8.0 Release
9.0/sources/libs/nvdsinfer/nvdsinfer_backend.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2019-2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
13 #ifndef __NVDSINFER_BACKEND_H__
14 #define __NVDSINFER_BACKEND_H__
15
16 #include <stdarg.h>
17 #include <condition_variable>
18 #include <memory>
19 #include <mutex>
20 #include <queue>
21
22 #include <cuda_runtime_api.h>
23
24 #include <NvInfer.h>
25 #include <NvInferRuntime.h>
26
27 #include "nvdsinfer_func_utils.h"
28
29 /* This file provides backend inference interface for abstracting implementation
30  * details in various cases like inferencing on implicit batch dims/full dims
31  * network, inferencing on DLA etc. This file also provides helper classes for
32  * managing the lifecycle of CUDA resources like streams, buffers, events. */
33
34 namespace nvdsinfer {
35
39 class CudaStream
40 {
41 public:
42  explicit CudaStream(uint flag = cudaStreamDefault, int priority = 0);
43  ~CudaStream();
44  operator cudaStream_t() { return m_Stream; }
45  cudaStream_t& ptr() { return m_Stream; }
47
48 private:
49  void move_copy(CudaStream&& o)
50  {
51  m_Stream = o.m_Stream;
52  o.m_Stream = nullptr;
53  }
54  DISABLE_CLASS_COPY(CudaStream);
55
56  cudaStream_t m_Stream = nullptr;
57 };
58
62 class CudaEvent
63 {
64 public:
65  explicit CudaEvent(uint flag = cudaEventDefault);
66  ~CudaEvent();
67  operator cudaEvent_t() { return m_Event; }
68  cudaEvent_t& ptr() { return m_Event; }
70
71 private:
72  void move_copy(CudaEvent&& o)
73  {
74  m_Event = o.m_Event;
75  o.m_Event = nullptr;
76  }
77  DISABLE_CLASS_COPY(CudaEvent);
78
79  cudaEvent_t m_Event = nullptr;
80 };
81
85 class CudaBuffer
86 {
87 public:
88  virtual ~CudaBuffer() = default;
89  size_t bytes() const { return m_Size; }
90
91  template <typename T>
92  T* ptr()
93  {
94  return (T*)m_Buf;
95  }
96
97  void* ptr() { return m_Buf; }
99
100 protected:
101  explicit CudaBuffer(size_t s) : m_Size(s) {}
103  {
104  m_Buf = o.m_Buf;
105  o.m_Buf = nullptr;
106  m_Size = o.m_Size;
107  o.m_Size = 0;
108  }
110  void* m_Buf = nullptr;
111  size_t m_Size = 0;
112 };
113
117 class CudaDeviceBuffer : public CudaBuffer
118 {
119 public:
120  explicit CudaDeviceBuffer(size_t size);
122 };
123
127 class CudaHostBuffer : public CudaBuffer
128 {
129 public:
130  explicit CudaHostBuffer(size_t size);
131  ~CudaHostBuffer();
132 };
133
137 class InferBatchBuffer
138 {
139 public:
140  InferBatchBuffer() = default;
141  virtual ~InferBatchBuffer() = default;
142
143  /* Get device buffer pointers for bound layers associated with this batch. */
144  virtual std::vector<void*>& getDeviceBuffers() = 0;
145  /* Get the data type of the buffer(layer) for a bound layer having index
146  * `bindingIndex`. */
147  virtual NvDsInferDataType getDataType(int bindingIndex = 0) const = 0;
148  /* Get the batch dimensions for the buffer allocated for a bound layer having
149  * index `bindingIndex. */
150  virtual NvDsInferBatchDims getBatchDims(int bindingIndex = 0) const = 0;
151
152 private:
153  DISABLE_CLASS_COPY(InferBatchBuffer);
154 };
155
167 class BackendContext
168 {
169 public:
170  BackendContext() = default;
171  virtual ~BackendContext() = default;
172
173  /* Initialize the backend context. */
174  virtual NvDsInferStatus initialize() = 0;
175  /* Get the number of bound layers for the engine. */
176  virtual int getNumBoundLayers() = 0;
177
178  /* Get information for a bound layer with index `bindingIdx`. */
179  virtual const NvDsInferBatchDimsLayerInfo& getLayerInfo(int bindingIdx) = 0;
