Holds the inference information/history for one object based on it's tracking id.
Definition at line 607 of file post_processor_struct.h.
Data Fields | |
| int | under_inference |
| Boolean indicating if the object is already being inferred on. More... | |
| NvOSD_RectParams | last_inferred_coords |
| Bounding box co-ordinates of the object when it was last inferred on. More... | |
| unsigned long | last_inferred_frame_num |
| Number of the frame in the stream when the object was last inferred on. More... | |
| unsigned long | last_accessed_frame_num |
| Number of the frame in the stream when the object was last accessed. More... | |
| NvDsPostProcessObjectInfo | cached_info |
| Cached object information. More... | |
| NvDsPostProcessObjectInfo _NvDsPostProcessObjectHistory::cached_info |
Definition at line 620 of file post_processor_struct.h.
| unsigned long _NvDsPostProcessObjectHistory::last_accessed_frame_num |
This is useful for clearing stale enteries in map of the object histories and keeping the size of the map in check.
Definition at line 618 of file post_processor_struct.h.
| NvOSD_RectParams _NvDsPostProcessObjectHistory::last_inferred_coords |
Definition at line 612 of file post_processor_struct.h.
| unsigned long _NvDsPostProcessObjectHistory::last_inferred_frame_num |
Definition at line 614 of file post_processor_struct.h.
| int _NvDsPostProcessObjectHistory::under_inference |
Definition at line 610 of file post_processor_struct.h.
