Loading [MathJax]/extensions/tex2jax.js
8.0 Release
NvDsPreProcess Plugin
Defines an API for the GStreamer NvDsPreProcess plugin.
Defines an API for the GStreamer NvDsPreProcess custom lib.
Defines an API for the GStreamer NvDsPreProcess custom lib implementation.
Data Structures
struct  CustomTransformParams
 custom transformation parameter for calling nvbufsurftransform api for scaling and converting the ROIs to the network resolutions to be used by custom lib. More...
struct  NvDsPreProcessTensorParams
 Holds model parameters for tensor preparation. More...
struct  NvDsPreProcessNetworkSize
 Holds information about the model network. More...
struct  CustomSeqProcTensorParams
 Tensor params for Custom sequence processing for 3d conv network. More...
struct  CustomTensorParams
 Tensor params passed to custom library for tensor preparation. More...
struct  CustomInitParams
 Custom Initialization parameter for custom library. More...
struct  NvDsPreProcessCustomBuf
 Custom Buffer passed to the custom lib for preparing tensor. More...
class  NvDsPreProcessAcquirer
 class for acquiring and releasing a buffer from tensor pool by custom lib. More...
struct  NvDsPreProcessUnit
 A preprocess unit for processing which can be Frame/ROI. More...
struct  NvDsPreProcessBatch
 Holds information about the batch of frames to be inferred. More...
struct  NvDsPreProcessTensorMeta
 tensor meta containing prepared tensor and related info inside preprocess user meta which is attached at batch level More...
struct  GstNvDsPreProcessBatchMeta
 preprocess meta as a user meta which is attached at batch level More...
Macros
#define _PATH_MAX   4096
 Maximum file path length. More...
#define NVDSPREPROCESS_USER_CONFIGS_PIXEL_NORMALIZATION_FACTOR   "pixel-normalization-factor"
 pixel-normalization-factor config parameter More...
#define NVDSPREPROCESS_USER_CONFIGS_MEAN_FILE   "mean-file"
 mean-file config parameter More...
#define NVDSPREPROCESS_USER_CONFIGS_OFFSETS   "offsets"
 offsets config parameter More...
Typedefs
typedef struct CustomCtx CustomCtx
 Context for custom library. More...
typedef void(* NvDsPreProcessConvertFcnHalf) (half *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
 Function pointer type to which any of the NvDsPreProcessConvert functions can be assigned. More...
typedef void(* NvDsPreProcessConvertFcn) (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Enumerations
enum  NvDsPreProcessStatus {
  NVDSPREPROCESS_SUCCESS = 0,
  NVDSPREPROCESS_CONFIG_FAILED,
  NVDSPREPROCESS_CUSTOM_LIB_FAILED,
  NVDSPREPROCESS_CUSTOM_TRANSFORMATION_FAILED,
  NVDSPREPROCESS_CUSTOM_TENSOR_FAILED,
  NVDSPREPROCESS_INVALID_PARAMS,
  NVDSPREPROCESS_OUTPUT_PARSING_FAILED,
  NVDSPREPROCESS_CUDA_ERROR,
  NVDSPREPROCESS_TENSORRT_ERROR,
  NVDSPREPROCESS_RESOURCE_ERROR,
  NVDSPREPROCESS_TENSOR_NOT_READY,
 Enum for the status codes returned by NvDsPreProcessImpl. More...
enum  NvDsPreProcessNetworkInputOrder {
  NvDsPreProcessNetworkInputOrder_kNCHW = 0,
  NvDsPreProcessNetworkInputOrder_kNHWC,
  NvDsPreProcessNetworkInputOrder_CUSTOM,
 Enum for the network input order according to which network shape will be provided to prepare raw tensor for inferencing. More...
enum  NvDsPreProcessFormat {
  NvDsPreProcessFormat_RGB,
  NvDsPreProcessFormat_BGR,
  NvDsPreProcessFormat_GRAY,
  NvDsPreProcessFormat_RGBA,
  NvDsPreProcessFormat_BGRx,
  NvDsPreProcessFormat_Tensor,
  NvDsPreProcessFormat_Unknown = 0xFFFFFFFF,
 Defines model color formats. More...
