void (NvDsServerInferInfo * infer_info,
466  void *ctx) > infer_cb;
467  std::function < void (NvDsServerConvInfo * conv_info, void *ctx) > conv_cb;
468  std::function < void (NvDsServerMuxInfo * mux_info, void *ctx) > mux_cb;
469  std::function < void (NvDsServerInferServerInfo * inferserver_info,
470  void *ctx) > inferserver_cb;
471  std::function < void (NvDsServerNvTrackerInfo * nvTracker_info,
472  void *ctx) > nvTracker_cb;
473  std::function < void (NvDsServerOsdInfo * osd_info, void *ctx) > osd_cb;
474  std::function < void (NvDsServerAppInstanceInfo * appinstance_info,
475  void *ctx) > appinstance_cb;
476  std::function < void (NvDsServerAnalyticsInfo * analytics_info, void *ctx) > analytics_cb;
477  std::function < void (NvDsServerTextEmbeddingInfo * text_embedding_info, void *ctx) > text_embedding_cb;
478  std::function < void (NvDsServerGetRequestInfo * get_request_info,
479  void *ctx) > get_request_cb;
480  std::unordered_map <std::string, cb_func> custom_cb_endpt;
482
483 class NvDsRestServer;
484 NvDsRestServer* nvds_rest_server_start (NvDsServerConfig * server_config, NvDsServerCallbacks * server_cb, void* custom_ctx);
485 void nvds_rest_server_stop (NvDsRestServer *ctx);
486 bool iequals (const std::string & a, const std::string & b);
487
488 #endif
@ StatusMethodNotAllowed
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:236
NvDsServerConvInfo::dest_crop
Definition: sources/includes/nvds_rest_server.h:288
GET_METRICS_INFO_FAIL
@ GET_METRICS_INFO_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:140
NvDsServerRoiPropFlag
Definition: sources/includes/nvds_rest_server.h:105
NvDsServerMuxInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:306
GET_READY_INFO_SUCCESS
@ GET_READY_INFO_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:133
NvDsServerRoiInfo::stream_id
Definition: sources/includes/nvds_rest_server.h:313
GET_LIVE_STREAM_INFO_SUCCESS
@ GET_LIVE_STREAM_INFO_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:131
NvDsServerStreamInfo::metadata_resolution
Definition: sources/includes/nvds_rest_server.h:332
STREAM_REMOVE_SUCCESS
@ STREAM_REMOVE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:125
NvDsServerMuxPropFlag
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:49
void nvds_rest_server_stop(NvDsRestServer *ctx)
NvDsServerMuxInfo::root_key
Definition: sources/includes/nvds_rest_server.h:300
NvDsServerInferInfo::infer_flag
NvDsServerInferPropFlag infer_flag
Definition: sources/includes/nvds_rest_server.h:364
@ StatusPayloadTooLarge
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:241
Definition: sources/includes/nvds_rest_server.h:229
NvDsServerNvTrackerPropFlag
Definition: sources/includes/nvds_rest_server.h:65
NvDsServerDecPropFlag
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:26
NvDsServerRoiInfo::roi_log
std::string roi_log
Definition: sources/includes/nvds_rest_server.h:318
NvDsServerAnalyticsInfo::root_key
Definition: sources/includes/nvds_rest_server.h:383
NVTRACKER_CONFIG
@ NVTRACKER_CONFIG
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:67
Definition: sources/includes/nvds_rest_server.h:441
NvDsServerNvTrackerInfo::status
NvDsServerNvTrackerStatus status
Definition: sources/includes/nvds_rest_server.h:435
INFER_INTERVAL_UPDATE_FAIL
@ INFER_INTERVAL_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:196
NvDsServerCallbacks::custom_cb_endpt
std::unordered_map< std::string, cb_func > custom_cb_endpt
Definition: sources/includes/nvds_rest_server.h:480
NvDsServerRoiInfo::roi_flag
NvDsServerRoiPropFlag roi_flag
Definition: sources/includes/nvds_rest_server.h:317
NvDsServerNvTrackerInfo::root_key
Definition: sources/includes/nvds_rest_server.h:432
GET_LIVE_INFO_FAIL
@ GET_LIVE_INFO_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:136
NvDsServerMuxStatus
NvDsServerMuxStatus
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:185
NvDsServerInferInfo
struct NvDsServerInferInfo NvDsServerInferInfo
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:65
Definition: sources/includes/nvds_rest_server.h:205
