_NvDsTargetMiscDataStream Struct Reference
All misc targets data for a given stream.
Definition at line 90 of file sources/includes/nvds_tracker_meta.h.
Collaboration diagram for _NvDsTargetMiscDataStream:
Data Fields
NvDsTargetMiscDataObjectlist
 Pointer to targets inside this stream. More...
uint32_t streamID
 Stream id the same as frame_meta->pad_index. More...
uint64_t surfaceStreamID
 Stream id used inside tracker plugin. More...
uint32_t numAllocated
 Maximum number of objects allocated. More...
uint32_t numFilled
 Number of objects in this frame. More...
Field Documentation
◆ list
NvDsTargetMiscDataObject * _NvDsTargetMiscDataStream::list
Definition at line 93 of file sources/includes/nvds_tracker_meta.h.
Referenced by deepstream::NvDsKittiDump::generateTrackerPastKittiDump().
◆ numAllocated
uint32_t _NvDsTargetMiscDataStream::numAllocated
Definition at line 99 of file sources/includes/nvds_tracker_meta.h.
◆ numFilled
uint32_t _NvDsTargetMiscDataStream::numFilled
Definition at line 101 of file sources/includes/nvds_tracker_meta.h.
◆ streamID
uint32_t _NvDsTargetMiscDataStream::streamID
Definition at line 95 of file sources/includes/nvds_tracker_meta.h.
◆ surfaceStreamID
uint64_t _NvDsTargetMiscDataStream::surfaceStreamID
Definition at line 97 of file sources/includes/nvds_tracker_meta.h.
