9.0/sources/apps/apps-common/includes/deepstream_sinks.h File Reference
Data Structures
struct  NvDsSinkEncoderConfig
struct  NvDsSinkRenderConfig
struct  NvDsSinkMsgConvBrokerConfig
struct  NvDsSinkSubBinConfig
struct  NvDsSinkBinSubBin
struct  NvDsSinkBin
Enumerations
enum  NvDsSinkType {
  NV_DS_SINK_FAKE = 1,
  NV_DS_SINK_RENDER_EGL,
  NV_DS_SINK_ENCODE_FILE,
  NV_DS_SINK_UDPSINK,
  NV_DS_SINK_RENDER_DRM,
  NV_DS_SINK_MSG_CONV_BROKER,
  NV_DS_SINK_UDPSINK,
enum  NvDsContainerType {
  NV_DS_CONTAINER_MP4 = 1,
  NV_DS_CONTAINER_MKV,
  NV_DS_CONTAINER_MKV
enum  NvDsEncoderType {
  NV_DS_ENCODER_H264 = 1,
  NV_DS_ENCODER_H265,
  NV_DS_ENCODER_MPEG4,
  NV_DS_ENCODER_H265,
  NV_DS_ENCODER_MPEG4
enum  NvDsEncHwSwType {
  NV_DS_ENCODER_TYPE_HW,
  NV_DS_ENCODER_TYPE_SW,
enum  NvDsEncOutputIOMode {
  NV_DS_ENCODER_OUTPUT_IO_MODE_MMAP = 2,
  NV_DS_ENCODER_OUTPUT_IO_MODE_DMABUF_IMPORT = 5,
Functions
gboolean create_sink_bin (guint num_sub_bins, NvDsSinkSubBinConfig *config_array, NvDsSinkBin *bin, guint index)
 Initialize NvDsSinkBin. More...
void destroy_sink_bin (void)
gboolean create_demux_sink_bin (guint num_sub_bins, NvDsSinkSubBinConfig *config_array, NvDsSinkBin *bin, guint index)
void set_rtsp_udp_port_num (guint rtsp_port_num, guint udp_port_num)
◆ NvDsContainerType
Enumerator
NV_DS_CONTAINER_MP4
NV_DS_CONTAINER_MKV
NV_DS_CONTAINER_MP4
NV_DS_CONTAINER_MKV
Definition at line 41 of file 9.0/sources/apps/apps-common/includes/deepstream_sinks.h.
◆ NvDsEncHwSwType
Enumerator
Definition at line 54 of file 9.0/sources/apps/apps-common/includes/deepstream_sinks.h.
◆ NvDsEncoderType
Enumerator
NV_DS_ENCODER_H264
NV_DS_ENCODER_H265
NV_DS_ENCODER_MPEG4
NV_DS_ENCODER_H264
NV_DS_ENCODER_H265
NV_DS_ENCODER_MPEG4
Definition at line 47 of file 9.0/sources/apps/apps-common/includes/deepstream_sinks.h.
◆ NvDsEncOutputIOMode
Enumerator
Definition at line 60 of file 9.0/sources/apps/apps-common/includes/deepstream_sinks.h.
◆ NvDsSinkType
Enumerator
NV_DS_SINK_FAKE
NV_DS_SINK_UDPSINK
NV_DS_SINK_FAKE
NV_DS_SINK_UDPSINK
Definition at line 27 of file 9.0/sources/apps/apps-common/includes/deepstream_sinks.h.
Function Documentation
◆ create_demux_sink_bin()
gboolean create_demux_sink_bin ( guint  num_sub_bins,
NvDsSinkSubBinConfig config_array,
NvDsSinkBin bin,
guint  index
◆ create_sink_bin()
gboolean create_sink_bin ( guint  num_sub_bins,
NvDsSinkBin bin,
guint  index
It creates and adds sink and other elements needed for processing to the bin. It also sets properties mentioned in the configuration file under group CONFIG_GROUP_SINK
Parameters
[in]num_sub_binsnumber of sink elements.
[in]config_arrayarray of pointers of type NvDsSinkSubBinConfig parsed from configuration file.
[in]binpointer to NvDsSinkBin to be filled.
[in]indexid of source element.
Returns
true if bin created successfully.
◆ destroy_sink_bin()
void destroy_sink_bin ( void  )
◆ set_rtsp_udp_port_num()
void set_rtsp_udp_port_num ( guint  rtsp_port_num,
guint  udp_port_num
