Tracker Metadata
Specifies metadata concerning tracking.
Data Structures
struct  _NvDsTargetMiscDataFrame
 A single frame of misc data for a given Target. More...
struct  _NvDsTargetMiscDataObject
 All misc data output for a single target. More...
struct  _NvDsTargetMiscDataStream
 All misc targets data for a given stream. More...
struct  _NvDsTargetMiscDataBatch
 Batch of all streams of a given target misc output. More...
struct  _NvDsReidTensorBatch
 ReID tensor of the batch. More...
struct  _NvDsObjConvexHull
 Holds convex hull information. More...
struct  _NvDsObjReid
 Holds Reid Vector information for an object. More...
struct  _NvDsObj3DBbox
 Holds 3D bbox information for an object. More...
Macros
#define MAX_LABEL_SIZE   128
Typedefs
typedef struct _NvDsTargetMiscDataFrame NvDsTargetMiscDataFrame
typedef struct _NvDsTargetMiscDataObject NvDsTargetMiscDataObject
typedef struct _NvDsTargetMiscDataStream NvDsTargetMiscDataStream
typedef struct _NvDsTargetMiscDataBatch NvDsTargetMiscDataBatch
typedef struct _NvDsReidTensorBatch NvDsReidTensorBatch
typedef NvDsTargetMiscDataBatch NvDsTrajectoryBatch
 Batch of trajectory data in all streams. More...
typedef struct _NvDsObjConvexHull NvDsObjConvexHull
typedef struct _NvDsObjReid NvDsObjReid
typedef struct _NvDsObj3DBbox NvDsObj3DBbox
Enumerations
enum  TRACKER_STATE {
  EMPTY = 0,
  ACTIVE = 1,
  INACTIVE = 2,
  TENTATIVE = 3,
  PROJECTED = 4,
  QUASIACTIVE = 5,
  EMPTY = 0,
  ACTIVE = 1,
  INACTIVE = 2,
  TENTATIVE = 3,
  PROJECTED = 4,
  QUASIACTIVE = 5
  EMPTY = 0,
  ACTIVE = 1,
  INACTIVE = 2,
  TENTATIVE = 3,
  PROJECTED = 4,
  QUASIACTIVE = 5,
  EMPTY = 0,
  ACTIVE = 1,
  INACTIVE = 2,
  TENTATIVE = 3,
  PROJECTED = 4,
  QUASIACTIVE = 5
◆ MAX_LABEL_SIZE [1/2]
Definition at line 30 of file sources/includes/nvds_tracker_meta.h.
◆ MAX_LABEL_SIZE [2/2]
Definition at line 30 of file 9.0/sources/includes/nvds_tracker_meta.h.
Typedef Documentation
◆ NvDsObj3DBbox [1/2]
◆ NvDsObj3DBbox [2/2]
◆ NvDsObjConvexHull [1/2]
◆ NvDsObjConvexHull [2/2]
◆ NvDsObjReid [1/2]
◆ NvDsObjReid [2/2]
◆ NvDsReidTensorBatch [1/2]
◆ NvDsReidTensorBatch [2/2]
◆ NvDsTargetMiscDataBatch [1/2]
◆ NvDsTargetMiscDataBatch [2/2]
◆ NvDsTargetMiscDataFrame [1/2]
◆ NvDsTargetMiscDataFrame [2/2]
◆ NvDsTargetMiscDataObject [1/2]
◆ NvDsTargetMiscDataObject [2/2]
◆ NvDsTargetMiscDataStream [1/2]
◆ NvDsTargetMiscDataStream [2/2]
◆ NvDsTrajectoryBatch [1/2]
Definition at line 140 of file sources/includes/nvds_tracker_meta.h.
◆ NvDsTrajectoryBatch [2/2]
Definition at line 140 of file 9.0/sources/includes/nvds_tracker_meta.h.
◆ TRACKER_STATE [1/2]
Enumerator
EMPTY
ACTIVE
\ The corresponding tracker is no longer is in use
INACTIVE
\ tracking is being confirmed by detectors and actively reporting outputs
TENTATIVE
\ tracking is not confirmed or w/ low confidence, so not reporting the outputs, but keep tracking (i.e., Shadow Tracking)
PROJECTED
\ tracking is just started and in a probational period. Waiting to become ACTIVE
QUASIACTIVE
\ tracking is completed, the tracklet is about to be archived, and some projected points are appended at the end of the traclet for re-assoc.
EMPTY
ACTIVE
INACTIVE
TENTATIVE
PROJECTED
QUASIACTIVE
Definition at line 36 of file sources/includes/nvds_tracker_meta.h.
◆ TRACKER_STATE [2/2]
Enumerator
EMPTY
ACTIVE
INACTIVE
TENTATIVE
PROJECTED
QUASIACTIVE
EMPTY
ACTIVE
INACTIVE
TENTATIVE
PROJECTED
QUASIACTIVE
Definition at line 36 of file 9.0/sources/includes/nvds_tracker_meta.h.