NvDsServerConvInfo::root_key
Definition: sources/includes/nvds_rest_server.h:285
NvDsServerConvInfo::status
NvDsServerConvStatus status
Definition: sources/includes/nvds_rest_server.h:291
NvDsServerMuxInfo::mux_flag
NvDsServerMuxPropFlag mux_flag
Definition: sources/includes/nvds_rest_server.h:304
StatusNotAcceptable
@ StatusNotAcceptable
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:237
NvDsServerErrorInfo::code
NvDsServerStatusCode code
Definition: sources/includes/nvds_rest_server.h:251
INFERSERVER_INTERVAL_UPDATE_FAIL
@ INFERSERVER_INTERVAL_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:202
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:229
NvDsServerConvInfo::stream_id
Definition: sources/includes/nvds_rest_server.h:286
NvDsServerOsdInfo::status
NvDsServerOsdStatus status
Definition: sources/includes/nvds_rest_server.h:374
FLIP_METHOD_UPDATE_SUCCESS
@ FLIP_METHOD_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:181
NvDsServerCallbacks::nvTracker_cb
std::function< void(NvDsServerNvTrackerInfo *nvTracker_info, void *ctx) > nvTracker_cb
Definition: sources/includes/nvds_rest_server.h:472
MAX_LATENCY_UPDATE_FAIL
@ MAX_LATENCY_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:190
SKIP_FRAMES
@ SKIP_FRAMES
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:29
STREAM_ADD_SUCCESS
@ STREAM_ADD_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:123
NvDsServerErrorInfo::err_log
std::pair< int, std::string > err_log
Definition: sources/includes/nvds_rest_server.h:250
IFRAME_INTERVAL_UPDATE_FAIL
@ IFRAME_INTERVAL_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:170
struct NvDsServerAppInstanceInfo NvDsServerAppInstanceInfo
NvDsServerDecStatus
NvDsServerDecStatus
Definition: sources/includes/nvds_rest_server.h:151
GET_STARTUP_INFO
@ GET_STARTUP_INFO
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:85
NvDsServerOsdInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:377
NvDsServerConvInfo::src_crop
Definition: sources/includes/nvds_rest_server.h:287
NvDsGetRequestInfo::stream_info
Definition: sources/includes/nvds_rest_server.h:353
NvDsServerDecInfo::err_info
NvDsServerErrorInfo err_info
Definition: sources/includes/nvds_rest_server.h:265
PROCESS_MODE
@ PROCESS_MODE
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:92
NvDsServerRoiInfo::err_info
Definition: sources/includes/nvds_rest_server.h:320
FORCE_INTRA_UPDATE_FAIL
@ FORCE_INTRA_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:168
NvDsServerEncInfo::force_intra
Definition: sources/includes/nvds_rest_server.h:274
@ StatusProxyAuthenticationRequired
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:238
cb_func
std::function< NvDsServerStatusCode(const Json::Value &req_info, const Json::Value &in, Json::Value &out, struct mg_connection *conn, void *ctx)> cb_func
Definition: sources/includes/nvds_rest_server.h:456
NvDsServerStreamInfo::value_camera_name
Definition: sources/includes/nvds_rest_server.h:327
NvDsServerInferInfo
Definition: sources/includes/nvds_rest_server.h:358
StatusForbidden
@ StatusForbidden
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:235
NvDsServerDecInfo::skip_frames
guint skip_frames
Definition: sources/includes/nvds_rest_server.h:259
QUIT_SUCCESS
@ QUIT_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:117
NvDsServerInferServerInfo::inferserver_flag
NvDsServerInferServerPropFlag inferserver_flag
Definition: sources/includes/nvds_rest_server.h:424
NvDsServerConfig::ip
std::string ip
Definition: sources/includes/nvds_rest_server.h:450
NvDsServerAppInstanceFlag
Definition: sources/includes/nvds_rest_server.h:110
Definition: sources/includes/nvds_rest_server.h:173
NvDsGetRequestInfo::get_request_flag
NvDsServerGetRequestPropFlag get_request_flag
Definition: sources/includes/nvds_rest_server.h:350
NvDsServerStreamInfo::value_creation_time
Definition: sources/includes/nvds_rest_server.h:330
NvDsServerCallbacks::osd_cb
std::function< void(NvDsServerOsdInfo *osd_info, void *ctx) > osd_cb
Definition: sources/includes/nvds_rest_server.h:473
NvDsServerStreamInfo::headers_source
Definition: sources/includes/nvds_rest_server.h:336
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:60
@ StatusUnsupportedMediaType
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:243
NvDsServerRoiInfo::vect
std::vector< RoiDimension > vect
Definition: sources/includes/nvds_rest_server.h:315
NvDsServerOsdInfo::process_mode
guint process_mode
Definition: sources/includes/nvds_rest_server.h:373
FLIP_METHOD
@ FLIP_METHOD
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:45
NvDsGetRequestInfo::sensorInfo_vec
std::vector< NvDsSensorInfo * > sensorInfo_vec
Definition: sources/includes/nvds_rest_server.h:354
NvDsServerCallbacks::enc_cb
std::function< void(NvDsServerEncInfo *enc_info, void *ctx) > enc_cb
Definition: sources/includes/nvds_rest_server.h:462
NvDsServerMuxInfo
Definition: sources/includes/nvds_rest_server.h:298
NvDsServerResponseInfo::stream_info
Definition: sources/includes/nvds_rest_server.h:445
Definition: sources/includes/nvds_rest_server.h:418
NvDsServerCallbacks::appinstance_cb
std::function< void(NvDsServerAppInstanceInfo *appinstance_info, void *ctx) > appinstance_cb
Definition: sources/includes/nvds_rest_server.h:475
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:55
NvDsServerMuxInfo
struct NvDsServerMuxInfo NvDsServerMuxInfo
BATCHED_PUSH_TIMEOUT_UPDATE_SUCCESS
@ BATCHED_PUSH_TIMEOUT_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:187
@ StatusInternalServerError
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:244
NvDsServerDecInfo::drop_frame_interval
Definition: sources/includes/nvds_rest_server.h:258
Definition: sources/includes/nvds_rest_server.h:60
NvDsServerTextEmbeddingInfo::err_info
Definition: sources/includes/nvds_rest_server.h:404
NvDsServerMuxInfo::err_info
Definition: sources/includes/nvds_rest_server.h:307
PROCESS_MODE_UPDATE_FAIL
@ PROCESS_MODE_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:214
Flags for GET request types supported by the REST server.
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:80
GET_LIVE_INFO_SUCCESS
@ GET_LIVE_INFO_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:135
FORCE_INTRA_UPDATE_SUCCESS
@ FORCE_INTRA_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:167
NvDsServerEncInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:279
NvDsServerConvInfo::flip_method
guint flip_method
Definition: sources/includes/nvds_rest_server.h:289
FLIP_METHOD_UPDATE_FAIL
@ FLIP_METHOD_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:182
NvDsServerAnalyticsStatus
Definition: sources/includes/nvds_rest_server.h:217
NvDsServerConfig
struct NvDsServerConfig NvDsServerConfig
DROP_FRAME_INTERVAL_UPDATE_FAIL
@ DROP_FRAME_INTERVAL_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:154
NvDsServerCallbacks::conv_cb
std::function< void(NvDsServerConvInfo *conv_info, void *ctx) > conv_cb
Definition: sources/includes/nvds_rest_server.h:467
NvDsServerDecInfo::stream_id
Definition: sources/includes/nvds_rest_server.h:257
NvDsServerTextEmbeddingInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:403
NVTRACKER_CONFIG_UPDATE_SUCCESS
@ NVTRACKER_CONFIG_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:207
NvDsServerTextEmbeddingInfo::text_embedding_flag
NvDsServerTextEmbeddingPropFlag text_embedding_flag
Definition: sources/includes/nvds_rest_server.h:401
NvDsServerEncInfo::status
NvDsServerEncStatus status
Definition: sources/includes/nvds_rest_server.h:276
StatusUnauthorized
@ StatusUnauthorized
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:234
struct NvDsGetRequestInfo NvDsServerGetRequestInfo
NvDsServerAppInstanceStatus
Definition: sources/includes/nvds_rest_server.h:115
NvDsServerCallbacks
Definition: sources/includes/nvds_rest_server.h:458
Definition: sources/includes/nvds_rest_server.h:55
INTERPOLATION_METHOD_UPDATE_FAIL
@ INTERPOLATION_METHOD_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:180
NvDsServerTextEmbeddingStatus
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:223
SKIP_FRAMES_UPDATE_FAIL
@ SKIP_FRAMES_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:156
