Defines the DeepStream inference interface API. In C++, defines the NvDsInferContext class.
The DeepStream inference API "NvDsInfer" provides methods to initialize and deinitialize the inference engine, pre-process the input frames as required by the network, and parse the output from the raw tensor buffers.
Both C and C++ interfaces are available, with the C interface being a simple wrapper over the C++ interface.
You can create an opaque handle to an instance of the context required by the API by calling the factory function createNvDsInferContext() or NvDsInferContext_Create(). Both functions accept an instance of NvDsInferContextInitParams to initialize the context. Both let you specify a logging callback to get detailed information about failures and warnings.
Initialization parameters allow you to configure the network data type, network type (Detector, Classifier, or Other), preprocessing parameters (mean subtraction and normalization), model-related parameters like Caffe/Uff/Onnx model file paths, output layer names, etc.
Batches of frames can be queued for inferencing, using NvDsInferContext::queueInputBatch() or NvDsInferContext_QueueInputBatch(). The input frame memories must be accessible to the GPU device configured during initialization. You can provide an asynchronous callback function to return the input buffers to the caller as soon as the input is consumed.
Inference output can be dequeued using NvDsInferContext::dequeueOutputBatch() or NvDsInferContext_DequeueOutputBatch(). The order of dequeued outputs corresponds to the input queueing order. In case of failure, the output of the batch is lost. The dequeued output must be released back to the context using NvDsInferContext::releaseBatchOutput() or NvDsInferContext_ReleaseBatchOutput() to free the associated memory and return the output layer buffers for reuse by the context.
Detectors output an array of detected objects for each frame in the batch. Classifiers classify entire frames and output an array of attributes for each frame. Segmentation classifies each pixel in the frame. A special network type (Other) has been provided whose output layers are not parsed. The caller can parse the device and host output layer buffers. You can also use this network type with the Gst-infer plugin to flow the output buffers as metadata.
Other methods and functions get parsed labels from a label's file and properties of all layers bound by the inference engine.
You can extend the Gst-nvinfer API using the custom method implementations. Refer to the Custom Method Implementations section for more details.
Data Structures | |
| struct | NvDsInferDetectionParams |
| Holds detection and bounding box grouping parameters. More... | |
| struct | _NvDsInferContextInitParams |
| Holds the initialization parameters required for the NvDsInferContext interface. More... | |
| struct | NvDsInferContextBatchInput |
| Holds information about one batch to be inferred. More... | |
| struct | NvDsInferContextBatchPreprocessedInput |
| struct | NvDsInferObject |
| Holds information about one detected object. More... | |
| struct | NvDsInferDetectionOutput |
| Holds information on all objects detected by a detector network in one frame. More... | |
| struct | NvDsInferClassificationOutput |
| Holds information on all attributes classifed by a classifier network for one frame. More... | |
| struct | NvDsInferSegmentationOutput |
| Holds information parsed from segmentation network output for one frame. More... | |
| struct | NvDsInferFrameOutput |
| Holds the information inferred by the network on one frame. More... | |
| struct | NvDsInferContextBatchOutput |