Functions
void NvDsPreProcessConvert_C3ToP3Float (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
 Converts an input packed 3 channel buffer of width x height resolution into an planar 3-channel float buffer of width x height resolution. More...
void NvDsPreProcessConvert_C3ToL3Float (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
 Converts an input packed 3 channel buffer of width x height resolution into an linear 3-channel float buffer of width x height resolution. More...
void NvDsPreProcessConvert_C4ToP3Float (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void NvDsPreProcessConvert_C4ToP3Half (half *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
 Converts an input packed 3 channel buffer of width x height resolution into an planar 3-channel half buffer of width x height resolution. More...
void NvDsPreProcessConvert_C4ToL3Float (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void NvDsPreProcessConvert_C3ToP3RFloat (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
 Converts an input packed 3 channel buffer of width x height resolution into an planar 3-channel float buffer of width x height resolution with plane order reversed. More...
void NvDsPreProcessConvert_C3ToL3RFloat (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
 Converts an input packed 3 channel buffer of width x height resolution into an linear 3-channel float buffer of width x height resolution with plane order reversed. More...
void NvDsPreProcessConvert_C4ToP3RHalf (half *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
 Converts an input packed 4 channel buffer of width x height resolution into an planar 3-channel float buffer of width x height resolution with plane order reversed. More...
void NvDsPreProcessConvert_C4ToP3RFloat (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void NvDsPreProcessConvert_C4ToL3RFloat (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
 Converts an input packed 4 channel buffer of width x height resolution into an linear 3-channel float buffer of width x height resolution with plane order reversed. More...
void NvDsPreProcessConvert_C1ToP1Float (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
 Converts an 1 channel UINT8 input of width x height resolution into an 1 channel float buffer of width x height resolution. More...
void NvDsPreProcessConvert_FtFTensor (float *outBuffer, float *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
NvDsPreProcessStatus CustomTransformation (NvBufSurface *in_surf, NvBufSurface *out_surf, CustomTransformParams &params)
 Custom transformation function for group. More...
NvDsPreProcessStatus CustomAsyncTransformation (NvBufSurface *in_surf, NvBufSurface *out_surf, CustomTransformParams &params)
 Custom Asynchronus group transformation function. More...
NvDsPreProcessStatus CustomTensorPreparation (CustomCtx *ctx, NvDsPreProcessBatch *batch, NvDsPreProcessCustomBuf *&buf, CustomTensorParams &tensorParam, NvDsPreProcessAcquirer *acquirer)
 Custom tensor preparation function for NCHW/NHWC network order. More...
CustomCtxinitLib (CustomInitParams initparams)
 custom library initialization function More...
void deInitLib (CustomCtx *ctx)
 custom library deinitialization function More...
Variables
void * NvDsPreProcessTensorMeta::raw_tensor_buffer
 raw tensor buffer preprocessed for infer More...
guint64 NvDsPreProcessTensorMeta::buffer_size
 size of raw tensor buffer More...
std::vector< int > NvDsPreProcessTensorMeta::tensor_shape
 raw tensor buffer shape More...
NvDsDataType NvDsPreProcessTensorMeta::data_type
 model datatype for which tensor prepared More...
std::string NvDsPreProcessTensorMeta::tensor_name
 to be same as model input layer name More...
guint NvDsPreProcessTensorMeta::gpu_id
 gpu-id on which tensor prepared More...
void * NvDsPreProcessTensorMeta::private_data
 pointer to buffer from tensor pool More...
guint NvDsPreProcessTensorMeta::meta_id
 meta id for differentiating between multiple tensor meta from same gst buffer,for the case when sum of roi's exceeds the batch size More...
gboolean NvDsPreProcessTensorMeta::maintain_aspect_ratio
 parameter to inform whether aspect ratio is maintained in the preprocess tensor More...
std::vector< guint64 > GstNvDsPreProcessBatchMeta::target_unique_ids
 target unique ids for which meta is prepared More...
NvDsPreProcessTensorMetaGstNvDsPreProcessBatchMeta::tensor_meta
 pointer to tensor meta More...
std::vector< NvDsRoiMetaGstNvDsPreProcessBatchMeta::roi_vector
 list of roi vectors per batch More...
void * GstNvDsPreProcessBatchMeta::private_data
 pointer to buffer from scaling pool More...
◆ _PATH_MAX
Definition at line 36 of file nvdspreprocess_lib.h.
◆ NVDSPREPROCESS_USER_CONFIGS_MEAN_FILE
Definition at line 42 of file nvdspreprocess_lib.h.
◆ NVDSPREPROCESS_USER_CONFIGS_OFFSETS
Definition at line 45 of file nvdspreprocess_lib.h.
