8.0 Release
sources/includes/gst-nvmultiurisrcbincreator.h File Reference
Typedefs
typedef struct NvDsServerDecInfo NvDsServerDecInfo
typedef struct NvDsServerMuxInfo NvDsServerMuxInfo
typedef struct NvDsServerConvInfo NvDsServerConvInfo
typedef struct NvDsServerAppInstanceInfo NvDsServerAppInstanceInfo
typedef void * NvDst_Handle_NvMultiUriSrcCreator
Enumerations
enum  NvDsMultiUriMode {
  NVDS_MULTIURISRCBIN_MODE_VIDEO,
  NVDS_MULTIURISRCBIN_MODE_AUDIO,
Functions
gboolean find_source (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId)
 API to check if sourceId related source exist. More...
gboolean set_nvuribin_dec_prop (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId, NvDsServerDecInfo *dec_info)
 API to set property value on nvv4l2decoder of nvmultiurisrcbin instance. More...
gboolean set_nvuribin_conv_prop (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId, NvDsServerConvInfo *conv_info)
 API to set property value on nvvideoconvert of nvmultiurisrcbin instance. More...
gboolean set_nvuribin_mux_prop (NvDst_Handle_NvMultiUriSrcCreator apiHandle, NvDsServerMuxInfo *mux_info)
 API to set property value on nvstreammux of nvmultiurisrcbin instance. More...
gboolean s_force_eos_handle (NvDst_Handle_NvMultiUriSrcCreator apiHandle, NvDsServerAppInstanceInfo *appinstance_info)
 API to set EOS related properties on nvstreammux of nvmultiurisrcbin instance. More...
NvDst_Handle_NvMultiUriSrcCreator gst_nvmultiurisrcbincreator_init (gchar *binName, NvDsMultiUriMode mode, GstDsNvStreammuxConfig *muxConfig)
 Initialize the API for nvmultiurisrcbin creation Note: nvmultiurisrcbin is a collection of DeepStream plugins viz: nvurisrcbin X N -> nvstreammux. More...
gboolean gst_nvmultiurisrcbincreator_add_source (NvDst_Handle_NvMultiUriSrcCreator apiHandle, GstDsNvUriSrcConfig *sourceConfig)
 API to add a source/stream into the nvmultiurisrcbin instance A new instance of nvurisrcbin will be created for this stream and be linked with appropriate sink pad of the nvstreammux instance. More...
gboolean gst_nvmultiurisrcbincreator_remove_source (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId)
 API to remove a source/stream from the nvmultiurisrcbin instance The corresponding nvurisrcbin will be unlinked from nvstreammux and removed from the parent nvmultiurisrcbin instance. More...
gboolean gst_nvmultiurisrcbincreator_remove_source_without_forced_state_change (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId)
GstElement * gst_nvmultiurisrcbincreator_get_bin (NvDst_Handle_NvMultiUriSrcCreator apiHandle)
 Get the nvmultiurisrcbin GstBin User may: a) add this Bin/Element into their pipeline and b) link the bin's src pad to downstream element Note: This bin's src pad capability will be same as nvstreammux src pad capability. More...
GstPad * gst_nvmultiurisrcbincreator_get_source_pad (NvDst_Handle_NvMultiUriSrcCreator apiHandle)
 API to procure the source pad ("src") of this nvmultiurisrcbin instance Note: User may link the bin's src pad to downstream element Note: This src pad is the nvstreammux instance's src pad. More...
gboolean gst_nvmultiurisrcbincreator_sync_children_states (NvDst_Handle_NvMultiUriSrcCreator apiHandle)
void gst_nvmultiurisrcbincreator_deinit (NvDst_Handle_NvMultiUriSrcCreator apiHandle)
 Deinit the nvmultiurisrcbin creator API Note: If this bin was added to a parent pipeline instance, Use this API before calling gst_object_unref on the pipeline object. More...
GstDsNvUriSrcConfiggst_nvmultiurisrcbincreator_get_source_config (NvDst_Handle_NvMultiUriSrcCreator apiHandle, gchar const *uri, gchar const *sensorId)
 API to procure the source config for a particular sensor. More...
