Typedefs | |
| typedef struct NvDsServerDecInfo | NvDsServerDecInfo |
| typedef struct NvDsServerMuxInfo | NvDsServerMuxInfo |
| typedef struct NvDsServerConvInfo | NvDsServerConvInfo |
| typedef struct NvDsServerAppInstanceInfo | NvDsServerAppInstanceInfo |
| typedef void * | NvDst_Handle_NvMultiUriSrcCreator |
Functions | |
| gboolean | find_source (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId) |
| API to check if sourceId related source exist. More... | |
| gboolean | set_nvuribin_dec_prop (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId, NvDsServerDecInfo *dec_info) |
| API to set property value on nvv4l2decoder of nvmultiurisrcbin instance. More... | |
| gboolean | set_nvuribin_conv_prop (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId, NvDsServerConvInfo *conv_info) |
| API to set property value on nvvideoconvert of nvmultiurisrcbin instance. More... | |
| gboolean | set_nvuribin_mux_prop (NvDst_Handle_NvMultiUriSrcCreator apiHandle, NvDsServerMuxInfo *mux_info) |
| API to set property value on nvstreammux of nvmultiurisrcbin instance. More... | |
| gboolean | s_force_eos_handle (NvDst_Handle_NvMultiUriSrcCreator apiHandle, NvDsServerAppInstanceInfo *appinstance_info) |
| API to set EOS related properties on nvstreammux of nvmultiurisrcbin instance. More... | |
| NvDst_Handle_NvMultiUriSrcCreator | gst_nvmultiurisrcbincreator_init (gchar *binName, NvDsMultiUriMode mode, GstDsNvStreammuxConfig *muxConfig) |
| Initialize the API for nvmultiurisrcbin creation Note: nvmultiurisrcbin is a collection of DeepStream plugins viz: nvurisrcbin X N -> nvstreammux. More... | |
| gboolean | gst_nvmultiurisrcbincreator_add_source (NvDst_Handle_NvMultiUriSrcCreator apiHandle, GstDsNvUriSrcConfig *sourceConfig) |
| API to add a source/stream into the nvmultiurisrcbin instance A new instance of nvurisrcbin will be created for this stream and be linked with appropriate sink pad of the nvstreammux instance. More... | |
| gboolean | gst_nvmultiurisrcbincreator_remove_source (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId) |
| API to remove a source/stream from the nvmultiurisrcbin instance The corresponding nvurisrcbin will be unlinked from nvstreammux and removed from the parent nvmultiurisrcbin instance. More... | |
| gboolean | gst_nvmultiurisrcbincreator_remove_source_without_forced_state_change (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId) |
| GstElement * | gst_nvmultiurisrcbincreator_get_bin (NvDst_Handle_NvMultiUriSrcCreator apiHandle) |
| Get the nvmultiurisrcbin GstBin User may: a) add this Bin/Element into their pipeline and b) link the bin's src pad to downstream element Note: This bin's src pad capability will be same as nvstreammux src pad capability. More... | |
| GstPad * | gst_nvmultiurisrcbincreator_get_source_pad (NvDst_Handle_NvMultiUriSrcCreator apiHandle) |
| API to procure the source pad ("src") of this nvmultiurisrcbin instance Note: User may link the bin's src pad to downstream element Note: This src pad is the nvstreammux instance's src pad. More... | |
| gboolean | gst_nvmultiurisrcbincreator_sync_children_states (NvDst_Handle_NvMultiUriSrcCreator apiHandle) |
| void | gst_nvmultiurisrcbincreator_deinit (NvDst_Handle_NvMultiUriSrcCreator apiHandle) |
