proto_adapter Struct Reference
Definition at line 53 of file sources/includes/nvmsgbroker_internal.h.
Public Member Functions
 proto_adapter ()
 proto_adapter ()
Data Fields
string protocol
void * so_handle
int ref_count
bool subscribe_capability
bool signature_capability
NvDsMsgApiHandle(* nvds_msgapi_connect_ptr )(char *connection_str, nvds_msgapi_connect_cb_t connect_cb, char *config_path)
NvDsMsgApiErrorType(* nvds_msgapi_disconnect_ptr )(NvDsMsgApiHandle h_ptr)
NvDsMsgApiErrorType(* nvds_msgapi_send_async_ptr )(NvDsMsgApiHandle conn, char *topic, const uint8_t *payload, size_t nbuf, nvds_msgapi_send_cb_t send_callback, void *user_ptr)
void(* nvds_msgapi_do_work_ptr )(NvDsMsgApiHandle h_ptr)
NvDsMsgApiErrorType(* nvds_msgapi_subscribe_ptr )(NvDsMsgApiHandle conn, char **topics, int num_topics, nvds_msgapi_subscribe_request_cb_t cb, void *user_ctx)
char *(* nvds_msgapi_getversion_ptr )(void)
char *(* nvds_msgapi_get_protocol_name_ptr )(void)
NvDsMsgApiErrorType(* nvds_msgapi_connection_signature_ptr )(char *connection_str, char *config_path, char *output_str, int max_len)
◆ proto_adapter() [1/2]
proto_adapter::proto_adapter ( )
inline
Definition at line 68 of file sources/includes/nvmsgbroker_internal.h.
◆ proto_adapter() [2/2]
inline
Definition at line 68 of file 9.0/sources/includes/nvmsgbroker_internal.h.
Field Documentation
◆ nvds_msgapi_connect_ptr
NvDsMsgApiHandle(* proto_adapter::nvds_msgapi_connect_ptr)(char *connection_str, nvds_msgapi_connect_cb_t connect_cb, char *config_path)
Definition at line 59 of file sources/includes/nvmsgbroker_internal.h.
◆ nvds_msgapi_connection_signature_ptr
NvDsMsgApiErrorType(* proto_adapter::nvds_msgapi_connection_signature_ptr)(char *connection_str, char *config_path, char *output_str, int max_len)
Definition at line 66 of file sources/includes/nvmsgbroker_internal.h.
◆ nvds_msgapi_disconnect_ptr
NvDsMsgApiErrorType(* proto_adapter::nvds_msgapi_disconnect_ptr)(NvDsMsgApiHandle h_ptr)
Definition at line 60 of file sources/includes/nvmsgbroker_internal.h.
◆ nvds_msgapi_do_work_ptr
void(* proto_adapter::nvds_msgapi_do_work_ptr)(NvDsMsgApiHandle h_ptr)
Definition at line 62 of file sources/includes/nvmsgbroker_internal.h.
◆ nvds_msgapi_get_protocol_name_ptr
char *(* proto_adapter::nvds_msgapi_get_protocol_name_ptr)(void)
Definition at line 65 of file sources/includes/nvmsgbroker_internal.h.
◆ nvds_msgapi_getversion_ptr
char *(* proto_adapter::nvds_msgapi_getversion_ptr)(void)
Definition at line 64 of file sources/includes/nvmsgbroker_internal.h.
◆ nvds_msgapi_send_async_ptr
NvDsMsgApiErrorType(* proto_adapter::nvds_msgapi_send_async_ptr)(NvDsMsgApiHandle conn, char *topic, const uint8_t *payload, size_t nbuf, nvds_msgapi_send_cb_t send_callback, void *user_ptr)
Definition at line 61 of file sources/includes/nvmsgbroker_internal.h.
◆ nvds_msgapi_subscribe_ptr
NvDsMsgApiErrorType(* proto_adapter::nvds_msgapi_subscribe_ptr)(NvDsMsgApiHandle conn, char **topics, int num_topics, nvds_msgapi_subscribe_request_cb_t cb, void *user_ctx)
Definition at line 63 of file sources/includes/nvmsgbroker_internal.h.
◆ protocol
string proto_adapter::protocol
Definition at line 54 of file sources/includes/nvmsgbroker_internal.h.
◆ ref_count
int proto_adapter::ref_count
Definition at line 56 of file sources/includes/nvmsgbroker_internal.h.
◆ signature_capability
bool proto_adapter::signature_capability
Definition at line 58 of file sources/includes/nvmsgbroker_internal.h.
◆ so_handle
void * proto_adapter::so_handle
Definition at line 55 of file sources/includes/nvmsgbroker_internal.h.
◆ subscribe_capability
bool proto_adapter::subscribe_capability
Definition at line 57 of file sources/includes/nvmsgbroker_internal.h.
