7.1 Release
NvDsInferTensorMeta Struct Reference
Holds the raw tensor output information for one frame / one object.
The "nvinfer" plugins adds this meta when the "output-tensor-meta" property of the element instance is set to TRUE.
This meta data is added as NvDsUserMeta to the frame_user_meta_list of the corresponding frame_meta or object_user_meta_list of the corresponding object with the meta_type set to NVDSINFER_TENSOR_OUTPUT_META.
Definition at line 72 of file gstnvdsinfer.h.
Collaboration diagram for NvDsInferTensorMeta:
Data Fields
guint unique_id
 Unique ID of the gst-nvinfer instance which attached this meta. More...
guint num_output_layers
 Number of bound output layers. More...
NvDsInferLayerInfooutput_layers_info
 Pointer to the array containing information for the bound output layers. More...
void ** out_buf_ptrs_host
 Array of pointers to the output host buffers for the batch / frame / object. More...
void ** out_buf_ptrs_dev
 Array of pointers to the output device buffers for the batch / frame / object. More...
gint gpu_id
 GPU device ID on which the device buffers have been allocated. More...
void * priv_data
 Private data used for the meta producer's internal memory management. More...
NvDsInferNetworkInfo network_info
 Network information for the model specified for the nvinfer element instance. More...
gboolean maintain_aspect_ratio
 Whether aspect ratio was maintained while scaling to network resolution. More...
gboolean symmetric_padding
 Whether symmetric padding was maintained while scaling to network resolution valid only when maintain_aspect_ratio is true. More...
Field Documentation
◆ gpu_id
gint NvDsInferTensorMeta::gpu_id
Definition at line 87 of file gstnvdsinfer.h.
◆ maintain_aspect_ratio
gboolean NvDsInferTensorMeta::maintain_aspect_ratio
Definition at line 93 of file gstnvdsinfer.h.
◆ network_info
NvDsInferNetworkInfo NvDsInferTensorMeta::network_info
Definition at line 91 of file gstnvdsinfer.h.
◆ num_output_layers
guint NvDsInferTensorMeta::num_output_layers
Definition at line 77 of file gstnvdsinfer.h.
◆ out_buf_ptrs_dev
void** NvDsInferTensorMeta::out_buf_ptrs_dev
Definition at line 85 of file gstnvdsinfer.h.
◆ out_buf_ptrs_host
void** NvDsInferTensorMeta::out_buf_ptrs_host
Definition at line 83 of file gstnvdsinfer.h.
◆ output_layers_info
NvDsInferLayerInfo* NvDsInferTensorMeta::output_layers_info
Size of the array will be equal to num_output_layers. Pointers inside the NvDsInferLayerInfo structure are not valid for this array.
Definition at line 81 of file gstnvdsinfer.h.
◆ priv_data
void* NvDsInferTensorMeta::priv_data
Definition at line 89 of file gstnvdsinfer.h.
◆ symmetric_padding
gboolean NvDsInferTensorMeta::symmetric_padding
Definition at line 97 of file gstnvdsinfer.h.
◆ unique_id
guint NvDsInferTensorMeta::unique_id
Definition at line 75 of file gstnvdsinfer.h.
