Holds information about one parsed object from a detector's output.
Definition at line 143 of file nvdsinfer.h.
Data Fields | |
unsigned int | classId |
Holds the ID of the class to which the object belongs. More... | |
float | left |
Holds the horizontal offset of the bounding box shape for the object. More... | |
float | top |
Holds the vertical offset of the object's bounding box. More... | |
float | width |
Holds the width of the object's bounding box. More... | |
float | height |
Holds the height of the object's bounding box. More... | |
float | detectionConfidence |
Holds the object detection confidence level; must in the range [0.0,1.0]. More... | |
unsigned int NvDsInferObjectDetectionInfo::classId |
Definition at line 146 of file nvdsinfer.h.
float NvDsInferObjectDetectionInfo::detectionConfidence |
Definition at line 159 of file nvdsinfer.h.
float NvDsInferObjectDetectionInfo::height |
Definition at line 155 of file nvdsinfer.h.
float NvDsInferObjectDetectionInfo::left |
Definition at line 149 of file nvdsinfer.h.
float NvDsInferObjectDetectionInfo::top |
Definition at line 151 of file nvdsinfer.h.
float NvDsInferObjectDetectionInfo::width |
Definition at line 153 of file nvdsinfer.h.
