7.1 Release
BatchPolicyConfig Struct Reference
Definition at line 56 of file nvstreammux_batch.h.
Public Member Functions
 BatchPolicyConfig ()
Data Fields
NvStreammuxBatchMethod type
bool adaptive_batching
unsigned int batch_size
unsigned int overall_max_fps_n
unsigned int overall_max_fps_d
unsigned int overall_min_fps_n
unsigned int overall_min_fps_d
unsigned int max_same_source_frames
bool enable_source_rate_control
bool enable_max_fps_control
 enables or disables the throttling control in push_loop() implementing max_fps configuration support More...
std::unordered_map< unsigned int, NvStreammuxSourcePropssource_props
◆ BatchPolicyConfig()
BatchPolicyConfig::BatchPolicyConfig ( )
inline
Definition at line 72 of file nvstreammux_batch.h.
References batch_size.
Field Documentation
◆ adaptive_batching
bool BatchPolicyConfig::adaptive_batching
Definition at line 59 of file nvstreammux_batch.h.
◆ batch_size
unsigned int BatchPolicyConfig::batch_size
Definition at line 60 of file nvstreammux_batch.h.
Referenced by BatchPolicyConfig().
◆ enable_max_fps_control
bool BatchPolicyConfig::enable_max_fps_control
Definition at line 69 of file nvstreammux_batch.h.
◆ enable_source_rate_control
bool BatchPolicyConfig::enable_source_rate_control
Definition at line 66 of file nvstreammux_batch.h.
◆ max_same_source_frames
unsigned int BatchPolicyConfig::max_same_source_frames
Definition at line 65 of file nvstreammux_batch.h.
◆ overall_max_fps_d
unsigned int BatchPolicyConfig::overall_max_fps_d
Definition at line 62 of file nvstreammux_batch.h.
◆ overall_max_fps_n
unsigned int BatchPolicyConfig::overall_max_fps_n
Definition at line 61 of file nvstreammux_batch.h.
◆ overall_min_fps_d
unsigned int BatchPolicyConfig::overall_min_fps_d
Definition at line 64 of file nvstreammux_batch.h.
◆ overall_min_fps_n
unsigned int BatchPolicyConfig::overall_min_fps_n
Definition at line 63 of file nvstreammux_batch.h.
◆ source_props
std::unordered_map< unsigned int, NvStreammuxSourceProps> BatchPolicyConfig::source_props
Definition at line 70 of file nvstreammux_batch.h.
◆ type
NvStreammuxBatchMethod BatchPolicyConfig::type
Definition at line 58 of file nvstreammux_batch.h.
