_NvDsTargetMiscDataObject Struct Reference
All misc data output for a single target.
Definition at line 70 of file sources/includes/nvds_tracker_meta.h.
Collaboration diagram for _NvDsTargetMiscDataObject:
Data Fields
NvDsTargetMiscDataFramelist
 Pointer to a list per-frame information of the target. More...
uint32_t numObj
 Number of frames this target appreared in the past. More...
uint32_t numAllocated
 Maximum number of frames allocated. More...
uint64_t uniqueId
 Target tracking id. More...
uint16_t classId
 Target class id. More...
char objLabel [MAX_LABEL_SIZE]
 An array of the string describing the target class. More...
Field Documentation
◆ classId
uint16_t _NvDsTargetMiscDataObject::classId
Target class id.
Definition at line 81 of file sources/includes/nvds_tracker_meta.h.
◆ list
NvDsTargetMiscDataFrame * _NvDsTargetMiscDataObject::list
Definition at line 73 of file sources/includes/nvds_tracker_meta.h.
Referenced by deepstream::NvDsKittiDump::generateTrackerPastKittiDump().
◆ numAllocated
uint32_t _NvDsTargetMiscDataObject::numAllocated
Definition at line 77 of file sources/includes/nvds_tracker_meta.h.
◆ numObj
uint32_t _NvDsTargetMiscDataObject::numObj
Definition at line 75 of file sources/includes/nvds_tracker_meta.h.
◆ objLabel
char _NvDsTargetMiscDataObject::objLabel
Definition at line 83 of file sources/includes/nvds_tracker_meta.h.
◆ uniqueId
uint64_t _NvDsTargetMiscDataObject::uniqueId
Target tracking id.
Definition at line 79 of file sources/includes/nvds_tracker_meta.h.
