7.1 Release
_GstNvDsAudioAllocatorParams Struct Reference
Definition at line 42 of file gst_nvdsaudio.h.
Data Fields
uint32_t batchSize
 Max size of audio batch. More...
bool isContiguous
 If the memory within a batch is contiguos or not. More...
NvBufAudioLayout layout
NvBufAudioFormat format
uint32_t bpf
 Bytes per frame; the size of a frame; size of one sample * @channels. More...
uint32_t channels
 Number of audio channels. More...
uint32_t rate
 audio sample rate in samples per second More...
uint32_t bufferLength
 The number of audio samples in each buffer of the batch. More...
guint gpuId
NvDsMemType memType
Field Documentation
◆ batchSize
uint32_t _GstNvDsAudioAllocatorParams::batchSize
Definition at line 45 of file gst_nvdsaudio.h.
◆ bpf
uint32_t _GstNvDsAudioAllocatorParams::bpf
Definition at line 51 of file gst_nvdsaudio.h.
◆ bufferLength
uint32_t _GstNvDsAudioAllocatorParams::bufferLength
Definition at line 56 of file gst_nvdsaudio.h.
◆ channels
uint32_t _GstNvDsAudioAllocatorParams::channels
Definition at line 53 of file gst_nvdsaudio.h.
◆ format
NvBufAudioFormat _GstNvDsAudioAllocatorParams::format
Definition at line 50 of file gst_nvdsaudio.h.
◆ gpuId
guint _GstNvDsAudioAllocatorParams::gpuId
Parameters
gpuIdID of the gpu where the batch memory will be allocated.
Definition at line 58 of file gst_nvdsaudio.h.
◆ isContiguous
bool _GstNvDsAudioAllocatorParams::isContiguous
Definition at line 47 of file gst_nvdsaudio.h.
◆ layout
NvBufAudioLayout _GstNvDsAudioAllocatorParams::layout
Definition at line 49 of file gst_nvdsaudio.h.
◆ memType
NvDsMemType _GstNvDsAudioAllocatorParams::memType
Definition at line 59 of file gst_nvdsaudio.h.
◆ rate
uint32_t _GstNvDsAudioAllocatorParams::rate
Definition at line 54 of file gst_nvdsaudio.h.
