NvDsInferObject Struct Reference
Holds information about one detected object.
Holds the information about one detected object.
Definition at line 533 of file sources/includes/nvdsinfer_context.h.
Data Fields
float left
 Holds the object's offset from the left boundary of the frame. More...
float top
 Holds the object's offset from the top boundary of the frame. More...
float width
 Holds the object's width. More...
float height
 Holds the object's height. More...
int classIndex
 Holds the index for the object's class. More...
char * label
 Holds a pointer to a string containing a label for the object. More...
float confidence
float * mask
unsigned int mask_width
 Holds width of mask. More...
unsigned int mask_height
 Holds height of mask. More...
unsigned int mask_size
 Holds size of mask in bytes. More...
float rotation_angle
 Holds the rotation angle in radians for oriented bounding boxes (OBB). More...
Field Documentation
◆ classIndex
int NvDsInferObject::classIndex
Definition at line 544 of file sources/includes/nvdsinfer_context.h.
◆ confidence
float NvDsInferObject::confidence
Definition at line 548 of file sources/includes/nvdsinfer_context.h.
◆ height
float NvDsInferObject::height
Object height.
Definition at line 542 of file sources/includes/nvdsinfer_context.h.
◆ label
char * NvDsInferObject::label
Definition at line 546 of file sources/includes/nvdsinfer_context.h.
◆ left
float NvDsInferObject::left
Offset from the left boundary of the frame.
Definition at line 536 of file sources/includes/nvdsinfer_context.h.
◆ mask
float * NvDsInferObject::mask
Definition at line 550 of file sources/includes/nvdsinfer_context.h.
◆ mask_height
unsigned int NvDsInferObject::mask_height
Definition at line 554 of file sources/includes/nvdsinfer_context.h.
◆ mask_size
unsigned int NvDsInferObject::mask_size
Definition at line 556 of file sources/includes/nvdsinfer_context.h.
◆ mask_width
unsigned int NvDsInferObject::mask_width
Definition at line 552 of file sources/includes/nvdsinfer_context.h.
◆ rotation_angle
float NvDsInferObject::rotation_angle
0.0 indicates axis-aligned bounding box.
Definition at line 559 of file sources/includes/nvdsinfer_context.h.
◆ top
float NvDsInferObject::top
Offset from the top boundary of the frame.
Definition at line 538 of file sources/includes/nvdsinfer_context.h.
◆ width
float NvDsInferObject::width
Object width.
Definition at line 540 of file sources/includes/nvdsinfer_context.h.
The documentation for this struct was generated from the following files:
