7.1 Release
NvDsInferSegmentationOutput Struct Reference
Holds the information parsed from segmentation network output for one frame.
Holds information parsed from segmentation network output for one frame.
Definition at line 75 of file infer_post_datatypes.h.
Data Fields
unsigned int width
 Width of the output. More...
unsigned int height
 Height of the output. More...
unsigned int classes
 Number of classes supported by the network. More...
int * class_map
 Pointer to the array for 2D pixel class map. More...
float * class_probability_map
 Pointer to the raw array containing the probabilities. More...
Field Documentation
◆ class_map
int * NvDsInferSegmentationOutput::class_map
Holds a pointer to an array for the 2D pixel class map.
The output for pixel (x,y) will be at index (y * width + x).
The output for pixel (x,y) is at index (y*width+x).
Definition at line 84 of file infer_post_datatypes.h.
◆ class_probability_map
float * NvDsInferSegmentationOutput::class_probability_map
Holds a pointer to an array containing raw probabilities.
The probability for class c and pixel (x,y) will be at index (c * width *height + y * width + x).
The probability for class c and pixel (x,y) is at index (c*width*height + y*width+x).
Definition at line 88 of file infer_post_datatypes.h.
◆ classes
unsigned int NvDsInferSegmentationOutput::classes
Holds the number of classes supported by the network.
Definition at line 81 of file infer_post_datatypes.h.
◆ height
unsigned int NvDsInferSegmentationOutput::height
Holds the height of the output.
Same as network height.
Definition at line 79 of file infer_post_datatypes.h.
◆ width
unsigned int NvDsInferSegmentationOutput::width
Holds the width of the output.
Same as network width.
Definition at line 77 of file infer_post_datatypes.h.
The documentation for this struct was generated from the following files:
