Specifies metadata concerning ROIs used in nvdspreprocess plugin.
Data Structures | |
| struct | NvDsRoiMeta |
| Holds Information about ROI Metadata. More... | |
Macros | |
| #define | DS_MAX_POLYGON_POINTS 8 |
| max polygon points ; currently not being used More... | |
Typedefs | |
| typedef struct NvBufSurfaceParams | NvBufSurfaceParams |
| DS NvBufSurfaceParams. More... | |
| typedef struct _NvDsFrameMeta | NvDsFrameMeta |
| DS NvDsFrameMeta. More... | |
| typedef struct _NvDsObjectMeta | NvDsObjectMeta |
| DS NvDsObjectMeta. More... | |
| typedef GList | NvDsClassifierMetaList |
| classifier meta list More... | |
| typedef GList | NvDsUserMetaList |
| user meta list More... | |
| typedef struct NvDsRoiMeta | NvDsRoiMeta |
Enumerations | |
| enum | NvDsDataType { NvDsDataType_FP32, NvDsDataType_UINT8, NvDsDataType_INT8, NvDsDataType_UINT32, NvDsDataType_INT32, NvDsDataType_INT64, NvDsDataType_UINT64, NvDsDataType_FP16 } |
| Data type used for model in infer. More... | |
| enum | NvDsUnitType { NvDsUnitType_FullFrame = 0, NvDsUnitType_ROI, NvDsUnitType_Object } |
| Unit Type Fullframe/ROI/Crop Objects. More... | |
Variables | |
| NvOSD_RectParams | NvDsRoiMeta::roi |
| guint | NvDsRoiMeta::roi_polygon [DS_MAX_POLYGON_POINTS][2] |
| NvBufSurfaceParams * | NvDsRoiMeta::converted_buffer |
| NvDsFrameMeta * | NvDsRoiMeta::frame_meta |
| gdouble | NvDsRoiMeta::scale_ratio_x |
| Ratio by which the frame/ROI crop was scaled in horizontal direction Required when scaling co-ordinates/sizes in metadata back to input resolution. More... | |
| gdouble | NvDsRoiMeta::scale_ratio_y |
| Ratio by which the frame/ROI crop was scaled in vertical direction Required when scaling co-ordinates/sizes in metadata back to input resolution. More... | |
| gdouble | NvDsRoiMeta::offset_left |
| offsets in horizontal direction while scaling More... | |
| gdouble | NvDsRoiMeta::offset_top |
| offsets in vertical direction while scaling More... | |
| NvDsClassifierMetaList * | NvDsRoiMeta::classifier_meta_list |
| Holds a pointer to a list of pointers of type NvDsClassifierMeta. More... | |
| NvDsUserMetaList * | NvDsRoiMeta::roi_user_meta_list |
| Holds a pointer to a list of pointers of type NvDsUserMeta. More... | |
| NvDsObjectMeta * | NvDsRoiMeta::object_meta |
| #define DS_MAX_POLYGON_POINTS 8 |
Definition at line 34 of file nvds_roi_meta.h.
| typedef struct NvBufSurfaceParams NvBufSurfaceParams |
Definition at line 37 of file nvds_roi_meta.h.
| typedef GList NvDsClassifierMetaList |
Definition at line 46 of file nvds_roi_meta.h.
| typedef struct _NvDsFrameMeta NvDsFrameMeta |
DS NvDsFrameMeta.
Definition at line 40 of file nvds_roi_meta.h.
| typedef struct _NvDsObjectMeta NvDsObjectMeta |
DS NvDsObjectMeta.
Definition at line 43 of file nvds_roi_meta.h.
| typedef struct NvDsRoiMeta NvDsRoiMeta |
| typedef GList NvDsUserMetaList |
user meta list
Definition at line 49 of file nvds_roi_meta.h.
| enum NvDsDataType |
Definition at line 54 of file nvds_roi_meta.h.
| enum NvDsUnitType |
| Enumerator | |
| NvDsUnitType_FullFrame | Full frames. |
| NvDsUnitType_ROI | Region of Interests (ROIs) |
| NvDsUnitType_Object | object mode |
Definition at line 77 of file nvds_roi_meta.h.
| NvDsClassifierMetaList* NvDsRoiMeta::classifier_meta_list |
Definition at line 121 of file nvds_roi_meta.h.
| NvBufSurfaceParams* NvDsRoiMeta::converted_buffer |
Definition at line 99 of file nvds_roi_meta.h.
| NvDsFrameMeta* NvDsRoiMeta::frame_meta |
Definition at line 102 of file nvds_roi_meta.h.
| NvDsObjectMeta* NvDsRoiMeta::object_meta |
Definition at line 127 of file nvds_roi_meta.h.
| gdouble NvDsRoiMeta::offset_left |
Definition at line 115 of file nvds_roi_meta.h.
| gdouble NvDsRoiMeta::offset_top |
Definition at line 118 of file nvds_roi_meta.h.
| NvOSD_RectParams NvDsRoiMeta::roi |
Definition at line 93 of file nvds_roi_meta.h.
| guint NvDsRoiMeta::roi_polygon[DS_MAX_POLYGON_POINTS][2] |
Definition at line 96 of file nvds_roi_meta.h.
| NvDsUserMetaList* NvDsRoiMeta::roi_user_meta_list |
Definition at line 124 of file nvds_roi_meta.h.
| gdouble NvDsRoiMeta::scale_ratio_x |
Definition at line 107 of file nvds_roi_meta.h.
| gdouble NvDsRoiMeta::scale_ratio_y |
Definition at line 112 of file nvds_roi_meta.h.
