Holds information about one layer in the model.
Definition at line 91 of file nvdsinfer.h.
Data Fields | |
| NvDsInferDataType | dataType |
| Holds the data type of the layer. More... | |
| union { | |
| NvDsInferDims inferDims | |
| Holds the dimensions of the layer. More... | |
| int | bindingIndex |
| Holds the TensorRT binding index of the layer. More... | |
| const char * | layerName |
| Holds the name of the layer. More... | |
| void * | buffer |
| Holds a pointer to the buffer for the layer data. More... | |
| int | isInput |
| Holds a Boolean; true if the layer is an input layer, or false if an output layer. More... | |
| union { ... } |
| int NvDsInferLayerInfo::bindingIndex |
Definition at line 101 of file nvdsinfer.h.
| void* NvDsInferLayerInfo::buffer |
Definition at line 105 of file nvdsinfer.h.
Referenced by deepstream::TensorMetaParser::handleData().
| NvDsInferDataType NvDsInferLayerInfo::dataType |
Definition at line 94 of file nvdsinfer.h.
| NvDsInferDims NvDsInferLayerInfo::inferDims |
Definition at line 97 of file nvdsinfer.h.
| int NvDsInferLayerInfo::isInput |
Definition at line 108 of file nvdsinfer.h.
| const char* NvDsInferLayerInfo::layerName |
Definition at line 103 of file nvdsinfer.h.
