NvBufSurfaceMapPlaneParams Struct Reference
Holds plane parameters to map the buffer received from another process.
Definition at line 621 of file sources/includes/nvbufsurface.h.
Data Fields
uint32_t width
 Holds the widths of planes. More...
uint32_t height
 Holds the heights of planes. More...
uint32_t pitch
 Holds the pitches of planes in bytes. More...
uint32_t offset
 Holds the offsets of planes in bytes. More...
uint32_t psize
 Holds the sizes of planes in bytes. More...
uint32_t secondfieldoffset
 Holds offset of the second field for interlaced buffer. More...
uint32_t blockheightlog2
 Holds block height of the planes for blockLinear layout buffer. More...
uint64_t flags
 Holds flags associated with the planes. More...
uint8_t reserved [64]
 Reserved. More...