| Deinit the nvmultiurisrcbin creator API Note: If this bin was added to a parent pipeline instance, Use this API before calling gst_object_unref on the pipeline object. More... | |
| GstDsNvUriSrcConfig * | gst_nvmultiurisrcbincreator_get_source_config (NvDst_Handle_NvMultiUriSrcCreator apiHandle, gchar const *uri, gchar const *sensorId) |
| API to procure the source config for a particular sensor. More... | |
| GstDsNvUriSrcConfig * | gst_nvmultiurisrcbincreator_src_config_dup (GstDsNvUriSrcConfig *sourceConfig) |
| API to create duplicate of GstDsNvUriSrcConfig. More... | |
| void | gst_nvmultiurisrcbincreator_src_config_free (GstDsNvUriSrcConfig *config) |
| API to free GstDsNvUriSrcConfig object obtained with API: gst_nvmultiurisrcbincreator_src_config_dup. More... | |
| GstDsNvUriSrcConfig * | gst_nvmultiurisrcbincreator_get_source_config_by_sensorid (NvDst_Handle_NvMultiUriSrcCreator apiHandle, gchar const *sensorId) |
| gboolean | gst_nvmultiurisrcbincreator_get_active_sources_list (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint *count, GstDsNvUriSrcConfig ***configs) |
| API to procure the list of sources. More... | |
| gboolean | gst_nvmultiurisrcbincreator_get_source_info_list (NvDst_Handle_NvMultiUriSrcCreator apiHandle, GList **sensor_info_list) |
| API to procure the list of active sources. More... | |
| void | gst_nvmultiurisrcbincreator_src_config_list_free (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint count, GstDsNvUriSrcConfig **configs) |
| API to destroy the memory allocation for list of sources procured with API: gst_nvmultiurisrcbincreator_get_active_sources_list() More... | |
| gchar * | gst_nvmultiurisrcbincreator_get_sensor_id_from_source_id (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId) |
| API to get the sensor id from the source id. More... | |
| guint | get_gpu_id (NvDst_Handle_NvMultiUriSrcCreator apiHandle) |
| API to get the GPU ID configured for the nvmultiurisrcbin creator. More... | |
| typedef struct NvDsServerAppInstanceInfo NvDsServerAppInstanceInfo |
Definition at line 23 of file 9.0/sources/includes/gst-nvmultiurisrcbincreator.h.
| typedef struct NvDsServerConvInfo NvDsServerConvInfo |
Definition at line 22 of file 9.0/sources/includes/gst-nvmultiurisrcbincreator.h.
| typedef struct NvDsServerDecInfo NvDsServerDecInfo |
Definition at line 20 of file 9.0/sources/includes/gst-nvmultiurisrcbincreator.h.
| typedef struct NvDsServerMuxInfo NvDsServerMuxInfo |
Definition at line 21 of file 9.0/sources/includes/gst-nvmultiurisrcbincreator.h.
| typedef void* NvDst_Handle_NvMultiUriSrcCreator |
Definition at line 31 of file 9.0/sources/includes/gst-nvmultiurisrcbincreator.h.
| enum NvDsMultiUriMode |
Definition at line 33 of file 9.0/sources/includes/gst-nvmultiurisrcbincreator.h.
| gboolean find_source | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
| guint | sourceId | ||
| [in] | apiHandle | The nvmultiurisrcbincreator API handle returned by init |
| [in] | sourceId | sourceId information of the stream |
| guint get_gpu_id | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle | ) |
This function retrieves the GPU ID that is being used by the nvstreammux component within the nvmultiurisrcbin. The GPU ID determines which GPU device is used for processing streams.
