7.1 Release
_NvDsReidTensorBatch Struct Reference
ReID tensor of the batch.
Definition at line 118 of file nvds_tracker_meta.h.
Data Fields
uint32_t featureSize
 Each target's ReID vector length. More...
uint32_t numFilled
 Number of reid vectors in the batch. More...
float * ptr_host
 ReID vector on CPU. More...
float * ptr_dev
 ReID vector on GPU. More...
void * priv_data
 Pointer to internal buffer pool needed by gst pipelines to return buffers. More...
Field Documentation
◆ featureSize
uint32_t _NvDsReidTensorBatch::featureSize
Definition at line 121 of file nvds_tracker_meta.h.
◆ numFilled
uint32_t _NvDsReidTensorBatch::numFilled
Definition at line 123 of file nvds_tracker_meta.h.
◆ priv_data
void* _NvDsReidTensorBatch::priv_data
Definition at line 129 of file nvds_tracker_meta.h.
◆ ptr_dev
float* _NvDsReidTensorBatch::ptr_dev
ReID vector on GPU.
Definition at line 127 of file nvds_tracker_meta.h.
◆ ptr_host
float* _NvDsReidTensorBatch::ptr_host
ReID vector on CPU.
Definition at line 125 of file nvds_tracker_meta.h.