| Holds the output for all of the frames in a batch (an array of frame), and related buffer information. More... | |
NvDsInferContext API common types and functions. | |
This section describes the common types and functions for both the C and C++ interfaces for the NvDsInferContext class. | |
| enum | NvDsInferNetworkMode { NvDsInferNetworkMode_FP32, NvDsInferNetworkMode_INT8, NvDsInferNetworkMode_FP16, NvDsInferNetworkMode_BEST } |
| Defines internal data formats used by the inference engine. More... | |
| enum | NvDsInferNetworkType { NvDsInferNetworkType_Detector, NvDsInferNetworkType_Classifier, NvDsInferNetworkType_Segmentation, NvDsInferNetworkType_InstanceSegmentation, NvDsInferNetworkType_Other = 100 } |
| Defines network types. More... | |
| enum | NvDsInferFormat { NvDsInferFormat_RGB, NvDsInferFormat_BGR, NvDsInferFormat_GRAY, NvDsInferFormat_RGBA, NvDsInferFormat_BGRx, NvDsInferFormat_Tensor, NvDsInferFormat_Unknown = 0xFFFFFFFF } |
| Defines color formats. More... | |
| enum | NvDsInferTensorOrder { NvDsInferTensorOrder_kNCHW, NvDsInferTensorOrder_kNHWC, NvDsInferTensorOrder_kNC, NvDsInferUffOrder_kNCHW =("Use NvDsInferTensorOrder_kNCHW instead") = NvDsInferTensorOrder_kNCHW, NvDsInferUffOrder_kNHWC =("Use NvDsInferTensorOrder_kNCWH instead") = NvDsInferTensorOrder_kNHWC, NvDsInferUffOrder_kNC =("Use NvDsInferTensorOrder_kNC instead") = NvDsInferTensorOrder_kNC } |
| Defines UFF input layer orders. More... | |
| enum | NvDsInferClusterMode { NVDSINFER_CLUSTER_GROUP_RECTANGLES = 0, NVDSINFER_CLUSTER_DBSCAN, NVDSINFER_CLUSTER_NMS, NVDSINFER_CLUSTER_DBSCAN_NMS_HYBRID, NVDSINFER_CLUSTER_NONE } |
| Enum for clustering mode for detectors. More... | |
| typedef struct _NvDsInferContextInitParams | NvDsInferContextInitParams |
| typedef void(* | NvDsInferContextReturnInputAsyncFunc) (void *data) |
| Defines a callback function type for asynchronously returning the input client buffers to the NvDsInferContext client. More... | |
| typedef struct INvDsInferContext * | NvDsInferContextHandle |
| An opaque pointer type to be used as a handle for a context instance. More... | |
| typedef void(* | NvDsInferContextLoggingFunc) (NvDsInferContextHandle handle, unsigned int uniqueID, NvDsInferLogLevel logLevel, const char *logMessage, void *userCtx) |
| Type declaration for a logging callback. More... | |
| void | NvDsInferContext_ResetInitParams (NvDsInferContextInitParams *initParams) |
| Resets a context parameter structure to default values. More... | |
| NvDsInferContext_GetStatusName is deprecated Use NvDsInferStatus2Str const instead char * | NvDsInferContext_GetStatusName (NvDsInferStatus status) |
| Gets the string name of the status. More... | |
| #define | _PATH_MAX 4096 |
| Maximum length of a file path parameter. More... | |
| #define | _MAX_CHANNELS 4 |
| Defines the maximum number of channels supported by the API for image input layers. More... | |
| #define | _MAX_STR_LENGTH 1024 |
| Defines the maximum length of string parameters. More... | |
| #define | NVDSINFER_MAX_BATCH_SIZE 1024 |
| Defines the maximum batch size supported by nvdsinfer. More... | |
| #define | NVDSINFER_MIN_OUTPUT_BUFFERPOOL_SIZE 2 |
| Defines the minimum number of sets of output buffers that must be allocated. More... | |
| #define | NvDsInferUffOrder |
NvDsInferContext API C-interface | |
This section describes the C interface for the NvDsInferContext class. | |
| NvDsInferStatus | NvDsInferContext_Create (NvDsInferContextHandle *handle, NvDsInferContextInitParams *initParams, void *userCtx, NvDsInferContextLoggingFunc logFunc) |
| Creates a new NvDsInferContext object with specified initialization parameters. More... | |