GstDsNvUriSrcConfiggst_nvmultiurisrcbincreator_src_config_dup (GstDsNvUriSrcConfig *sourceConfig)
 API to create duplicate of GstDsNvUriSrcConfig. More...
void gst_nvmultiurisrcbincreator_src_config_free (GstDsNvUriSrcConfig *config)
 API to free GstDsNvUriSrcConfig object obtained with API: gst_nvmultiurisrcbincreator_src_config_dup. More...
GstDsNvUriSrcConfiggst_nvmultiurisrcbincreator_get_source_config_by_sensorid (NvDst_Handle_NvMultiUriSrcCreator apiHandle, gchar const *sensorId)
gboolean gst_nvmultiurisrcbincreator_get_active_sources_list (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint *count, GstDsNvUriSrcConfig ***configs)
 API to procure the list of sources. More...
gboolean gst_nvmultiurisrcbincreator_get_source_info_list (NvDst_Handle_NvMultiUriSrcCreator apiHandle, GList **sensor_info_list)
 API to procure the list of active sources. More...
void gst_nvmultiurisrcbincreator_src_config_list_free (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint count, GstDsNvUriSrcConfig **configs)
 API to destroy the memory allocation for list of sources procured with API: gst_nvmultiurisrcbincreator_get_active_sources_list() More...
gchar * gst_nvmultiurisrcbincreator_get_sensor_id_from_source_id (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId)
 API to get the sensor id from the source id. More...
guint get_gpu_id (NvDst_Handle_NvMultiUriSrcCreator apiHandle)
 API to get the GPU ID configured for the nvmultiurisrcbin creator. More...
Typedef Documentation
◆ NvDsServerAppInstanceInfo
◆ NvDsServerConvInfo
◆ NvDsServerDecInfo
◆ NvDsServerMuxInfo
◆ NvDst_Handle_NvMultiUriSrcCreator
◆ NvDsMultiUriMode
Enumerator
Definition at line 33 of file sources/includes/gst-nvmultiurisrcbincreator.h.
Function Documentation
◆ find_source()
gboolean find_source ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
guint  sourceId
Parameters
[in]apiHandleThe nvmultiurisrcbincreator API handle returned by init
[in]sourceIdsourceId information of the stream
Returns
TRUE if source found, else FALSE
◆ get_gpu_id()
guint get_gpu_id ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle)
This function retrieves the GPU ID that is being used by the nvstreammux component within the nvmultiurisrcbin. The GPU ID determines which GPU device is used for processing streams.
Parameters
Returns
The GPU ID configured in the mux configuration Returns 0 if muxConfig is NULL or not set
◆ gst_nvmultiurisrcbincreator_add_source()
gboolean gst_nvmultiurisrcbincreator_add_source ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
GstDsNvUriSrcConfig sourceConfig
Parameters
[in]sourceConfigNew stream/source configuration information
Returns
TRUE if successful, else FALSE
◆ gst_nvmultiurisrcbincreator_deinit()
void gst_nvmultiurisrcbincreator_deinit ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle)
Parameters
◆ gst_nvmultiurisrcbincreator_get_active_sources_list()
gboolean gst_nvmultiurisrcbincreator_get_active_sources_list ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
guint *  count,
GstDsNvUriSrcConfig ***  configs
Parameters
[in/out]count The number of streams added to this bin using API gst_nvmultiurisrcbincreator_add_source()
[in/out]configs An array of configs of size count [transfer-full] Please free this configs array using API gst_nvmultiurisrcbincreator_src_config_list_free() API gst_nvmultiurisrcbincreator_add_source()
Returns
TRUE if API was successful; FALSE otherwise
◆ gst_nvmultiurisrcbincreator_get_bin()
GstElement* gst_nvmultiurisrcbincreator_get_bin ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle)
Parameters
Returns
[transfer none] A pointer to the nvmultiurisrcbin instance GstBin typecasted to the parent GstElement
◆ gst_nvmultiurisrcbincreator_get_sensor_id_from_source_id()
gchar* gst_nvmultiurisrcbincreator_get_sensor_id_from_source_id ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
guint  sourceId
Parameters
[in]sourceIdThe source id
Returns
The sensor id
◆ gst_nvmultiurisrcbincreator_get_source_config()
GstDsNvUriSrcConfig* gst_nvmultiurisrcbincreator_get_source_config ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
gchar const *  uri,
gchar const *  sensorId
Parameters
[in]uriThe uri string (need to exactly match details provided with gst_nvmultiurisrcbincreator_add_source()
