_NvDsObjConvexHull Struct Reference
Holds convex hull information.
Definition at line 145 of file sources/includes/nvds_tracker_meta.h.
Data Fields
int * list
 Holds a pointer to a list or array of object information blocks. More...
uint32_t numPointsAllocated
 Holds the number of blocks allocated for the list. More...
uint32_t numPoints
 Holds the number of points in the list. More...
Field Documentation
◆ list
int * _NvDsObjConvexHull::list
Definition at line 148 of file sources/includes/nvds_tracker_meta.h.
◆ numPoints
uint32_t _NvDsObjConvexHull::numPoints
Definition at line 152 of file sources/includes/nvds_tracker_meta.h.
◆ numPointsAllocated
uint32_t _NvDsObjConvexHull::numPointsAllocated
Definition at line 150 of file sources/includes/nvds_tracker_meta.h.