180  /* Get binding index for a bound layer with name `bindingName`. */
181  virtual bool isOutputLayer(const std::string& bindingName) = 0;
182
183  /* Returns if the bound layer at index `bindingIdx` can support the
184  * provided batch dimensions. */
185  virtual bool canSupportBatchDims(
186  int bindingIdx, const NvDsInferBatchDims& batchDims) = 0;
187
188  /* Get the min/max/optimal batch dimensions for a bound layer. */
189  virtual NvDsInferBatchDims getMaxBatchDims(int bindingIdx) = 0;
190  virtual NvDsInferBatchDims getMinBatchDims(int bindingIdx) = 0;
191  virtual NvDsInferBatchDims getOptBatchDims(int bindingIdx) = 0;
192
193  /* Enqueue a batched buffer for inference. */
195  const std::shared_ptr<InferBatchBuffer>& buffer, CudaStream& stream,
196  CudaEvent* consumeEvent) = 0;
197
198 private:
199  DISABLE_CLASS_COPY(BackendContext);
200 };
201
202 class TrtEngine;
203
208 class TrtBackendContext : public BackendContext
209 {
210 public:
212
213 protected:
214  TrtBackendContext(std::unique_ptr<nvinfer1::IExecutionContext>&& ctx,
215  std::shared_ptr<TrtEngine> engine);
216
217  bool isOutputLayer(const std::string& bindingName) override;
218  int getNumBoundLayers() override;
219
220  const NvDsInferBatchDimsLayerInfo& getLayerInfo(int bindingIdx) override
221  {
222  assert(bindingIdx < (int)m_AllLayers.size());
223  return m_AllLayers[bindingIdx];
224  }
225
226  bool canSupportBatchDims(
227  int bindingIdx, const NvDsInferBatchDims& batchDims) override;
228
229  virtual NvDsInferBatchDims getMaxBatchDims(int bindingIdx) override
230  {
231  assert(bindingIdx < (int)m_AllLayers.size());
232  return m_AllLayers[bindingIdx].profileDims[kSELECTOR_MAX];
233  }
234  virtual NvDsInferBatchDims getMinBatchDims(int bindingIdx) override
235  {
236  assert(bindingIdx < (int)m_AllLayers.size());
237  return m_AllLayers[bindingIdx].profileDims[kSELECTOR_MIN];
238  }
239  virtual NvDsInferBatchDims getOptBatchDims(int bindingIdx) override
240  {
241  assert(bindingIdx < (int)m_AllLayers.size());
242  return m_AllLayers[bindingIdx].profileDims[kSELECTOR_OPT];
243  }
244
245 protected:
246  std::unique_ptr<nvinfer1::IExecutionContext> m_Context;
247  std::shared_ptr<TrtEngine> m_CudaEngine;
248  std::vector<NvDsInferBatchDimsLayerInfo> m_AllLayers;
249
250  int m_GpuId = -1;
251
252  static std::mutex sDLAExecutionMutex;
253 };
254
258 class FullDimTrtBackendContext : public TrtBackendContext
259 {
260 public:
262  std::unique_ptr<nvinfer1::IExecutionContext>&& ctx,
263  std::shared_ptr<TrtEngine> engine, int profile = 0);
264
265 private:
266  NvDsInferStatus initialize() override;
267
268  NvDsInferStatus enqueueBuffer(
269  const std::shared_ptr<InferBatchBuffer>& buffer, CudaStream& stream,
270  CudaEvent* consumeEvent) override;
271
272 protected:
273  // Only idx 0 profile supported.
274  const int m_ProfileIndex = 0;
275 };
276
280 class DlaFullDimTrtBackendContext : public FullDimTrtBackendContext
281 {
282 public:
283  DlaFullDimTrtBackendContext(std::unique_ptr<nvinfer1::IExecutionContext>&& ctx,
284  std::shared_ptr<TrtEngine> engine, int profile = 0);
285
287  const std::shared_ptr<InferBatchBuffer>& buffer, CudaStream& stream,
288  CudaEvent* consumeEvent) override;
289
290 private:
291  static std::mutex sExecutionMutex;
292 };
293
303 std::unique_ptr<TrtBackendContext> createBackendContext(
304  const std::shared_ptr<TrtEngine>& engine);
305
306 } // end of namespace nvdsinfer
307
308 #endif
cudaStream_t
struct CUstream_st * cudaStream_t
Forward declaration of cudaStream_t.
