NvDsInferDetectionParams Struct Reference
Holds detection and bounding box grouping parameters.
Definition at line 194 of file sources/includes/nvdsinfer_context.h.
Data Fields
union {
   float   preClusterThreshold
 Holds the bounding box detection threshold to be applied prior to clustering operation. More...
float postClusterThreshold
 Hold the bounding box detection threshold to be applied post clustering operation. More...
float eps
 Holds the epsilon to control merging of overlapping boxes. More...
int minBoxes
 Holds the minimum number of boxes in a cluster to be considered an object during grouping using DBSCAN. More...
int groupThreshold
 Holds the minimum number boxes in a cluster to be considered an object during grouping using OpenCV groupRectangles. More...
float minScore
 Minimum score in a cluster for the cluster to be considered an object during grouping. More...
float nmsIOUThreshold
 IOU threshold to be used with NMS mode of clustering. More...
int topK
 Number of objects with objects to be filtered in the decensding order of probability. More...
union {
Field Documentation
◆ @20
union { ... }
◆ @60
union { ... }
◆ eps
float NvDsInferDetectionParams::eps
Refer to OpenCV groupRectangles and DBSCAN documentation for more information on epsilon.
Definition at line 209 of file sources/includes/nvdsinfer_context.h.
◆ groupThreshold
int NvDsInferDetectionParams::groupThreshold
Definition at line 215 of file sources/includes/nvdsinfer_context.h.
◆ minBoxes
int NvDsInferDetectionParams::minBoxes
Definition at line 212 of file sources/includes/nvdsinfer_context.h.
◆ minScore
float NvDsInferDetectionParams::minScore
Different clustering may cause the algorithm to use different scores.
Definition at line 219 of file sources/includes/nvdsinfer_context.h.
◆ nmsIOUThreshold
float NvDsInferDetectionParams::nmsIOUThreshold
Definition at line 221 of file sources/includes/nvdsinfer_context.h.
◆ postClusterThreshold
float NvDsInferDetectionParams::postClusterThreshold
Definition at line 205 of file sources/includes/nvdsinfer_context.h.
◆ preClusterThreshold
float NvDsInferDetectionParams::preClusterThreshold
Definition at line 200 of file sources/includes/nvdsinfer_context.h.
◆ topK
int NvDsInferDetectionParams::topK
Definition at line 224 of file sources/includes/nvdsinfer_context.h.