| gboolean gst_nvmultiurisrcbincreator_add_source | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
| GstDsNvUriSrcConfig * | sourceConfig | ||
| [in] | sourceConfig | New stream/source configuration information |
| void gst_nvmultiurisrcbincreator_deinit | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle | ) |
| gboolean gst_nvmultiurisrcbincreator_get_active_sources_list | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
| guint * | count, | ||
| GstDsNvUriSrcConfig *** | configs | ||
| [in/out] | count The number of streams added to this bin using API gst_nvmultiurisrcbincreator_add_source() | |
| [in/out] | configs An array of configs of size count [transfer-full] Please free this configs array using API gst_nvmultiurisrcbincreator_src_config_list_free() API gst_nvmultiurisrcbincreator_add_source() |
| GstElement* gst_nvmultiurisrcbincreator_get_bin | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle | ) |
| gchar* gst_nvmultiurisrcbincreator_get_sensor_id_from_source_id | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
| [in] | sourceId | The source id |
| GstDsNvUriSrcConfig* gst_nvmultiurisrcbincreator_get_source_config | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
| gchar const * | uri, | ||
| gchar const * | sensorId | ||
| [in] | uri | The uri string (need to exactly match details provided with gst_nvmultiurisrcbincreator_add_source() |
| [in] | sensorId | The sensorId string (need to exactly match details provided with gst_nvmultiurisrcbincreator_add_source() |
| GstDsNvUriSrcConfig* gst_nvmultiurisrcbincreator_get_source_config_by_sensorid | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
| gboolean gst_nvmultiurisrcbincreator_get_source_info_list | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
| GList ** | sensor_info_list | ||
| [in/out] | sensor_info_list A list which would contain the sensor realted info |
| GstPad* gst_nvmultiurisrcbincreator_get_source_pad | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle | ) |
Thus, the src pad GstCaps capability will be same as nvstreammux src pad capability
| NvDst_Handle_NvMultiUriSrcCreator gst_nvmultiurisrcbincreator_init | ( | gchar * | binName, |
| NvDsMultiUriMode | mode, | ||
| GstDsNvStreammuxConfig * | muxConfig | ||
| [in] | binName | A name to the nvmultiurisrcbin instance |
| [in] | mode | The bin's mode can either be video-only or audio-only |
| [in] | muxConfig | The nvstreammux config to use within nvmultiurisrcbin |
| gboolean gst_nvmultiurisrcbincreator_remove_source | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
The book-keeping for this source will also be cleared. Note: This API force the nvurisrcbin state to GST_STATE_NULL
| [in] | sourceId | stream/source ID matching the provided source configuration information |
| gboolean gst_nvmultiurisrcbincreator_remove_source_without_forced_state_change | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
The book-keeping for this source will also be cleared. Note: This API does force the nvurisrcbin state to GST_STATE_NULL Users may leverage this API when the state change happens externally (example: when there is an ERROR)
| GstDsNvUriSrcConfig* gst_nvmultiurisrcbincreator_src_config_dup | ( | GstDsNvUriSrcConfig * | sourceConfig | ) |
| void gst_nvmultiurisrcbincreator_src_config_free | ( | GstDsNvUriSrcConfig * | config | ) |
| void gst_nvmultiurisrcbincreator_src_config_list_free | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
| guint | count, | ||
| GstDsNvUriSrcConfig ** | configs | ||
| [in] | count | The size of configs array |
| [in] | configs | array of configs returned by API gst_nvmultiurisrcbincreator_get_active_sources_list() API gst_nvmultiurisrcbincreator_add_source() |
| gboolean gst_nvmultiurisrcbincreator_sync_children_states | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle | ) |
| gboolean s_force_eos_handle | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
| NvDsServerAppInstanceInfo * | appinstance_info | ||
| [in] | appinstance_info | info structure with activity to be used to set eos related properties on the nvstreammux |
| gboolean set_nvuribin_conv_prop | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
| guint | sourceId, | ||
| NvDsServerConvInfo * | conv_info | ||
| [in] | conv_info | converter info structure with property value to be used to set on the nvvideoconvert |
| gboolean set_nvuribin_dec_prop | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
| NvDsServerDecInfo * | dec_info | ||
| [in] | dec_info | decoder info structure with property value to be used to set on the nvv4l2decoder |
| gboolean set_nvuribin_mux_prop | ( | NvDst_Handle_NvMultiUriSrcCreator | apiHandle, |
| NvDsServerMuxInfo * | mux_info | ||
| [in] | mux_info | info structure with property value to be used to set on the nvstreammux |