Definition: sources/includes/nvbufsurftransform.h:35
nvdsinfer::TrtBackendContext::isOutputLayer
bool isOutputLayer(const std::string &bindingName) override
nvdsinfer::TrtBackendContext::TrtBackendContext
TrtBackendContext(std::unique_ptr< nvinfer1::IExecutionContext > &&ctx, std::shared_ptr< TrtEngine > engine)
nvdsinfer::FullDimTrtBackendContext::m_ProfileIndex
Definition: sources/libs/nvdsinfer/nvdsinfer_backend.h:274
nvdsinfer::BackendContext::enqueueBuffer
virtual NvDsInferStatus enqueueBuffer(const std::shared_ptr< InferBatchBuffer > &buffer, CudaStream &stream, CudaEvent *consumeEvent)=0
nvdsinfer::createBackendContext
std::unique_ptr< TrtBackendContext > createBackendContext(const std::shared_ptr< TrtEngine > &engine)
Create an instance of a BackendContext.
nvdsinfer::CudaHostBuffer::~CudaHostBuffer
~CudaHostBuffer()
nvdsinfer::CudaBuffer
Helper base class for managing Cuda allocated buffers.
Definition: sources/libs/nvdsinfer/nvdsinfer_backend.h:85
nvdsinfer::CudaDeviceBuffer::CudaDeviceBuffer
nvdsinfer::InferBatchBuffer::getBatchDims
virtual NvDsInferBatchDims getBatchDims(int bindingIndex=0) const =0
nvdsinfer::BackendContext::getMaxBatchDims
virtual NvDsInferBatchDims getMaxBatchDims(int bindingIdx)=0
nvdsinfer::TrtBackendContext::m_AllLayers
std::vector< NvDsInferBatchDimsLayerInfo > m_AllLayers
Definition: sources/libs/nvdsinfer/nvdsinfer_backend.h:248
nvdsinfer::InferBatchBuffer::InferBatchBuffer
InferBatchBuffer()=default
nvdsinfer::TrtBackendContext::m_GpuId
int m_GpuId
Definition: sources/libs/nvdsinfer/nvdsinfer_backend.h:250
nvdsinfer::TrtBackendContext::getLayerInfo
const NvDsInferBatchDimsLayerInfo & getLayerInfo(int bindingIdx) override
Definition: 9.0/sources/libs/nvdsinfer/nvdsinfer_backend.h:220
nvdsinfer::BackendContext::getOptBatchDims
virtual NvDsInferBatchDims getOptBatchDims(int bindingIdx)=0
nvdsinfer::CudaStream
Helper class for managing Cuda Streams.
Definition: sources/libs/nvdsinfer/nvdsinfer_backend.h:39
nvdsinfer::BackendContext::~BackendContext
virtual ~BackendContext()=default
nvdsinfer::DlaFullDimTrtBackendContext::DlaFullDimTrtBackendContext
DlaFullDimTrtBackendContext(std::unique_ptr< nvinfer1::IExecutionContext > &&ctx, std::shared_ptr< TrtEngine > engine, int profile=0)
nvdsinfer::TrtBackendContext::canSupportBatchDims
bool canSupportBatchDims(int bindingIdx, const NvDsInferBatchDims &batchDims) override
nvdsinfer::CudaStream::ptr
cudaStream_t & ptr()
Definition: 9.0/sources/libs/nvdsinfer/nvdsinfer_backend.h:45
nvdsinfer::CudaEvent::~CudaEvent
~CudaEvent()
nvdsinfer::CudaBuffer::CudaBuffer
Definition: 9.0/sources/libs/nvdsinfer/nvdsinfer_backend.h:101
nvdsinfer::TrtBackendContext::sDLAExecutionMutex
Definition: sources/libs/nvdsinfer/nvdsinfer_backend.h:252
nvdsinfer::TrtBackendContext::m_Context
std::unique_ptr< nvinfer1::IExecutionContext > m_Context
Definition: sources/libs/nvdsinfer/nvdsinfer_backend.h:246
nvdsinfer::CudaDeviceBuffer::~CudaDeviceBuffer
~CudaDeviceBuffer()
nvdsinfer::BackendContext::getMinBatchDims
virtual NvDsInferBatchDims getMinBatchDims(int bindingIdx)=0
NvDsInferDataType
NvDsInferDataType
Specifies the data type of a layer.
