Holds information about one classified attribute.
Definition at line 203 of file nvdsinfer.h.
Data Fields | |
| unsigned int | attributeIndex |
| Holds the index of the attribute's label. More... | |
| unsigned int | attributeValue |
| Holds the the attribute's output value. More... | |
| float | attributeConfidence |
| Holds the attribute's confidence level. More... | |
| char * | attributeLabel |
| Holds a pointer to a string containing the attribute's label. More... | |
| float NvDsInferAttribute::attributeConfidence |
Definition at line 212 of file nvdsinfer.h.
| unsigned int NvDsInferAttribute::attributeIndex |
This index corresponds to the order of output layers specified in the outputCoverageLayerNames vector during initialization.
Definition at line 208 of file nvdsinfer.h.
| char* NvDsInferAttribute::attributeLabel |
Memory for the string must not be freed. Custom parsing functions must allocate strings on heap using strdup or equivalent.
Definition at line 216 of file nvdsinfer.h.
| unsigned int NvDsInferAttribute::attributeValue |
Definition at line 210 of file nvdsinfer.h.