◆ NVDSPREPROCESS_USER_CONFIGS_PIXEL_NORMALIZATION_FACTOR
Definition at line 39 of file nvdspreprocess_lib.h.
Typedef Documentation
◆ CustomCtx [1/2]
Definition at line 44 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_interface.h.
◆ CustomCtx [2/2]
Definition at line 44 of file includes/nvdspreprocess_interface.h.
◆ NvDsPreProcessConvertFcn
Definition at line 402 of file nvdspreprocess_conversion.h.
◆ NvDsPreProcessConvertFcnHalf
Definition at line 388 of file nvdspreprocess_conversion.h.
◆ NvDsPreProcessFormat [1/2]
Enumerator
Specifies 24-bit interleaved R-G-B format.
Specifies 24-bit interleaved B-G-R format.
Specifies 8-bit Luma format.
Specifies 32-bit interleaved R-G-B-A format.
Specifies 32-bit interleaved B-G-R-x format.
NCHW planar.
NCHW planar.
Definition at line 94 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_interface.h.
◆ NvDsPreProcessFormat [2/2]
Enumerator
NCHW planar.
NCHW planar.
Definition at line 94 of file includes/nvdspreprocess_interface.h.
◆ NvDsPreProcessNetworkInputOrder [1/2]
Enumerator
Specifies NCHW network input order.
Specifies NHWC network input order.
Specifies any other custom input order handled by custom lib.
Definition at line 81 of file includes/nvdspreprocess_interface.h.
◆ NvDsPreProcessNetworkInputOrder [2/2]
Enumerator
Definition at line 81 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_interface.h.
◆ NvDsPreProcessStatus [1/2]
Enumerator
NvDsPreprocess operation succeeded.
Failed to configure the tensor_impl instance possibly due to an erroneous initialization property.
Custom Library interface implementation failed.
Custom Group Transformation failed.
Custom Tensor Preparation failed.
Invalid parameters were supplied.
Output parsing failed.
CUDA error was encountered.
TensorRT interface failed.
Resource error was encountered.
Tensor Yet not ready to be attached as meta.
Definition at line 49 of file includes/nvdspreprocess_interface.h.
◆ NvDsPreProcessStatus [2/2]
Enumerator
Definition at line 49 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_interface.h.
Function Documentation
◆ CustomAsyncTransformation()
NvDsPreProcessStatus CustomAsyncTransformation ( NvBufSurface in_surf,
NvBufSurface out_surf,
CustomTransformParams params
◆ CustomTensorPreparation()
NvDsPreProcessStatus CustomTensorPreparation ( CustomCtx ctx,
NvDsPreProcessBatch batch,
NvDsPreProcessCustomBuf *&  buf,
CustomTensorParams tensorParam,
NvDsPreProcessAcquirer acquirer
◆ CustomTransformation()
NvDsPreProcessStatus CustomTransformation ( NvBufSurface in_surf,
◆ deInitLib()
void deInitLib ( CustomCtx ctx)
◆ initLib()
CustomCtx* initLib ( CustomInitParams  initparams)
◆ NvDsPreProcessConvert_C1ToP1Float()
void NvDsPreProcessConvert_C1ToP1Float ( float *  outBuffer,
unsigned char *  inBuffer,
unsigned int  width,
unsigned int  pitch,
float  scaleFactor,
float *  meanDataBuffer,
cudaStream_t  stream
The input buffer can have a pitch > width . The cuda kernel supports normalization and mean image subtraction.
Parameters
outBufferCuda device buffer for float output. Should be at least (width * height * sizeof(float)) bytes.
inBufferCuda device buffer for UINT8 input. Should be at least (pitch * height) bytes.
widthWidth of the buffers in pixels.
heightHeight of the buffers in pixels.
pitchPitch of the input buffer in bytes.
scaleFactorNormalization factor.
meanDataBufferMean Image Data buffer. Should be at least (width * height * sizeof(float)) bytes.
streamCuda stream identifier.
◆ NvDsPreProcessConvert_C3ToL3Float()
void NvDsPreProcessConvert_C3ToL3Float ( float *  outBuffer,
unsigned int  width,
unsigned int  pitch,
float  scaleFactor,
cudaStream_t  stream
The input buffer can have a pitch > (width * 3). The cuda kernel supports normalization and mean image subtraction.
This kernel can be used for RGB -> RGB and BGR -> BGR conversions.
