_NvDsTargetMiscDataBatch Struct Reference
Batch of all streams of a given target misc output.
Definition at line 107 of file sources/includes/nvds_tracker_meta.h.
Collaboration diagram for _NvDsTargetMiscDataBatch:
Data Fields
NvDsTargetMiscDataStreamlist
 Pointer to array of stream lists. More...
uint32_t numAllocated
 Number of blocks allocated for the list. More...
uint32_t numFilled
 Number of filled blocks in the list. More...
void * priv_data
 Pointer to internal buffer pool needed by gst pipelines to return buffers. More...
Field Documentation
◆ list
NvDsTargetMiscDataStream * _NvDsTargetMiscDataBatch::list
Definition at line 110 of file sources/includes/nvds_tracker_meta.h.
Referenced by deepstream::NvDsKittiDump::generateTrackerPastKittiDump().
◆ numAllocated
uint32_t _NvDsTargetMiscDataBatch::numAllocated
Definition at line 112 of file sources/includes/nvds_tracker_meta.h.
◆ numFilled
uint32_t _NvDsTargetMiscDataBatch::numFilled
Definition at line 114 of file sources/includes/nvds_tracker_meta.h.
◆ priv_data
void * _NvDsTargetMiscDataBatch::priv_data
Definition at line 116 of file sources/includes/nvds_tracker_meta.h.
