8.0 Release
NvDsInferContextBatchInput Struct Reference
Holds information about one batch to be inferred.
Definition at line 500 of file sources/includes/nvdsinfer_context.h.
Data Fields
void ** inputFrames
 Holds a pointer to an array of pointers to input frame buffers. More...
unsigned int numInputFrames
 Holds the number of input frames, i.e. More...
NvDsInferFormat inputFormat
 Holds the format of the frame contents. More...
unsigned int inputPitch
 Holds the pitch of the input frames, in bytes. More...
NvDsInferContextReturnInputAsyncFunc returnInputFunc
 Holds a callback for returning the input buffers to the client. More...
void * returnFuncData
 A pointer to the data to be supplied with the callback in returnInputFunc. More...
Field Documentation
◆ inputFormat
NvDsInferFormat NvDsInferContextBatchInput::inputFormat
Definition at line 508 of file sources/includes/nvdsinfer_context.h.
◆ inputFrames
void ** NvDsInferContextBatchInput::inputFrames
The size of the array must be at least numInputFrames.
Definition at line 504 of file sources/includes/nvdsinfer_context.h.
◆ inputPitch
unsigned int NvDsInferContextBatchInput::inputPitch
Definition at line 510 of file sources/includes/nvdsinfer_context.h.
◆ numInputFrames
unsigned int NvDsInferContextBatchInput::numInputFrames
the size of the batch.
Definition at line 506 of file sources/includes/nvdsinfer_context.h.
◆ returnFuncData
void * NvDsInferContextBatchInput::returnFuncData
Definition at line 515 of file sources/includes/nvdsinfer_context.h.
◆ returnInputFunc
NvDsInferContextReturnInputAsyncFunc NvDsInferContextBatchInput::returnInputFunc
Definition at line 512 of file sources/includes/nvdsinfer_context.h.
