On-Screen Display Manager
Defines the NvOSD library to be used to draw rectangles and text over the frame.
Data Structures
struct  _NvBbox_Coords
 Holds unclipped bounding box coordinates of the object. More...
struct  _NvOSD_ColorParams
 Holds the color parameters of the box or text to be overlayed. More...
struct  _NvOSD_FontParams
 Holds the font parameters of the text to be overlayed. More...
struct  _NvOSD_TextParams
 Holds parameters of text to be overlayed. More...
struct  _NvOSD_Color_info
struct  _NvOSD_RectParams
 Holds the box parameters of the box to be overlayed. More...
struct  _NvOSD_MaskParams
 Holds the mask parameters of the segment to be overlayed. More...
struct  _NvOSD_LineParams
 Holds the box parameters of a line to be overlayed. More...
struct  _NvOSD_ArrowParams
 Holds arrow parameters to be overlaid. More...
struct  _NvOSD_CircleParams
 Holds circle parameters to be overlayed. More...
Typedefs
typedef struct _NvBbox_Coords NvBbox_Coords
typedef struct _NvOSD_ColorParams NvOSD_ColorParams
typedef struct _NvOSD_FontParams NvOSD_FontParams
typedef struct _NvOSD_TextParams NvOSD_TextParams
typedef struct _NvOSD_Color_info NvOSD_Color_info
typedef struct _NvOSD_RectParams NvOSD_RectParams
typedef struct _NvOSD_MaskParams NvOSD_MaskParams
typedef struct _NvOSD_LineParams NvOSD_LineParams
typedef struct _NvOSD_ArrowParams NvOSD_ArrowParams
typedef struct _NvOSD_CircleParams NvOSD_CircleParams
Enumerations
enum  NvOSD_Mode {
  MODE_CPU,
  MODE_GPU,
  MODE_NONE,
  MODE_CPU,
  MODE_GPU,
  MODE_NONE
 Defines modes used to overlay boxes and text. More...
enum  NvOSD_Arrow_Head_Direction {
  START_HEAD,
  END_HEAD,
  BOTH_HEAD,
  START_HEAD,
  END_HEAD,
  BOTH_HEAD
 Specifies arrow head positions. More...
enum  NvOSD_Mode {
  MODE_CPU,
  MODE_GPU,
  MODE_NONE,
  MODE_CPU,
  MODE_GPU,
  MODE_NONE
  START_HEAD,
  END_HEAD,
  BOTH_HEAD,
  START_HEAD,
  END_HEAD,
  BOTH_HEAD
Typedef Documentation
◆ NvBbox_Coords [1/2]
◆ NvBbox_Coords [2/2]
◆ NvOSD_ArrowParams [1/2]
◆ NvOSD_ArrowParams [2/2]
◆ NvOSD_CircleParams [1/2]
◆ NvOSD_CircleParams [2/2]
◆ NvOSD_Color_info [1/2]
◆ NvOSD_Color_info [2/2]
◆ NvOSD_ColorParams [1/2]
◆ NvOSD_ColorParams [2/2]
◆ NvOSD_FontParams [1/2]
◆ NvOSD_FontParams [2/2]
◆ NvOSD_LineParams [1/2]
◆ NvOSD_LineParams [2/2]
◆ NvOSD_MaskParams [1/2]
◆ NvOSD_MaskParams [2/2]
◆ NvOSD_RectParams [1/2]
◆ NvOSD_RectParams [2/2]
◆ NvOSD_TextParams [1/2]
◆ NvOSD_TextParams [2/2]
◆ NvOSD_Arrow_Head_Direction [1/2]
Enumerator
START_HEAD
Specifies an arrow head only at start = 0.
END_HEAD
Specifies an arrow head only at end = 1.
BOTH_HEAD
Specifies arrow heads at both start and end = 2.
START_HEAD
END_HEAD
BOTH_HEAD
Definition at line 53 of file sources/includes/nvll_osd_struct.h.
◆ NvOSD_Arrow_Head_Direction [2/2]
Enumerator
START_HEAD
END_HEAD
BOTH_HEAD
START_HEAD
END_HEAD
BOTH_HEAD
Definition at line 53 of file 9.0/sources/includes/nvll_osd_struct.h.
◆ NvOSD_Mode [1/2]
enum NvOSD_Mode
Enumerator
MODE_CPU
Specifies using the CPU for OSD processing.
Works with RGBA data only
MODE_GPU
Specifies using the GPU for OSD processing.
Currently not implemented.
MODE_NONE
Invalid mode.
Instead GPU mode will be used.
MODE_CPU
MODE_GPU
MODE_NONE
Invalid mode.
Definition at line 42 of file 9.0/sources/includes/nvll_osd_struct.h.
◆ NvOSD_Mode [2/2]
enum NvOSD_Mode
Enumerator
MODE_CPU
MODE_GPU
MODE_NONE
Invalid mode.
MODE_CPU
MODE_GPU
MODE_NONE
Invalid mode.
Definition at line 42 of file sources/includes/nvll_osd_struct.h.
