_NvOSD_RectParams Struct Reference
Holds the box parameters of the box to be overlayed.
Definition at line 140 of file sources/includes/nvll_osd_struct.h.
Collaboration diagram for _NvOSD_RectParams:
Data Fields
float left
 Holds the box's left coordinate in pixels. More...
float top
 Holds the box's top coordinate in pixels. More...
float width
 Holds the box's width in pixels. More...
float height
 Holds the box's height in pixels. More...
unsigned int border_width
 Holds the box's border width in pixels. More...
NvOSD_ColorParams border_color
 Holds the box's border color. More...
unsigned int has_bg_color
 Holds a Boolean; true if the box has a background color. More...
unsigned int reserved
 Holds a field reserved for future use. More...
NvOSD_ColorParams bg_color
 Holds the box's background color. More...
int has_color_info
int color_id
float rotation_angle
 Holds the box's rotation angle in degrees in case of OBB. More...
Field Documentation
◆ bg_color
NvOSD_ColorParams _NvOSD_RectParams::bg_color
Definition at line 161 of file sources/includes/nvll_osd_struct.h.
◆ border_color
NvOSD_ColorParams _NvOSD_RectParams::border_color
Definition at line 153 of file sources/includes/nvll_osd_struct.h.
◆ border_width
unsigned int _NvOSD_RectParams::border_width
Definition at line 151 of file sources/includes/nvll_osd_struct.h.
◆ color_id
int _NvOSD_RectParams::color_id
Definition at line 164 of file sources/includes/nvll_osd_struct.h.
◆ has_bg_color
unsigned int _NvOSD_RectParams::has_bg_color
Definition at line 156 of file sources/includes/nvll_osd_struct.h.
◆ has_color_info
int _NvOSD_RectParams::has_color_info
Definition at line 163 of file sources/includes/nvll_osd_struct.h.
◆ height
float _NvOSD_RectParams::height
◆ left
float _NvOSD_RectParams::left
◆ reserved
unsigned int _NvOSD_RectParams::reserved
Definition at line 159 of file sources/includes/nvll_osd_struct.h.
◆ rotation_angle
float _NvOSD_RectParams::rotation_angle
Definition at line 166 of file sources/includes/nvll_osd_struct.h.
◆ top
float _NvOSD_RectParams::top
◆ width
float _NvOSD_RectParams::width
