NvDsInferContextBatchOutput Struct Reference
Holds the output for all of the frames in a batch (an array of frame), and related buffer information.
Definition at line 640 of file sources/includes/nvdsinfer_context.h.
Collaboration diagram for NvDsInferContextBatchOutput:
Data Fields
NvDsInferFrameOutputframes
 Holds a pointer to an array of outputs for each frame in the batch. More...
unsigned int numFrames
 Holds the number of elements in frames. More...
void ** outputDeviceBuffers
 Holds a pointer to an array of pointers to output device buffers for this batch. More...
unsigned int numOutputDeviceBuffers
 Holds the number of elements in *outputDeviceBuffers. More...
void ** hostBuffers
 Holds a pointer to an array of pointers to host buffers for this batch. More...
unsigned int numHostBuffers
 Holds the number of elements in hostBuffers. More...
void * priv
 Holds a private context pointer for the set of output buffers. More...
Field Documentation
◆ frames
NvDsInferFrameOutput * NvDsInferContextBatchOutput::frames
Definition at line 643 of file sources/includes/nvdsinfer_context.h.
◆ hostBuffers
void ** NvDsInferContextBatchOutput::hostBuffers
The array elements are set by
Definition at line 655 of file sources/includes/nvdsinfer_context.h.
◆ numFrames
unsigned int NvDsInferContextBatchOutput::numFrames
Definition at line 645 of file sources/includes/nvdsinfer_context.h.
◆ numHostBuffers
unsigned int NvDsInferContextBatchOutput::numHostBuffers
Definition at line 657 of file sources/includes/nvdsinfer_context.h.
◆ numOutputDeviceBuffers
unsigned int NvDsInferContextBatchOutput::numOutputDeviceBuffers
Definition at line 651 of file sources/includes/nvdsinfer_context.h.
◆ outputDeviceBuffers
void ** NvDsInferContextBatchOutput::outputDeviceBuffers
Definition at line 649 of file sources/includes/nvdsinfer_context.h.
◆ priv
void * NvDsInferContextBatchOutput::priv
Definition at line 660 of file sources/includes/nvdsinfer_context.h.
