tensor meta containing prepared tensor and related info inside preprocess user meta which is attached at batch level
Definition at line 40 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
Data Fields | |
void * | raw_tensor_buffer |
raw tensor buffer preprocessed for infer More... | |
guint64 | buffer_size |
size of raw tensor buffer More... | |
std::vector< int > | tensor_shape |
raw tensor buffer shape More... | |
NvDsDataType | data_type |
model datatype for which tensor prepared More... | |
std::string | tensor_name |
to be same as model input layer name More... | |
guint | gpu_id |
gpu-id on which tensor prepared More... | |
void * | private_data |
pointer to buffer from tensor pool More... | |
guint | meta_id |
meta id for differentiating between multiple tensor meta from same gst buffer,for the case when sum of roi's exceeds the batch size More... | |
gboolean | maintain_aspect_ratio |
parameter to inform whether aspect ratio is maintained in the preprocess tensor More... | |