Definition: sources/includes/nvdsinfer.h:72
nvdsinfer::InferBatchBuffer::getDeviceBuffers
virtual std::vector< void * > & getDeviceBuffers()=0
nvdsinfer::CudaBuffer::m_Buf
void * m_Buf
Definition: sources/libs/nvdsinfer/nvdsinfer_backend.h:110
nvdsinfer
Definition: sources/includes/nvdsinfer_logger.h:54
nvdsinfer::BackendContext::initialize
virtual NvDsInferStatus initialize()=0
CudaStream
Definition: sources/gst-plugins/gst-nvdspreprocess/nvdspreprocess_lib/nvdspreprocess_impl.h:97
nvdsinfer::BackendContext::getLayerInfo
virtual const NvDsInferBatchDimsLayerInfo & getLayerInfo(int bindingIdx)=0
nvdsinfer::TrtBackendContext::getNumBoundLayers
nvdsinfer::CudaBuffer::ptr
T * ptr()
Definition: 9.0/sources/libs/nvdsinfer/nvdsinfer_backend.h:92
nvdsinfer::InferBatchBuffer::getDataType
virtual NvDsInferDataType getDataType(int bindingIndex=0) const =0
nvdsinfer::CudaBuffer::move_copy
void move_copy(CudaBuffer &&o)
Definition: 9.0/sources/libs/nvdsinfer/nvdsinfer_backend.h:102
nvdsinfer::TrtBackendContext::m_CudaEngine
std::shared_ptr< TrtEngine > m_CudaEngine
Definition: sources/libs/nvdsinfer/nvdsinfer_backend.h:247
CudaBuffer
Definition: sources/gst-plugins/gst-nvdspreprocess/nvdspreprocess_lib/nvdspreprocess_impl.h:123
nvdsinfer::CudaEvent::CudaEvent
CudaEvent(uint flag=cudaEventDefault)
nvdsinfer::CudaBuffer::DISABLE_CLASS_COPY
DISABLE_CLASS_COPY(CudaBuffer)
nvdsinfer::BackendContext::getNumBoundLayers
virtual int getNumBoundLayers()=0
nvdsinfer::BackendContext::BackendContext
nvdsinfer::FullDimTrtBackendContext::FullDimTrtBackendContext
nvdsinfer::CudaBuffer::m_Size
size_t m_Size
Definition: sources/libs/nvdsinfer/nvdsinfer_backend.h:111
nvdsinfer::TrtBackendContext::getOptBatchDims
Definition: 9.0/sources/libs/nvdsinfer/nvdsinfer_backend.h:239
nvdsinfer::CudaBuffer::bytes
Definition: 9.0/sources/libs/nvdsinfer/nvdsinfer_backend.h:89
nvdsinfer::DlaFullDimTrtBackendContext::enqueueBuffer
NvDsInferStatus enqueueBuffer(const std::shared_ptr< InferBatchBuffer > &buffer, CudaStream &stream, CudaEvent *consumeEvent) override
nvdsinfer::CudaEvent::ptr
cudaEvent_t & ptr()
Definition: 9.0/sources/libs/nvdsinfer/nvdsinfer_backend.h:68
nvdsinfer::CudaHostBuffer::CudaHostBuffer
nvdsinfer::BackendContext::canSupportBatchDims
virtual bool canSupportBatchDims(int bindingIdx, const NvDsInferBatchDims &batchDims)=0
nvdsinfer::CudaStream::CudaStream
CudaStream(uint flag=cudaStreamDefault, int priority=0)
CudaDeviceBuffer
CUDA device buffers.
Definition: sources/gst-plugins/gst-nvdspreprocess/nvdspreprocess_lib/nvdspreprocess_impl.h:161
SIMPLE_MOVE_COPY
#define SIMPLE_MOVE_COPY(Cls)
helper move function
Definition: sources/gst-plugins/gst-nvdspreprocess/nvdspreprocess_lib/nvdspreprocess_impl.h:41
nvdsinfer::TrtBackendContext::getMaxBatchDims
Definition: 9.0/sources/libs/nvdsinfer/nvdsinfer_backend.h:229
nvdsinfer::CudaBuffer::~CudaBuffer
virtual ~CudaBuffer()=default
void * ptr()
Definition: 9.0/sources/libs/nvdsinfer/nvdsinfer_backend.h:97
nvdsinfer::TrtBackendContext::getMinBatchDims
Definition: 9.0/sources/libs/nvdsinfer/nvdsinfer_backend.h:234
nvdsinfer::InferBatchBuffer::~InferBatchBuffer
virtual ~InferBatchBuffer()=default
nvdsinfer::BackendContext::isOutputLayer
virtual bool isOutputLayer(const std::string &bindingName)=0
Helper class for managing Cuda events.
Definition: sources/libs/nvdsinfer/nvdsinfer_backend.h:62
nvdsinfer::TrtBackendContext::~TrtBackendContext
~TrtBackendContext()
nvdsinfer::CudaStream::~CudaStream
~CudaStream()
NvDsInferStatus
NvDsInferStatus
Definition: sources/includes/nvdsinfer.h:226
