Holds information about one parsed object and instance mask from a detector's output.
Definition at line 176 of file sources/includes/nvdsinfer.h.
Data Fields | |
| unsigned int | classId |
| Holds the ID of the class to which the object belongs. More... | |
| float | left |
| Holds the horizontal offset of the bounding box shape for the object. More... | |
| float | top |
| Holds the vertical offset of the object's bounding box. More... | |
| float | width |
| Holds the width of the object's bounding box. More... | |
| float | height |
| Holds the height of the object's bounding box. More... | |
| float | detectionConfidence |
| Holds the object detection confidence level; must in the range [0.0,1.0]. More... | |
| float * | mask |
| Holds object segment mask. More... | |
| unsigned int | mask_width |
| Holds width of mask. More... | |
| unsigned int | mask_height |
| Holds height of mask. More... | |
| unsigned int | mask_size |
| Holds size of mask in bytes. More... | |
| unsigned int NvDsInferInstanceMaskInfo::classId |
Definition at line 179 of file sources/includes/nvdsinfer.h.
| float NvDsInferInstanceMaskInfo::detectionConfidence |
Definition at line 192 of file sources/includes/nvdsinfer.h.
| float NvDsInferInstanceMaskInfo::height |
Definition at line 188 of file sources/includes/nvdsinfer.h.
| float NvDsInferInstanceMaskInfo::left |
Definition at line 182 of file sources/includes/nvdsinfer.h.
| float * NvDsInferInstanceMaskInfo::mask |
Definition at line 195 of file sources/includes/nvdsinfer.h.
| unsigned int NvDsInferInstanceMaskInfo::mask_height |
Definition at line 199 of file sources/includes/nvdsinfer.h.
| unsigned int NvDsInferInstanceMaskInfo::mask_size |
Definition at line 201 of file sources/includes/nvdsinfer.h.
| unsigned int NvDsInferInstanceMaskInfo::mask_width |
Definition at line 197 of file sources/includes/nvdsinfer.h.
| float NvDsInferInstanceMaskInfo::top |
Definition at line 184 of file sources/includes/nvdsinfer.h.
| float NvDsInferInstanceMaskInfo::width |
Definition at line 186 of file sources/includes/nvdsinfer.h.
