_NvOSD_TextParams Struct Reference
Holds parameters of text to be overlayed.
Definition at line 115 of file sources/includes/nvll_osd_struct.h.
Collaboration diagram for _NvOSD_TextParams:
Data Fields
char * display_text
 Holds the text to be overlayed. More...
unsigned int x_offset
 Holds the text's horizontal offset from the top left pixel of the frame. More...
unsigned int y_offset
 Holds the text's vertical offset from the top left pixel of the frame. More...
NvOSD_FontParams font_params
 Holds the font parameters of the text to be overlaid. More...
int set_bg_clr
 Holds a Boolean; true if the text has a background color. More...
NvOSD_ColorParams text_bg_clr
 Holds the text's background color, if specified. More...
Field Documentation
◆ display_text
char * _NvOSD_TextParams::display_text
Definition at line 116 of file sources/includes/nvll_osd_struct.h.
◆ font_params
NvOSD_FontParams _NvOSD_TextParams::font_params
Definition at line 122 of file sources/includes/nvll_osd_struct.h.
◆ set_bg_clr
int _NvOSD_TextParams::set_bg_clr
Definition at line 124 of file sources/includes/nvll_osd_struct.h.
◆ text_bg_clr
NvOSD_ColorParams _NvOSD_TextParams::text_bg_clr
Definition at line 127 of file sources/includes/nvll_osd_struct.h.
◆ x_offset
unsigned int _NvOSD_TextParams::x_offset
Definition at line 118 of file sources/includes/nvll_osd_struct.h.
◆ y_offset
unsigned int _NvOSD_TextParams::y_offset
Definition at line 120 of file sources/includes/nvll_osd_struct.h.
