_NvOSD_CircleParams Struct Reference
Holds circle parameters to be overlayed.
Definition at line 226 of file sources/includes/nvll_osd_struct.h.
Collaboration diagram for _NvOSD_CircleParams:
Data Fields
unsigned int xc
 Holds the start horizontal coordinate in pixels. More...
unsigned int yc
 Holds the start vertical coordinate in pixels. More...
unsigned int radius
 Holds the radius of circle in pixels. More...
NvOSD_ColorParams circle_color
 Holds the color parameters of the arrow box. More...
unsigned int has_bg_color
NvOSD_ColorParams bg_color
unsigned int circle_width
 Holds the circle's border width in pixels. More...
unsigned int reserved
 Reserved for future use; currently for internal use only. More...
Field Documentation
◆ bg_color
NvOSD_ColorParams _NvOSD_CircleParams::bg_color
Definition at line 239 of file sources/includes/nvll_osd_struct.h.
◆ circle_color
NvOSD_ColorParams _NvOSD_CircleParams::circle_color
Definition at line 233 of file sources/includes/nvll_osd_struct.h.
◆ circle_width
unsigned int _NvOSD_CircleParams::circle_width
Definition at line 241 of file sources/includes/nvll_osd_struct.h.
◆ has_bg_color
unsigned int _NvOSD_CircleParams::has_bg_color
Definition at line 236 of file sources/includes/nvll_osd_struct.h.
◆ radius
unsigned int _NvOSD_CircleParams::radius
Definition at line 231 of file sources/includes/nvll_osd_struct.h.
◆ reserved
unsigned int _NvOSD_CircleParams::reserved
Definition at line 243 of file sources/includes/nvll_osd_struct.h.
◆ xc
unsigned int _NvOSD_CircleParams::xc
Definition at line 227 of file sources/includes/nvll_osd_struct.h.
◆ yc
unsigned int _NvOSD_CircleParams::yc
Definition at line 229 of file sources/includes/nvll_osd_struct.h.