[in]sensorIdThe sensorId string (need to exactly match details provided with gst_nvmultiurisrcbincreator_add_source()
Returns
source config for the running sensor where uri and sensorId match [transfer-full] the pointer returned shall be freed using API gst_nvmultiurisrcbincreator_src_config_free(1, &returnedPointer)
◆ gst_nvmultiurisrcbincreator_get_source_config_by_sensorid()
GstDsNvUriSrcConfig* gst_nvmultiurisrcbincreator_get_source_config_by_sensorid ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
Parameters
Returns
◆ gst_nvmultiurisrcbincreator_get_source_info_list()
gboolean gst_nvmultiurisrcbincreator_get_source_info_list ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
GList **  sensor_info_list
Parameters
[in/out]sensor_info_list A list which would contain the sensor realted info
Returns
◆ gst_nvmultiurisrcbincreator_get_source_pad()
GstPad* gst_nvmultiurisrcbincreator_get_source_pad ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle)
Thus, the src pad GstCaps capability will be same as nvstreammux src pad capability
Parameters
Returns
source pad for nvmultiurisrcbin
◆ gst_nvmultiurisrcbincreator_init()
NvDst_Handle_NvMultiUriSrcCreator gst_nvmultiurisrcbincreator_init ( gchar *  binName,
GstDsNvStreammuxConfig muxConfig
Parameters
[in]binNameA name to the nvmultiurisrcbin instance
[in]modeThe bin's mode can either be video-only or audio-only
[in]muxConfigThe nvstreammux config to use within nvmultiurisrcbin
Returns
The handle to this API instance
◆ gst_nvmultiurisrcbincreator_remove_source()
gboolean gst_nvmultiurisrcbincreator_remove_source ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
guint  sourceId
The book-keeping for this source will also be cleared. Note: This API force the nvurisrcbin state to GST_STATE_NULL
Parameters
[in]sourceIdstream/source ID matching the provided source configuration information
Returns
◆ gst_nvmultiurisrcbincreator_remove_source_without_forced_state_change()
gboolean gst_nvmultiurisrcbincreator_remove_source_without_forced_state_change ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
guint  sourceId
The book-keeping for this source will also be cleared. Note: This API does force the nvurisrcbin state to GST_STATE_NULL Users may leverage this API when the state change happens externally (example: when there is an ERROR)
Parameters
Returns
◆ gst_nvmultiurisrcbincreator_src_config_dup()
GstDsNvUriSrcConfig* gst_nvmultiurisrcbincreator_src_config_dup ( GstDsNvUriSrcConfig sourceConfig)
◆ gst_nvmultiurisrcbincreator_src_config_free()
void gst_nvmultiurisrcbincreator_src_config_free ( GstDsNvUriSrcConfig config)
◆ gst_nvmultiurisrcbincreator_src_config_list_free()
void gst_nvmultiurisrcbincreator_src_config_list_free ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
guint  count,
GstDsNvUriSrcConfig **  configs
Parameters
[in]countThe size of configs array
[in]configsarray of configs returned by API gst_nvmultiurisrcbincreator_get_active_sources_list() API gst_nvmultiurisrcbincreator_add_source()
◆ gst_nvmultiurisrcbincreator_sync_children_states()
gboolean gst_nvmultiurisrcbincreator_sync_children_states ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle)
Parameters
Returns
◆ s_force_eos_handle()
gboolean s_force_eos_handle ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
NvDsServerAppInstanceInfo appinstance_info
Parameters
[in]appinstance_infoinfo structure with activity to be used to set eos related properties on the nvstreammux
Returns
◆ set_nvuribin_conv_prop()
gboolean set_nvuribin_conv_prop ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
guint  sourceId,
NvDsServerConvInfo conv_info
Parameters
[in]conv_infoconverter info structure with property value to be used to set on the nvvideoconvert
Returns
◆ set_nvuribin_dec_prop()
gboolean set_nvuribin_dec_prop ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
guint  sourceId,
NvDsServerDecInfo dec_info
Parameters
[in]dec_infodecoder info structure with property value to be used to set on the nvv4l2decoder
Returns
◆ set_nvuribin_mux_prop()
gboolean set_nvuribin_mux_prop ( NvDst_Handle_NvMultiUriSrcCreator  apiHandle,
NvDsServerMuxInfo mux_info
Parameters
[in]mux_infoinfo structure with property value to be used to set on the nvstreammux
Returns