NvDsServerNvTrackerInfo::nvTracker_flag
NvDsServerNvTrackerPropFlag nvTracker_flag
Definition: sources/includes/nvds_rest_server.h:436
NvDsServerConfig::port
std::string port
Definition: sources/includes/nvds_rest_server.h:451
PROCESS_MODE_UPDATE_SUCCESS
@ PROCESS_MODE_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:213
NvDsServerAppInstanceInfo::err_info
Definition: sources/includes/nvds_rest_server.h:415
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:105
NvDsServerInferInfo::infer_log
Definition: sources/includes/nvds_rest_server.h:365
FORCE_IDR_UPDATE_FAIL
@ FORCE_IDR_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:166
NvDsServerCallbacks::inferserver_cb
std::function< void(NvDsServerInferServerInfo *inferserver_info, void *ctx) > inferserver_cb
Definition: sources/includes/nvds_rest_server.h:470
NvDsServerOsdInfo::stream_id
Definition: sources/includes/nvds_rest_server.h:372
NvDsServerInferServerInfo::status
NvDsServerInferServerStatus status
Definition: sources/includes/nvds_rest_server.h:423
DROP_FRAME_INTERVAL_UPDATE_SUCCESS
@ DROP_FRAME_INTERVAL_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:153
NvDsServerEncInfo::root_key
Definition: sources/includes/nvds_rest_server.h:270
NvDsServerDecInfo::dec_flag
NvDsServerDecPropFlag dec_flag
Definition: sources/includes/nvds_rest_server.h:262
NvDsServerRoiInfo
struct NvDsServerRoiInfo NvDsServerRoiInfo
NvDsServerCallbacks::dec_cb
std::function< void(NvDsServerDecInfo *dec_info, void *ctx) > dec_cb
Definition: sources/includes/nvds_rest_server.h:461
NvDsServerStreamInfo::value_camera_url
Definition: sources/includes/nvds_rest_server.h:328
NvDsServerEncPropFlag
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:33
NvDsServerAnalyticsInfo::err_info
Definition: sources/includes/nvds_rest_server.h:390
NvDsServerEncInfo::bitrate
guint bitrate
Definition: sources/includes/nvds_rest_server.h:272
StatusUriTooLong
@ StatusUriTooLong
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:242
MAX_LATENCY
@ MAX_LATENCY
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:52
NvDsServerDecInfo::root_key
Definition: sources/includes/nvds_rest_server.h:256
LOW_LATENCY_MODE_UPDATE_FAIL
@ LOW_LATENCY_MODE_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:158
GET_METRICS_INFO
@ GET_METRICS_INFO
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:86
NvDsServerConvPropFlag
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:41
STREAM_ADD_FAIL
@ STREAM_ADD_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:124
NvDsServerOsdStatus
NvDsServerOsdStatus
Definition: sources/includes/nvds_rest_server.h:211
NvDsServerDecInfo::low_latency_mode
Definition: sources/includes/nvds_rest_server.h:260
NvDsServerTextEmbeddingInfo::text_input
Definition: sources/includes/nvds_rest_server.h:395
NvDsServerAnalyticsInfo::analytics_log
Definition: sources/includes/nvds_rest_server.h:388
NvDsServerAppInstanceInfo::root_key
Definition: sources/includes/nvds_rest_server.h:409
NvDsServerInferInfo::status
NvDsServerInferStatus status
Definition: sources/includes/nvds_rest_server.h:363
NvDsServerStreamInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:340
GET_LIVE_INFO
@ GET_LIVE_INFO
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:84
NvDsServerTextEmbeddingInfo::id
std::string id
Definition: sources/includes/nvds_rest_server.h:397
NvDsServerOsdPropFlag
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:90
TEXT_EMBEDDING_GENERATE_FAIL
@ TEXT_EMBEDDING_GENERATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:226
NvDsServerDecInfo
struct NvDsServerDecInfo NvDsServerDecInfo
NvDsServerAnalyticsInfo::analytics_flag
NvDsServerAnalyticsPropFlag analytics_flag
Definition: sources/includes/nvds_rest_server.h:387
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:205
NvDsServerDecInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:264
SRC_CROP_UPDATE_FAIL
@ SRC_CROP_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:178
NvDsGetRequestInfo
Definition: sources/includes/nvds_rest_server.h:344
NvDsServerInferServerInfo::err_info