Parameters
outBufferCuda device buffer for planar float output. Should be at least (width * height * 3 * sizeof(float)) bytes.
inBufferCuda device buffer for packed input. Should be at least (pitch * height) bytes.
meanDataBufferMean Image Data buffer. Should be at least (width * height * 3 * sizeof(float)) bytes.
◆ NvDsPreProcessConvert_C3ToL3RFloat()
void NvDsPreProcessConvert_C3ToL3RFloat ( float *  outBuffer,
unsigned int  width,
unsigned int  pitch,
float  scaleFactor,
cudaStream_t  stream
This kernel can be used for BGR -> RGB and RGB -> BGR conversions.
Parameters
◆ NvDsPreProcessConvert_C3ToP3Float()
void NvDsPreProcessConvert_C3ToP3Float ( float *  outBuffer,
unsigned int  width,
unsigned int  pitch,
float  scaleFactor,
cudaStream_t  stream
Parameters
◆ NvDsPreProcessConvert_C3ToP3RFloat()
void NvDsPreProcessConvert_C3ToP3RFloat ( float *  outBuffer,
unsigned int  width,
unsigned int  pitch,
float  scaleFactor,
cudaStream_t  stream
Parameters
◆ NvDsPreProcessConvert_C4ToL3Float()
void NvDsPreProcessConvert_C4ToL3Float ( float *  outBuffer,
unsigned int  width,
unsigned int  pitch,
float  scaleFactor,
cudaStream_t  stream
This kernel can be used for RGBA -> RGB and BGRx -> BGR conversions.
Parameters
outBufferCuda device buffer for linear float output. Should be at least (width * height * 3 * sizeof(float)) bytes.
◆ NvDsPreProcessConvert_C4ToL3RFloat()
void NvDsPreProcessConvert_C4ToL3RFloat ( float *  outBuffer,
unsigned int  width,
unsigned int  pitch,
float  scaleFactor,
cudaStream_t  stream
This kernel can be used for BGRx -> RGB and RGBA -> BGR conversions.
Parameters
◆ NvDsPreProcessConvert_C4ToP3Float()
void NvDsPreProcessConvert_C4ToP3Float ( float *  outBuffer,
unsigned int  width,
unsigned int  pitch,
float  scaleFactor,
cudaStream_t  stream
Parameters
◆ NvDsPreProcessConvert_C4ToP3Half()
void NvDsPreProcessConvert_C4ToP3Half ( half *  outBuffer,
unsigned int  width,
unsigned int  pitch,
float  scaleFactor,
cudaStream_t  stream
Parameters
outBufferCuda device buffer for planar half output. Should be at least (width * height * 3 * sizeof(half)) bytes.
◆ NvDsPreProcessConvert_C4ToP3RFloat()
void NvDsPreProcessConvert_C4ToP3RFloat ( float *  outBuffer,
unsigned int  width,
unsigned int  pitch,
float  scaleFactor,
cudaStream_t  stream
Parameters
◆ NvDsPreProcessConvert_C4ToP3RHalf()
void NvDsPreProcessConvert_C4ToP3RHalf ( half *  outBuffer,
unsigned int  width,
unsigned int  pitch,
float  scaleFactor,
cudaStream_t  stream
Parameters
outBufferCuda device buffer for planar float output. Should be at least (width * height * 3 * sizeof(half)) bytes.
◆ NvDsPreProcessConvert_FtFTensor()
void NvDsPreProcessConvert_FtFTensor ( float *  outBuffer,
float *  inBuffer,
unsigned int  width,
unsigned int  pitch,
float  scaleFactor,
cudaStream_t  stream
Variable Documentation
◆ buffer_size
Definition at line 46 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
◆ data_type
Definition at line 52 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
◆ gpu_id
Definition at line 58 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
◆ maintain_aspect_ratio
Definition at line 67 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
◆ meta_id
Definition at line 64 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
◆ private_data [1/2]
Definition at line 61 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
◆ private_data [2/2]
Definition at line 86 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
◆ raw_tensor_buffer
Definition at line 43 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
◆ roi_vector
std::vector< NvDsRoiMeta > GstNvDsPreProcessBatchMeta::roi_vector
Definition at line 83 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
◆ target_unique_ids
Definition at line 77 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
◆ tensor_meta
NvDsPreProcessTensorMeta * GstNvDsPreProcessBatchMeta::tensor_meta
Definition at line 80 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
◆ tensor_name
Definition at line 55 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
◆ tensor_shape
Definition at line 49 of file gst-plugins/gst-nvdspreprocess/include/nvdspreprocess_meta.h.