| void | NvDsInferContext_Destroy (NvDsInferContextHandle handle) |
| Destroys an NvDsInferContext instance and releases its resources. More... | |
| NvDsInferStatus | NvDsInferContext_QueueInputBatch (NvDsInferContextHandle handle, NvDsInferContextBatchInput *batchInput) |
| Queues a batch of input frames for preprocessing and inferencing. More... | |
| NvDsInferStatus | NvDsInferContext_DequeueOutputBatch (NvDsInferContextHandle handle, NvDsInferContextBatchOutput *batchOutput) |
| Dequeues output for a batch of frames. More... | |
| void | NvDsInferContext_ReleaseBatchOutput (NvDsInferContextHandle handle, NvDsInferContextBatchOutput *batchOutput) |
| Frees the memory associated with the batch output and releases the set of host buffers back to the context for reuse. More... | |
| void | NvDsInferContext_GetNetworkInfo (NvDsInferContextHandle handle, NvDsInferNetworkInfo *networkInfo) |
| Gets network input information. More... | |
| unsigned int | NvDsInferContext_GetNumLayersInfo (NvDsInferContextHandle handle) |
| Gets the number of the bound layers of the inference engine in an NvDsInferContext instance. More... | |
| void | NvDsInferContext_FillLayersInfo (NvDsInferContextHandle handle, NvDsInferLayerInfo *layersInfo) |
| Fills an input vector with information about all of the bound layers of the inference engine in an NvDsInferContext instance. More... | |
| const char * | NvDsInferContext_GetLabel (NvDsInferContextHandle handle, unsigned int id, unsigned int value) |
| Gets the string label associated with the class ID for detectors and the attribute ID and attribute value for classifiers. More... | |
| #define _MAX_CHANNELS 4 |
Definition at line 101 of file nvdsinfer_context.h.
| #define _MAX_STR_LENGTH 1024 |
Definition at line 104 of file nvdsinfer_context.h.
| #define _PATH_MAX 4096 |
Definition at line 97 of file nvdsinfer_context.h.
| #define NVDSINFER_MAX_BATCH_SIZE 1024 |
Definition at line 107 of file nvdsinfer_context.h.
| #define NVDSINFER_MIN_OUTPUT_BUFFERPOOL_SIZE 2 |
Definition at line 111 of file nvdsinfer_context.h.
| #define NvDsInferUffOrder |
Definition at line 185 of file nvdsinfer_context.h.
| typedef struct INvDsInferContext* NvDsInferContextHandle |
Definition at line 632 of file nvdsinfer_context.h.
| typedef struct _NvDsInferContextInitParams NvDsInferContextInitParams |
| typedef void(* NvDsInferContextLoggingFunc) (NvDsInferContextHandle handle, unsigned int uniqueID, NvDsInferLogLevel logLevel, const char *logMessage, void *userCtx) |
The callaback log NvDsInferContext messages.
| [in] | handle | The handle of the NvDsInferContext instance that generated the log. |
| [in] | uniqueID | Unique ID of the NvDsInferContext instance that generated the log. |
| [in] | logLevel | Level of the log. |
| [in] | funcName | A pointer to the name of the function that generated the log. |
| [in] | logMessage | A pointer to the log message string. |
| [in] | userCtx | An opaque pointer to the user context, supplied when creating the NvDsInferContext instance. |
Definition at line 650 of file nvdsinfer_context.h.
| typedef void(* NvDsInferContextReturnInputAsyncFunc) (void *data) |
| [in] | data | An opaque pointer provided to the input queueing function through NvDsInferContextBatchInput. |
Definition at line 466 of file nvdsinfer_context.h.
| enum NvDsInferClusterMode |
| Enumerator | |
| NVDSINFER_CLUSTER_GROUP_RECTANGLES | |
| NVDSINFER_CLUSTER_DBSCAN | |
| NVDSINFER_CLUSTER_NMS | |
| NVDSINFER_CLUSTER_DBSCAN_NMS_HYBRID | |
| NVDSINFER_CLUSTER_NONE | |
Definition at line 228 of file nvdsinfer_context.h.
| enum NvDsInferFormat |
Definition at line 156 of file nvdsinfer_context.h.