Definition: sources/includes/nvds_rest_server.h:427
NvDsServerInferServerInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:426
NvDsServerOsdInfo::osd_log
std::string osd_log
Definition: sources/includes/nvds_rest_server.h:376
NvDsServerConfig
Definition: sources/includes/nvds_rest_server.h:448
NvDsServerCallbacks::text_embedding_cb
std::function< void(NvDsServerTextEmbeddingInfo *text_embedding_info, void *ctx) > text_embedding_cb
Definition: sources/includes/nvds_rest_server.h:477
Definition: sources/includes/nvds_rest_server.h:49
NvDsServerRoiStatus
NvDsServerRoiStatus
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:145
struct NvDsServerTextEmbeddingInfo NvDsServerTextEmbeddingInfo
NvDsServerEncInfo
Definition: sources/includes/nvds_rest_server.h:268
Definition: sources/includes/nvds_rest_server.h:100
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:110
Definition: sources/includes/nvds_rest_server.h:223
NvDsGetRequestInfo::status
NvDsServerGetRequestStatus status
Definition: sources/includes/nvds_rest_server.h:349
NvDsServerResponseInfo::reason
std::string reason
Definition: sources/includes/nvds_rest_server.h:444
ROI_UPDATE_FAIL
@ ROI_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:148
NvDsServerDecStatus
NvDsServerDecStatus
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:151
SKIP_FRAMES_UPDATE_SUCCESS
@ SKIP_FRAMES_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:155
NvDsServerStreamInfo::metadata_framerate
Definition: sources/includes/nvds_rest_server.h:334
NvDsServerNvTrackerInfo::config_path
Definition: sources/includes/nvds_rest_server.h:434
BITRATE_UPDATE_SUCCESS
@ BITRATE_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:163
NvDsServerConvInfo::err_info
Definition: sources/includes/nvds_rest_server.h:295
NvDsServerCallbacks::stream_cb
std::function< void(NvDsServerStreamInfo *stream_info, void *ctx) > stream_cb
Definition: sources/includes/nvds_rest_server.h:464
NvDsServerCallbacks::roi_cb
std::function< void(NvDsServerRoiInfo *roi_info, void *ctx) > roi_cb
Definition: sources/includes/nvds_rest_server.h:460
QUIT_APP
@ QUIT_APP
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:112
NvDsServerOsdStatus
NvDsServerOsdStatus
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:211
struct NvDsServerAnalyticsInfo NvDsServerAnalyticsInfo
NvDsServerOsdInfo
Definition: sources/includes/nvds_rest_server.h:369
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:199
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:51
NvDsServerRoiInfo::roi_count
guint roi_count
Definition: sources/includes/nvds_rest_server.h:314
NvDsServerResponseInfo::status
std::string status
Definition: sources/includes/nvds_rest_server.h:443
SRC_CROP_UPDATE_SUCCESS
@ SRC_CROP_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:177
NvDsServerRoiInfo::status
NvDsServerRoiStatus status
Definition: sources/includes/nvds_rest_server.h:316
NvDsServerDecInfo
Definition: sources/includes/nvds_rest_server.h:254
FORCE_IDR
@ FORCE_IDR
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:36
NvDsServerOsdInfo::root_key
Definition: sources/includes/nvds_rest_server.h:371
NvDsServerEncStatus
NvDsServerEncStatus
Definition: sources/includes/nvds_rest_server.h:161
NvDsServerEncInfo::stream_id
Definition: sources/includes/nvds_rest_server.h:271
GET_METADATA_INFO
@ GET_METADATA_INFO
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:87
@ StatusRequestTimeout
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:239
GET_READY_INFO_FAIL
@ GET_READY_INFO_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:134
NvDsServerMuxStatus
NvDsServerMuxStatus
Definition: sources/includes/nvds_rest_server.h:185
TEXT_EMBEDDING_GENERATE_SUCCESS
@ TEXT_EMBEDDING_GENERATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:225
ROI_UPDATE
@ ROI_UPDATE
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:107
DEST_CROP_UPDATE_SUCCESS
@ DEST_CROP_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:175
NvDsServerMuxInfo::max_latency
guint max_latency
Definition: sources/includes/nvds_rest_server.h:302
