7.1 Release
_NvOSD_ArrowParams Struct Reference
Holds arrow parameters to be overlaid.
Definition at line 200 of file nvll_osd_struct.h.
Collaboration diagram for _NvOSD_ArrowParams:
Data Fields
unsigned int x1
 Holds the start horizontal coordinate in pixels. More...
unsigned int y1
 Holds the start vertical coordinate in pixels. More...
unsigned int x2
 Holds the end horizontal coordinate in pixels. More...
unsigned int y2
 Holds the end vertical coordinate in pixels. More...
unsigned int arrow_width
 Holds the arrow shaft width in pixels. More...
NvOSD_Arrow_Head_Direction arrow_head
 Holds the arrowhead position. More...
NvOSD_ColorParams arrow_color
 Holds color parameters of the arrow box. More...
unsigned int reserved
 Reserved for future use; currently for internal use only. More...
Field Documentation
◆ arrow_color
NvOSD_ColorParams _NvOSD_ArrowParams::arrow_color
Definition at line 214 of file nvll_osd_struct.h.
◆ arrow_head
NvOSD_Arrow_Head_Direction _NvOSD_ArrowParams::arrow_head
Definition at line 211 of file nvll_osd_struct.h.
◆ arrow_width
unsigned int _NvOSD_ArrowParams::arrow_width
Definition at line 209 of file nvll_osd_struct.h.
◆ reserved
unsigned int _NvOSD_ArrowParams::reserved
Definition at line 217 of file nvll_osd_struct.h.
◆ x1
unsigned int _NvOSD_ArrowParams::x1
Definition at line 201 of file nvll_osd_struct.h.
◆ x2
unsigned int _NvOSD_ArrowParams::x2
Definition at line 205 of file nvll_osd_struct.h.
◆ y1
unsigned int _NvOSD_ArrowParams::y1
Definition at line 203 of file nvll_osd_struct.h.
◆ y2
unsigned int _NvOSD_ArrowParams::y2
Definition at line 207 of file nvll_osd_struct.h.