| enum NvDsInferNetworkMode |
The NvDsInferNetworkMode is aligned with network-level precision options "--fp16","--int8","--noTF32" and "--best" for trtexec. Please refer to https://docs.nvidia.com/deeplearning/tensorrt/developer-guide/index.html#trtexec-flags
| Enumerator | |
| NvDsInferNetworkMode_FP32 | |
| NvDsInferNetworkMode_INT8 | |
| NvDsInferNetworkMode_FP16 | |
| NvDsInferNetworkMode_BEST | |
Definition at line 120 of file nvdsinfer_context.h.
| enum NvDsInferNetworkType |
Definition at line 131 of file nvdsinfer_context.h.
| enum NvDsInferTensorOrder |
| Enumerator | |
| NvDsInferTensorOrder_kNCHW | |
| NvDsInferTensorOrder_kNHWC | |
| NvDsInferTensorOrder_kNC | |
| NvDsInferUffOrder_kNCHW | |
| NvDsInferUffOrder_kNHWC | |
| NvDsInferUffOrder_kNC | |
Definition at line 176 of file nvdsinfer_context.h.
| NvDsInferStatus NvDsInferContext_Create | ( | NvDsInferContextHandle * | handle, |
| NvDsInferContextInitParams * | initParams, | ||
| void * | userCtx, | ||
| NvDsInferContextLoggingFunc | logFunc | ||
| [out] | handle | A pointer to an NvDsInferContext handle. |
| [in] | initParams | A pointer to a parameter structure to be used to initialize the context. |
| [in] | userCtx | A pointer to an opaque user context, with callbacks, generated by the NvDsInferContext instance. |
| [in] | logFunc | A log callback for the instance. |
| NvDsInferStatus NvDsInferContext_DequeueOutputBatch | ( | NvDsInferContextHandle | handle, |
| NvDsInferContextBatchOutput * | batchOutput | ||
| [in] | handle | A handle to an NvDsInferContext instance. |
| [in,out] | batchOutput | A reference to the batch output structure to which output is to be appended. |
| void NvDsInferContext_Destroy | ( | NvDsInferContextHandle | handle | ) |
| [in] | handle | The handle to the NvDsInferContext instance to be destroyed. |
| void NvDsInferContext_FillLayersInfo | ( | NvDsInferContextHandle | handle, |
| NvDsInferLayerInfo * | layersInfo | ||
The size of the array must be at least the value returned by NvDsInferContext_GetNumLayersInfo().
| [in,out] | layersInfo | A pointer to an array of NvDsInferLayerInfo structures to be filled by the function. |
| const char* NvDsInferContext_GetLabel | ( | NvDsInferContextHandle | handle, |
| unsigned int | id, | ||
| unsigned int | value | ||
The string is owned by the context; the caller may not modify or free it.
| [in] | id | Class ID for detectors, or attribute ID for classifiers. |
| [in] | value | Attribute value for classifiers; set to 0 for detectors. |
| void NvDsInferContext_GetNetworkInfo | ( | NvDsInferContextHandle | handle, |
| NvDsInferNetworkInfo * | networkInfo | ||
| [in,out] | networkInfo | A pointer to an NvDsInferNetworkInfo structure. |
| unsigned int NvDsInferContext_GetNumLayersInfo | ( | NvDsInferContextHandle | handle | ) |
| NvDsInferContext_GetStatusName is deprecated Use NvDsInferStatus2Str const instead char* NvDsInferContext_GetStatusName | ( | NvDsInferStatus | status | ) |
| [in] | status | An inference status code. |
| NvDsInferStatus NvDsInferContext_QueueInputBatch | ( | NvDsInferContextHandle | handle, |
| NvDsInferContextBatchInput * | batchInput | ||
| [in] | batchInput | A reference to a batch input structure. |
| void NvDsInferContext_ReleaseBatchOutput | ( | NvDsInferContextHandle | handle, |
| [in] | batchOutput | A pointer to an NvDsInferContextBatchOutput structure filled by NvDsInferContext_DequeueOutputBatch(). |
| void NvDsInferContext_ResetInitParams | ( | NvDsInferContextInitParams * | initParams | ) |
| [in] | initParams | A pointer to a context parameter structure. |