NvDsServerAppInstanceInfo::app_quit
gboolean app_quit
Definition: sources/includes/nvds_rest_server.h:410
NvDsServerStreamInfo::stream_log
Definition: sources/includes/nvds_rest_server.h:339
NvDsServerCallbacks
struct NvDsServerCallbacks NvDsServerCallbacks
Definition: sources/includes/nvds_rest_server.h:199
NvDsServerRoiInfo
Definition: sources/includes/nvds_rest_server.h:310
NvDsGetRequestInfo::err_info
Definition: sources/includes/nvds_rest_server.h:355
Definition: sources/includes/nvds_rest_server.h:95
struct NvDsServerResponseInfo NvDsServerResponseInfo
StatusAccepted
@ StatusAccepted
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:232
GET_STARTUP_INFO_SUCCESS
@ GET_STARTUP_INFO_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:137
Definition: sources/includes/nvds_rest_server.h:90
Definition: sources/includes/nvds_rest_server.h:323
GET_METADATA_INFO_FAIL
@ GET_METADATA_INFO_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:142
NvDsServerTextEmbeddingInfo::model
std::string model
Definition: sources/includes/nvds_rest_server.h:396
NvDsServerAnalyticsInfo::config_file_path
Definition: sources/includes/nvds_rest_server.h:385
NvDsGetRequestInfo::get_request_log
Definition: sources/includes/nvds_rest_server.h:351
MAX_LATENCY_UPDATE_SUCCESS
@ MAX_LATENCY_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:189
INFERSERVER_INTERVAL_UPDATE_SUCCESS
@ INFERSERVER_INTERVAL_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:201
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:62
NvDsServerAppInstanceInfo::status
NvDsServerAppInstanceStatus status
Definition: sources/includes/nvds_rest_server.h:411
NvDsServerRoiInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:319
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:115
NvDsServerEncInfo::iframeinterval
Definition: sources/includes/nvds_rest_server.h:275
NvDsServerCallbacks::get_request_cb
std::function< void(NvDsServerGetRequestInfo *get_request_info, void *ctx) > get_request_cb
Definition: sources/includes/nvds_rest_server.h:479
NvDsServerDecInfo::status
NvDsServerDecStatus status
Definition: sources/includes/nvds_rest_server.h:261
NvDsRestServer * nvds_rest_server_start(NvDsServerConfig *server_config, NvDsServerCallbacks *server_cb, void *custom_ctx)
NvDsGetRequestInfo::root_key
Definition: sources/includes/nvds_rest_server.h:346
StatusOk
@ StatusOk
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:231
NvDsServerMuxInfo::mux_log
std::string mux_log
Definition: sources/includes/nvds_rest_server.h:305
struct NvDsServerNvTrackerInfo NvDsServerNvTrackerInfo
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:129
INTERPOLATION_METHOD_UPDATE_SUCCESS
@ INTERPOLATION_METHOD_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:179
Definition: sources/includes/nvds_rest_server.h:129
struct NvDsServerStreamInfo NvDsServerStreamInfo
NvDsServerNvTrackerInfo::nvTracker_log
Definition: sources/includes/nvds_rest_server.h:437
DEST_CROP_UPDATE_FAIL
@ DEST_CROP_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:176
NvDsServerConvInfo::interpolation_method
Definition: sources/includes/nvds_rest_server.h:290
NvDsServerDecInfo::dec_log
std::string dec_log
Definition: sources/includes/nvds_rest_server.h:263
NvDsServerInferServerInfo::root_key
Definition: sources/includes/nvds_rest_server.h:420
NvDsServerRoiStatus
NvDsServerRoiStatus
Definition: sources/includes/nvds_rest_server.h:145
NvDsServerRoiInfo::root_key
Definition: sources/includes/nvds_rest_server.h:312
LOW_LATENCY_MODE
@ LOW_LATENCY_MODE
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:30
BITRATE_UPDATE_FAIL
@ BITRATE_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:164
NvDsGetRequestInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:352
NvDsServerOsdInfo::err_info
Definition: sources/includes/nvds_rest_server.h:378
RELOAD_CONFIG
@ RELOAD_CONFIG
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:97
NvDsServerNvTrackerInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:438
@ StatusNotImplemented
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:245
NvDsServerAnalyticsInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:389
@ StatusPreconditionFailed
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:240
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:173
NvDsServerStreamInfo::metadata_codec
Definition: sources/includes/nvds_rest_server.h:333
IFRAME_INTERVAL
@ IFRAME_INTERVAL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:38
NvDsServerEncStatus
NvDsServerEncStatus
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:161
NvDsServerEncInfo::enc_log
std::string enc_log
Definition: sources/includes/nvds_rest_server.h:278
Definition: sources/includes/nvds_rest_server.h:193
NvDsServerInferInfo::interval
guint interval
Definition: sources/includes/nvds_rest_server.h:362
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:217
NvDsServerOsdInfo::osd_flag
NvDsServerOsdPropFlag osd_flag
Definition: sources/includes/nvds_rest_server.h:375
NvDsServerEncInfo::enc_flag
NvDsServerEncPropFlag enc_flag
Definition: sources/includes/nvds_rest_server.h:277
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:102
NvDsServerAppInstanceInfo::app_log
std::string app_log
Definition: sources/includes/nvds_rest_server.h:413
DEST_CROP
@ DEST_CROP
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:44
NvDsServerMuxInfo::batched_push_timeout
gint batched_push_timeout
Definition: sources/includes/nvds_rest_server.h:301
NvDsServerInferInfo::root_key
Definition: sources/includes/nvds_rest_server.h:360
NvDsServerNvTrackerInfo::stream_id
Definition: sources/includes/nvds_rest_server.h:433
Definition: sources/includes/nvds_rest_server.h:430
NvDsServerEncInfo
struct NvDsServerEncInfo NvDsServerEncInfo
NvDsServerConvInfo
struct NvDsServerConvInfo NvDsServerConvInfo
NvDsServerAnalyticsInfo::status
NvDsServerAnalyticsStatus status
Definition: sources/includes/nvds_rest_server.h:386
STREAM_REMOVE_FAIL
@ STREAM_REMOVE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:126
GET_METRICS_INFO_SUCCESS
@ GET_METRICS_INFO_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:139
ROI_UPDATE_SUCCESS
@ ROI_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:147
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:193
Definition: sources/includes/nvds_rest_server.h:393
NvDsServerConvInfo::conv_log
Definition: sources/includes/nvds_rest_server.h:293
NvDsServerConvInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:294
NvDsServerCallbacks::analytics_cb
std::function< void(NvDsServerAnalyticsInfo *analytics_info, void *ctx) > analytics_cb
Definition: sources/includes/nvds_rest_server.h:476
FORCE_INTRA
@ FORCE_INTRA
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:37
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:95
NvDsServerInferInfo::err_info
Definition: sources/includes/nvds_rest_server.h:367
NvDsServerTextEmbeddingInfo::status
NvDsServerTextEmbeddingStatus status
Definition: sources/includes/nvds_rest_server.h:400
NvDsServerNvTrackerInfo::err_info
Definition: sources/includes/nvds_rest_server.h:439
Definition: sources/includes/nvds_rest_server.h:407
NvDsServerAppInstanceInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:414
NvDsServerInferInfo::uri
std::string uri
Definition: sources/includes/nvds_rest_server.h:366
QUIT_FAIL
@ QUIT_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:118
LOW_LATENCY_MODE_UPDATE_SUCCESS
@ LOW_LATENCY_MODE_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:157
NvDsServerEncInfo::err_info
Definition: sources/includes/nvds_rest_server.h:280
DROP_FRAME_INTERVAL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:28
NvDsServerStreamInfo::key
std::string key
Definition: sources/includes/nvds_rest_server.h:325
INFER_INTERVAL_UPDATE_SUCCESS
@ INFER_INTERVAL_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:195
iequals
bool iequals(const std::string &a, const std::string &b)
NvDsServerConvInfo
Definition: sources/includes/nvds_rest_server.h:283
NvDsServerStreamInfo::value_camera_id
Definition: sources/includes/nvds_rest_server.h:326
NvDsServerStreamStatus
Definition: sources/includes/nvds_rest_server.h:121
NvDsServerTextEmbeddingInfo::created
long created
Definition: sources/includes/nvds_rest_server.h:398
NvDsServerOsdInfo
struct NvDsServerOsdInfo NvDsServerOsdInfo
INFER_INTERVAL
@ INFER_INTERVAL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:57
RELOAD_CONFIG_UPDATE_FAIL
@ RELOAD_CONFIG_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:220
NvDsServerAnalyticsInfo::stream_id
Definition: sources/includes/nvds_rest_server.h:384
Definition: sources/includes/nvds_rest_server.h:80
NvDsServerErrorInfo
struct NvDsServerErrorInfo NvDsServerErrorInfo
FORCE_IDR_UPDATE_SUCCESS
@ FORCE_IDR_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:165
GET_METADATA_INFO_SUCCESS
@ GET_METADATA_INFO_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:141
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:121
NvDsServerStreamInfo::value_change
Definition: sources/includes/nvds_rest_server.h:329
NvDsServerMuxInfo::status
NvDsServerMuxStatus status
Definition: sources/includes/nvds_rest_server.h:303
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:82
NvDsServerInferServerInfo::stream_id
Definition: sources/includes/nvds_rest_server.h:421
BITRATE
@ BITRATE
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:35
StatusBadRequest
@ StatusBadRequest
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:233
NvDsServerTextEmbeddingInfo::text_embedding_log
Definition: sources/includes/nvds_rest_server.h:402
IFRAME_INTERVAL_UPDATE_SUCCESS
@ IFRAME_INTERVAL_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:169
NvDsServerConvInfo::conv_flag
NvDsServerConvPropFlag conv_flag
Definition: sources/includes/nvds_rest_server.h:292
NvDsGetRequestInfo::is_text
gboolean is_text
Definition: sources/includes/nvds_rest_server.h:348
struct NvDsServerInferServerInfo NvDsServerInferServerInfo
GET_LIVE_STREAM_INFO_FAIL
@ GET_LIVE_STREAM_INFO_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:132
NvDsServerStreamInfo::status
NvDsServerStreamStatus status
Definition: sources/includes/nvds_rest_server.h:338
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:46
NvDsServerInferInfo::stream_id
Definition: sources/includes/nvds_rest_server.h:361
NvDsServerStreamInfo::headers_created_at
Definition: sources/includes/nvds_rest_server.h:337
NvDsServerEncInfo::force_idr
gboolean force_idr
Definition: sources/includes/nvds_rest_server.h:273
Definition: sources/includes/nvds_rest_server.h:381
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:100
NvDsServerCallbacks::infer_cb
std::function< void(NvDsServerInferInfo *infer_info, void *ctx) > infer_cb
Definition: sources/includes/nvds_rest_server.h:466
NvDsGetRequestInfo::stream_id
Definition: sources/includes/nvds_rest_server.h:347
NvDsServerTextEmbeddingInfo::data
Json::Value data
Definition: sources/includes/nvds_rest_server.h:399
NvDsServerErrorInfo
Definition: sources/includes/nvds_rest_server.h:248
NvDsServerInferServerInfo::inferserver_log
Definition: sources/includes/nvds_rest_server.h:425
NvDsServerStreamInfo::err_info
Definition: sources/includes/nvds_rest_server.h:341
RELOAD_CONFIG_UPDATE_SUCCESS
@ RELOAD_CONFIG_UPDATE_SUCCESS
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:219
GET_READY_INFO
@ GET_READY_INFO
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:83
NvDsServerInferServerInfo::interval
guint interval
Definition: sources/includes/nvds_rest_server.h:422
NvDsServerAppInstanceInfo::appinstance_flag
NvDsServerAppInstanceFlag appinstance_flag
Definition: sources/includes/nvds_rest_server.h:412
GET_STARTUP_INFO_FAIL
@ GET_STARTUP_INFO_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:138
SRC_CROP
@ SRC_CROP
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:43
NVTRACKER_CONFIG_UPDATE_FAIL
@ NVTRACKER_CONFIG_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:208
NvDsServerCallbacks::mux_cb
std::function< void(NvDsServerMuxInfo *mux_info, void *ctx) > mux_cb
Definition: sources/includes/nvds_rest_server.h:468
BATCHED_PUSH_TIMEOUT_UPDATE_FAIL
@ BATCHED_PUSH_TIMEOUT_UPDATE_FAIL
Definition: sources/libs/nvds_rest_server/nvds_rest_server.h:188
